Results 1 to 11 of 11
Thread: Different Capri Struts for a MK 1 escort
    Sep 2005
    California USA
    284
    58
    Could someone please explain the differences in the Capri struts that are considered an upgrade fro a MK1 escort? Pics will help.
    I live in the US, and while some Capri's were imported. I don't know which would be the best upgrade for my 1300GT Mk1 escort
    James
    9,208
    In general the Capri struts are same as escort rs.
    They have replaceable inserts
    Disc brakes with m16 calipers
    Spring seat is about an inch lower so lowers car.
  3. The Following User Says Thank You to alladdin For This Useful Post:
    Sep 2005
    California USA
    284
    58
    Re: Different Capri Struts for a MK 1 escort
    Thanks for the reply, some more question that hopefully will help me avoid buying the wrong parts
    If I were fitting Capri coilovers to a MK1 escort what other considerations do I need to think about.
    I see several components on Gartrac site such as top caps, and alloy suspension mounts (with different sizes; standard and less and inch and adjustable lower spring seat, and different top mounts)
    https://www.gartrac.com/shop/steerin...leg-parts.html
    James
  5. #4
    Jan 2016
    Hull
    246
    Generally there are three types of Capri strut. 1.6/2.0-2.8 and 3.0. 1.6/2.0 struts can easily be converted to coil overs and able to fit adjustable inserts. 2.8 struts will be bilstein identifiable by the thick shocker rod and a nut at bottom of tube. 3.0 struts don't even touch as the the parts for them are one offs nothing can be used off anything else.
  6. #5
    9,208
    Not sure what your question is. If your buying new just tell them what you want it for.
  7. #6
    Jan 2016
    Hull
    246
    Think there might be some confusion between std struts and what we call coil overs.
  8. #7
    Sep 2005
    California USA
    284
    58
    How suitable would these be for a MK1 escort? The came from a 1973 SCCA capri.
    Any idea of value as is?
    James
    Click image for larger version Name:	IMG_4457.JPG Views:	118 Size:	84.7 KB ID:	79765Click image for larger version Name:	IMG_4458.JPG Views:	118 Size:	86.7 KB ID:	79766Click image for larger version Name:	IMG_4459.JPG Views:	115 Size:	82.6 KB ID:	79767
  9. #8
    Sep 2005
    California USA
    284
    58
    Bump
  10. #9
    9,208
    Struts look possible correct
    Top mount wrong
    Spring poundage ?
    Damper condition and settings ?
    It's a -How long is a piece of string - type question
  11. The Following User Says Thank You to alladdin For This Useful Post:
  12. #10
    Sep 2005
    California USA
    284
    58
    Any one pictures of the 2.8i strut? and do they have vented rotors (discs) and what do the brake caliper's look like.
    can they be bought new?
    James
  13. #11
    9,208
    Strut looks like normal Capri strut but
    Rod is thicker as its a bilstein unit
    There is a nut at bottom or threaded hole if damper missing
    Probably rubber gaitor over rod
    Vented discs as standard
    Calipers are normal m16 with a spacer between the halves.
  14. The Following User Says Thank You to alladdin For This Useful Post:
