Hi all a while ago I posted on here about my decked block after much thought I went down the route of having the pistons machined after loosing out on 2 blocks from eBay.
I'm getting close to completion now and I'm just woundering what kind of performance I can roughly expect out of my engine so HP , fuel economy, 0-60 time in standard escort with mex gearbox single prop and standard back end spec list below: and I'm not racing it's a road car
1700 xflow New everything in terms of seals
1300 +0.090 pistons (raised compression) and turned down 1.6mm
Kent bcf2 fast road cam
Piper dual valve springs
Steel rocker assembly, posts spacers
Port and polished faced and 're-cut valve head but retains gt/mex valve sizes New cam followers bearings all arround
crank ground 0.030 both j
Steel crank pulley
7.5 kg flywheel over the standard 12kg
Duplex dining chain kit
Standard oil pump kn oil filter and magnetic sump plug
Standard fuel pump
Mls head gasket standard thickness
Sportex 4 branch exhaust manifold and single back box
Yamaha r1 bike carbs and manifold with pipercross filter
Standard conrods
Arp studs all round: head, caps and rods
Powerspark ignition kit includes high power coil and magnetic pick up dizzy And ngk 4 point spark plugs
65amp altinator
The next question is since I've had so much machining done is it worth getting everything balanced up as I've been quoted an eye watering 280 +vat for the lot to be balanced up
Also I haven't had the head done for unleaded can I run unleaded fuel or will I need and additive. I was told having seats done was bad news of xflows
