Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 81 to 120 of 121
Thread: Live Mapping Cosworth ECUs - A How To
  1. #81
    Aug 2012
    Sweden
    12
    Re: Live Mapping Cosworth ECUs - A How To
    I am running AFR 13 @ WOT
  2. #82
    Jan 2014
    Antwerp Belgium
    Turbo charged and at 16psi or more ??
  3. #83
    Aug 2012
    Sweden
    12
    27psi at the moment
    The key is to have "low" ignition.
    And AFR 13 is only possible with livemapping on the road. If you are on the dyno the engine does not get the same afr with the same map, itīs much richer and still makes the most power then.
    Have not found the reason why yet ... Probably something with the wind speed?
  4. #84
    Jan 2014
    Antwerp Belgium
    Think you are right. I am roadmapping to.
    Only my bin with closed loop has some sort of checksum in it.
    You have any idea where to disable this ?
  5. #85
    Aug 2012
    Sweden
    12
    Looked into the .bin and didnīt find any obvious checksum correction. (Im not that good at the assembler language )
    Try increase one value with 1 hex and reduce another value with 1 hex. If the car starts then it is a checksum correction involved.
    I have made these tricks on other cars with checksum correction on them and i didnīt find how the correction counted or didnīt know where the value was stored.
  6. #86
    Clint's Avatar
    Jul 2001
    925,729
    Email me the bin and I will remove the checksum when I have time. clint@turbosport.co.uk
  7. #87
    Jan 2014
    Antwerp Belgium
    Sent
  8. #88
    Aug 2012
    Sweden
    12
    Have you found it Clint?
    I tried the .BIN to day on my car , and i can say that itīs NOT a standard checksum calculation. If i change the values so a standard checksum calc would be happy this one is not ...
    BTW does this .BIN have datacomm activated? I tried my datacomm logger with it but it didnīt work.
    Iīm looking for a .BIN that has datacomm activated so i can calibrate my 5bar map-sensor
  9. #89
    Jan 2014
    Antwerp Belgium
    Any news Clint ?
  10. #90
    Aug 2012
    Sweden
    12
    Have anyone got hit tracing in Tunerpro to work on P8 box? It only works on L8 for me
  11. #91
    Clint's Avatar
    Jul 2001
    925,729
    Can I get a picture of the chip fitted to the ecu, before I look at the bin ?
  12. #92
    Jan 2014
    Antwerp Belgium
    Hello Clint , you have at post 72 .
  13. #93
    Clint's Avatar
    Jul 2001
    925,729
    Ok I will take a look, I need to set this up on the bench with the ostrich, I am not 100% sure I have a L8 ecu here.
  14. #94
    Jan 2014
    Antwerp Belgium
    Hi Clint , had already time to look at the bin ?
    Grts
    Patrick
  15. #95
    Jul 2013
    Stoke on trent
    33
    10
    you still into this clint?
  16. #96
    Apr 2011
    Grantham
    65
    12
    Hi Clint are you still into P8 and live mapping would be very interested I am also trying to get a megasquirt running on my Rally Car I have just bought an AEM Peak & Hold DRiver
  17. #97
    Clint's Avatar
    Jul 2001
    925,729
    Hi yes I am still Mapping all of these Weber ECU;s
  18. #98
    Apr 2011
    Grantham
    65
    12
    Could you point me in the right direction as far as equipment needed and a few pointers on the P8 file s required
    Many thanks
  19. #99
    Clint's Avatar
    Jul 2001
    925,729
    TunerPro - Moates Ostrich 2 - Innovative LM2 or Techedge (an AFR that has logging), eprom reader and writer.
  20. #100
    Bodger Duffer's Avatar
    Jan 2014
    West Sussex
    198
    27
    Hi Clint, you mention that you have a P8 tuneable by only a RS232 lead... Very interested. Do you have details of the setup that you are running to achieve this?
    I have a P8 running a MSD stage 3 with wasted spark from the ecu (not their daughter board). I am also running a T25 inlet and TB, along with the T25 TPS, so am currently running without the ISCV fitted. I would like to do all the live mapping myself from the stage that I am at. Obviously the MSD chip sits on an encryption board, so where am I best starting?
    Clint's Avatar
    Jul 2001
    925,729
    Quote Originally Posted by Duffer View Post
    You need a Moates Ostrich 2 - I can un-encrypt the chip for you and tell you where the checksumms are for a small fee you can then remap the software you have.
  22. #102
    Jan 2014
    West Sussex
    198
    27
    Brilliant Clint, I shall get the kit along with the AFR plumbed in and then I shall be paying you a visit
    Certainly is a better solution than paying alot of money and upset just to go aftermarket as the P8 is so good
  23. #103
    Jun 2012
    Slovakia
    to remove checksum test on P8 ECU just change value on address 94CF from 27 to 20.
    I have a full xdf driver for P8 ecu (tunerPRO). If anybody wants to play with this...
  24. #104
    Apr 2011
    Grantham
    65
    12
    Hi If you could send me the xdf drive and a little help on how to do this I have a Moates Ostrich 2 on the way and have registered tunerPRo
  25. #105
    Jun 2012
    Slovakia
    send me your mail to pm
  26. #106
    Apr 2011
    Grantham
    65
    12
    Hi Please mail to k.bennett744@gmail.com
  27. #107
    Jun 2013
    Greece
    31
    Hi there. I have a sierra cosworth with l8 ecu. I bought the ostrich 2 emulator and the tunerpro and I connected to my ecu. Now my problem is that althought I have to xdf and bin file I need I also need the ADX file to live map the ecu. Can anyone help me to thatg pleasE? Thanks!
  28. #108
    Jun 2013
    Greece
    31
    None? Ohh please help me with the adx file and of cource I will pay if it is needed!
  29. #109
    Apr 2011
    Grantham
    65
    12
    send me your e-mail address and i will send you one
  30. #110
    Aug 2013
    Norway
    Hi all,
    Looking for L8 standard and stage1 bin with tuned fuel and spark table.
    Can anyone help?
    thanks
  31. #111
    Apr 2011
    Grantham
    65
    12
    Hi Clint
    Great to see you are getting better
    Could you help with my encrypted P8 can send you the Chip if that is any good?
    Thanks Kevin
  32. #112
    Sep 2016
    UK
    What do you want from chip, just to decode it ?
    Let me know and I can post back to you
  33. #113
    Jun 2014
    Malta
    12
    Hi Guys
    Has anybody tried fiddling around with the injection firing angle degrees.
    I am play around with a programable ecu. The car has been dynoed, made 350bhp on pump fuel which is enough for what i needed. What i noticed is that it is using much more fuel , apart from the over run fuel, i was looking into other things that could use alot of more fuel.
    Infact i locked the fuel and timing on idle at around 950rpm, and took some readings for different injection firing angles. the best result was at -90 .
    The problem is that this is at idle.
    I don't know how i can work out the rest of the map.
    Any help even with a std map would be very helpful.
    Thanks and regards
    Cpur
  34. #114
    Tyre Kicker Mark_Lister's Avatar
    Mar 2003
    West Sussex
    I know this is probably highly illegal - but can someone PM or post up a standard P8 BIN file. I need to burn a standard chip so I can simply test the ECU Fuel Pump prime and ISCV pulse (my ECU doesn't want to do either). This is just to rule out a dodgy Pectel board/chip.
    Anyone able to help?
  35. #115
    Mar 2003
    West Sussex
    Scratch that, all sorted! Thanks all!
  36. #116
    Feb 2019
    italy
    Good morning
    I hope my question is not included in the wrong post.
    I'd like to know how to figure out each ecu map what does it correspond to?
    I read somewhere that there is a sw of marelli called VISION that could serve this purpose, do you think it is so?
    thanks for all a greeting to all
  37. #117
    Jun 2012
    Slovakia
    you need xdf file for ecu....
    on tunerpro sitt you can find l8 and p8 xdf file from me
  38. #118
    Feb 2019
    italy
    ok thanks 1000
    are the xdfs you made very complete?
    I'm also interested in activating strange things like
    als
    bang
    water injection
    if possible pop or crackle
    (I state that I only need the bang) but I'd be curious to understand
    how to activate the whole trip if you can activate it.
    P.S. obviously I know that both the engine and the turbo need to be modified, that I will have to fit a larger valve, etc.
    a big hello
  39. #119
    Mar 2020
    Wales
    Relighting an old thread maybe Iv got a cosworth ecu with pectel board in my rs turbo its a l6 with pectel board Been having issues with flagging up knock sensor code my car hasnt even got one it does it around 5000rpm An cut my boost write back Iv tryed everything out 2 other looms As i was advised might be rf signals i rewired a loom with ur screened wires for crank cam an crank sensor an made sure all wires were uncut An it still does it If i post my file could u unencript it so i can use the map on tuner pro if i pay ya a fee want to be able to have a play about aswell as fix my problem I bought a burn 2 programmer Havent got a ostrich yet Iv even got a datamans4 an pectel program but having trouble using it Was told program worked without dongle but im not so sure An im a newb on eproms an older dos programs Im a mechanic an know the basics but learning Im assuming my problem is l6 hasnt got a knock sensor an l8 board does Was mapped by oddkiddcreations It hasnt always done it though Iv even put a diff ecu in aswell So think deffo something in the map
  40. #120
    Mar 2020
    Wales
    Sorry for the essay
Similar Threads
  1. cosworth mapping
    By mk1wayne in forum Cosworth Installations
    Last Post: 12-05-2006, 14:14
  2. live mapping!!.. i need and AFR table and ign table
    By casper002 in forum The Technical Section
    Last Post: 27-04-2006, 18:44
  3. cossie ecus for sale
    By scrote in forum Parts For Sale
    Last Post: 07-11-2005, 10:07
  4. std S2 ecus
    By Dans2turbo in forum Parts For Sale
    Last Post: 02-06-2003, 09:44
  5. 2wd Saph Cossie Ecus ?
    By 900ss in forum Cosworth Installations
    Last Post: 23-05-2003, 22:41
