Results 1 to 24 of 24
Thread: Negative crankcase pressure with a dry sump
    Jul 2009
    Perth, Australia
    112
    Help - is this normal?
    I have a Duratec installed in my escort running the SBD supplied Titan dry sump pump. I have read that these should be run with a sealed engine so have capped all the engine breathers. The tank is mounted in the engine bay and is vented to atmosphere. When I run the engine (even at idle) the crankcase vacuum is high enough that it is difficult to lift off the oil filler cap, and when I shut the engine down I can hear air being sucked back in for about 20 to 30 seconds afterwards.
    Jun 2004
    Yarm (Teesside)
    64
    Re: Negative crankcase pressure with a dry sump
    When I installed a dry sump (Pace system) on my Cosworth YBT engine in my RS200 replica I had a small return line from the top of the dry sump tank (swirl pot part) which had a small non return valve fitted. The idea behind this was to allow the negative pressure to suck any oily fumes back to the engine and also break the vacuum slightly.
    This also then meant that the oil catch tank which I had fitted from the dry sump tank didn't get any oily fumes if everything was working correctly.
    But I have seen other systems with no return line but the top of the engine has a very small hole 1-2mm) in a cam cover take off pipe to allow the vacuum to break.
    I have also seen them like yours and each engine builder has said theirs is the correct way.
    All I can say mine worked very well and it ran 460+ BHP
    Jim
    Jun 2004
    Yarm (Teesside)
    64
    Jim
    May 2004
    Norn Iron
    1,142
    Some will some wont, just depends on the actual pump and setup used.
    But if it is pulling vacuum, which is no bad thing it would be wise to fit a check valve somewhere on the breathers to actually limit how much vacuum can be pulled.
    Jul 2009
    Perth, Australia
    112
    From my google research it seems that a vacuum is really good, but I also agree I need to fit some sort of relief/check valve to limit.
    Thanks for your responses.
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Is crankcase vacuum another of these horsepower old wives tales? Alot do it but I have never found a back to back test on a dyno done. Just pondering....
    Oct 2013
    Suffolk
    47
    194
    You want neg" pressure
    It helps the engine , you only have to much when the seals are
    Being sucked in which causes a squeaky noise
    Neg" pressure can variey due to a number of thing
    Pump effiencey
    Engine seals strength
    Piston and ring clearance
    Na will normally pull neg pressure through the revs
    Where a turbo engine will get blow by at revs due to boost
    My friend builds engines for the burgcup and other events
    And he has done a lot of testing with engines with dry sumps
    Ref" negative pressure
    And has always says there much better with more
    This is why he uses may kits as he can pull more neg pressure
    If a one way valve is fitted
    It needs to dump at about 5/10 psi
    And on a na it needs to let the engine breathe in
    And on a turbo the valve needs to let the engine breathe out
    Hope this helps
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Unless the sum of the scavenge side of the pump has a much greater capacity than the pressure side then even a dry sump will have a quantity of oil in the bottom. If there is a certain depth of oil then the scavenge side of the pump will only ever pull oil and never air from that sump i.e. never create a vacuum. My weaver 3 stage pump has 66% more scavenge capability (2 x 1.2" vs 1 x 1.45" gears) although I am not sure by how much the long return line via a filter and cooler reduces this capability (I did have a damaged scavenge section which would have reduced capability significantly). I should therefore have an empty sump at all times and be creating a vacuum but there is no way of knowing.....Now that I have a Picoscope I will be measuring real world block pressures!! ........mythbusting time........??
    Dec 2008
    Finland
    35
    376
    Peterson fluids makes a nice adjustable vacuum regulator with filter for drysump systems
    http://www.petersonfluidsys.com/engi...Regulator.html
    Oct 2013
    Suffolk
    47
    194
    Probably no good for turbo application
    As once it comes on boost the engine goes from negative
    To positive pressure
    May 2004
    Norn Iron
    1,142
    Quote Originally Posted by Lacey View Post
    The above in no way connects to anything that boost would affect it. And it is a suitable valve to use for limiting vacuum in the crankcase on a dry sump system where it will pull vacuum in there.
    n/a, boosted, whatever.
    Oct 2013
    Suffolk
    47
    194
    I've been involved in dry sumping
    Engines for 20 years
    I machined pumps/kits for the super touring cars in 1999 and onwards
    And for a lot of the big names in the industry
    All these people done test after test
    N/a and turbo
    With the info being fed back to us
    So I think you will find I do know that boost will
    Effect negative crank pressure
    Boost will alway find its way here there and everywhere
    The only reason you want a one way valve on a n/a dry sump engine
    Is because The pump ( if you have a good one ) will pull the seals cause
    A squeak noise and the possibility of pulling dirt in
    This is the same on a turbo engine till the boost cuts in
    Then blow by will happen
    hence the one way valve is turned around to
    Breathe out so once the blow by get to high it can bleed
    It off
    or it can blow the seals out
    This has been proven time and time again
    May 2004
    Norn Iron
    1,142
    Please explain how "boost" will find its way into the crankcase ?
    And the valve listed above is a vacuum limiting valve to prevent excess vacuum being created in the crankcase. Used all over the world without issue.
    And nobody has asked for a one way valve ?
    ring blowby, you will always get some under boost
    May 2004
    Norn Iron
    1,142
    And equally combustion of all sorts can generate cylinder pressure which if you've a crap ring seal can lead to some blowby.
    So there is little difference n/a or boost, and that is not "boost" finding its way into the crankcase.
    agree, but you dont get 100% seal with any ring, and combustion pressures are much higher than N/a so you will get more blowby
    Oct 2013
    Suffolk
    47
    194
    Lol
    Oh dear
    All my findings are based on facts from the top end of race team/company's down to the
    Humble engine build testing on dyno
    New rings will blow by to
    The only ring that reduces it to a minimum are total seal ring and there still not a 100% seal in turbo engines once max boost is reached
    Lol now your excepting there is a little difference between na and turbo as you say above
    If it ain't boost what is it then as the only real main difference is the lung bolted on the side of the engine
    To be honest mate I am getting bored of justifying fact to you sorry
    So believe what you want to believe mate it make no difference to me
    May 2004
    Norn Iron
    1,142
    Of course it is not boost, it's combustion pressure. The two are not the same.
    And the valve listed does the job it is listed for and is correct for a dry sump that pulls vac in the crankcase regardless of the application.
  19. #19
    your splitting hairs, whether its boost or combustion pressure matters not, when the engine is under high boost you get more blowby and the system isn't going to hold a negative pressure
  20. #20
    May 2004
    Norn Iron
    1,142
    It isnt splitting hairs, it's being factual.
    If the system cannot pull vac in the crankcase, then that is inadequacies with the scavenge pump system in use. Not any filter valves used, or boost, or rings, or anything like that.
    The pump is either capable or it is not...design it right from the outset.
    And if cannot pull vac, then design a breather system to suit !
  21. #21
    `i think the problem here is with a high boost engine, if you could still pull a vacuum under full load/boost then off boost the vacuum would be so massive you would suck the oil seals in
  22. #22
    May 2004
    Norn Iron
    1,142
    Which is exactly why you use the Peterson valve listed above ! It will limit the amount of vac you can pull to prevent that happening and is adjustable so you can decide how much vacuum you allow it.
  23. #23
    Oct 2013
    Suffolk
    47
    194
    Lol
    This is funny now
    First you went on about the valve
    Then say I was wrong about the rings and everything else
    Now your stating the obvious about the pump being up to the job
    Just out of curiosity would you argue that black is white
    No need for a answer I think I know already
    But maybe that's wrong to lol
  24. #24
    May 2004
    Norn Iron
    1,142
    And who is arguing black is white ?
    You claimed boost made its way into the crankcase, that is factually incorrect.
    You were the one saying that valve/ref/filter is of no use on a boosted car...which again is factually incorrect.
    You make claims as if all n/a engines have absolutely zero blowby from combustion/cylinder pressure and that is unique to a boosted engine...again 100% incorrect.
    You claim a boosted engine with dry sump will never pull vac...which again, is 100% incorrect.
    Or did I misread what you have said ?
