Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 81 to 120 of 329
Thread: My Escort XE Project!
  1. #81
    Re: My Escort XE Project!
    Nice work skmotorsport!
  2. #82
    Oct 2011
    Plymouth, United Kingdom
    11
    Looks stunning
  3. #83
    Great work 👍
  4. #84
    May 2016
    Germany
    288
    63
    Gearbox bracket finished!
    The normal T9 Gearbox bracket is too short if you fit a big tunnel!
    Maybe I will attach some triangled plates to stiffen the outer wings...
    Next job was my Ingnition Coil pack.
    Normally it sits near the heater bowl. But I decided to screw it to the engine.
    After make some paper mockups I ordered a 10mm thick alloy plate. To reduce vibrations I will add some rubber washers.
    Now it sits under my Throttlebodies and the Ignition cables are not visible...
    Stay tuned
  5. #85
    May 2016
    Germany
    288
    63
    Not much done due to a lot of private appointments...
    BUT... I finished my Rims!!!
    Look at this beauties!!
  6. #86
    May 2010
    london
    1,139
    Quote Originally Posted by skmotorsport View Post
    Attachment 82845
    Attachment 82846
    Attachment 82847
    very nice...keep the pics comimg..cheers mark
  7. #87
    May 2016
    Germany
    288
    63
    Next job done...Closing my huge gearbox tunnel hole. My intention is to keep the escort as original as possible inside! To keep the original center console in place with the big gearbox tunnel it was nescessary to build my own cover and weld it together. Just some small tuning underneath the center console with the grinder and here we are...it fits nearly perfect with the IP/ ashtray cover. There ist a small 8mm gap which i can close with the anti noise foil and the carpet!
    stay tuned....
  8. #88
    May 2016
    Germany
    288
    63
    The tyre nightmare. After fitting the BBS it shows that the fenders need more work...and the tyres more space...
    Maybe I need to mill the alloy front hubs by 10mm to get the wheels under my fenders. Tomorrow I will check the clearance between the tyre and the front springs. If there´s enough clearance I can move on...
    The rearside fits perfeclty.
  9. #89
    May 2016
    Germany
    288
    63
    Last week I finished the welding on the watts linkage (pre welded, final welding will be done on the roller Jig)
    Both Watt domes are now in place.
    I also mounted the alloy radiator to prepare the cooling hoses.
    And I sarted to check the routing of the exhaust system. It seems to need abit love an time to get more clearance to the Steering column shaft.
    To get more clearance at the front fenders I ordered again new alloy hubs with standard measurements. The ones I used at the moment are the GRP4 Style hubs with a plus of 10mm per side! Together with some slight modifications at the fenders together with some spacers between the BBS outer Rims it will produce about 15mm more clearance! That should be enough to go lower at the front!!Next Job will be the brake lines.
    Stay tuned...
  10. #90
    May 2016
    Germany
    288
    63
    Last week I´ve checked the bias paddle box...what else...the throttle pedal goes straight through my steering column shaft.
    After redesign it looks a bit funny...but it works perfectly.
  11. #91
    May 2016
    Germany
    288
    63
    Small steps...
    Adapter found from Motamec to get water hoses in the perfect angle!
    Also found a place for my two brake fluid bottles...(not the alloy bumper brackets!!)
    Next step is to complete the brake system. With metal hoses, adapters for the Wilwood calipers...
    And I received a funny pic from a friend...he modifiyed my trumpets!
  12. #92
    Mechanic Matt75's Avatar
    Mar 2011
    Melbourne
    797
    Looking great, keep at it
    Matt
  13. #93
    May 2016
    Germany
    288
    63
  14. #94
    May 2016
    Germany
    288
    63
    This week I started with the gearbox. I ordered a new alloy top plate with breather from JT.
    And I made some wings to stiften the gearbox mounting
    03A71342-D84F-4EC8-960F-29583421D848.jpeg D6AC356D-DB21-4ECE-9328-B60BA2E873A0.jpeg
    And I started to find out the best Seat position. One issue to fix is the bias Pedal Box brake Pedal position.
    To get it in the right Position i have to cut the thread from the Pistons an made two 6 mm thick spacer
    Also the fuel pump bracket arrived. Now all parts can go to powder coating.
    Stay tuned...
  15. #95
    May 2016
    Germany
    288
    63
    Engine and Brake fluid reservoir brackets came back.
    Yesterday i started to finish the trunk. It seems that I need to cut the top of the tank bracket to get silver paint behind the punched holes!
    next step is creating the bracket for the battery and the fuel pump/filter galery.
  16. #96
    May 2016
    Germany
    288
    63
    Next stop, fuel Tank sender for my RS cluster.
    The cluster is now ready with the carbon foil. The rev.couter is Now getting to a specialist to expand the rev Range from 7000 to 8000 rpm.
    Final solution for the fuel sender unit was the original one, which is used in standard escorts. To fix it I used alloy rivet nuts.
    B06E3D0B-54AA-4F5A-8B52-024B4BB7849A.jpeg A79984BD-BD34-41EF-BC41-EBF4FEECF99E.jpeg
    To get a balanced presure to the unit I used a alloy ring. Now it looks perfekt.
    82950BD0-2CD4-42D9-89F2-170F7AE6EE27.jpeg 09A9A863-8A2D-4B4E-9CCB-D5513692F2D7.jpeg
    Now it will take some hours of cleaning the tank !
    Also the wet sump came back from welding.
    Now it‘s Time to finishthe engine.
    Before and after...
    74DD057E-3F4E-4B66-BA46-E77AF94171DA.jpeg 8B656757-5EAC-4247-B6F8-F00A301B7C72.jpeg
    Stay tuned....
  17. #97
    May 2016
    Germany
    288
    63
    Still pushing ...
    After hours of searching I came to the conclusion that someone scrap my blody Oil pickup pipe! So I bought again 2 used pipes to modify them for the Wet sump according Steve´s manual (SBD).
    After cutting I went to an old friend who builds custom bikes. He made two sleves and brazed the pipe together!
    To get a Oil temperature signal from the XE, I used the plug screw from the oil pump. Just bought an VDO sensor in M14x1,5 and cut a thread in the plug...now here we are...
    To get the oil presure signal I bought an original Oil presure pipe for the RS cluster.
    Last job yesterday was to create a battery tray. I used a 3mm thick metal plate, to support the battery tray from below.
    Stay tuned...
  18. #98
    Great progress as usual keep the updates coming.
  19. The Following User Says Thank You to wildo105e For This Useful Post:
  20. #99
    May 2016
    Germany
    288
    63
    New day , new issue, as usual.
    we brazed the oil pickup pipe together. But the angle of the pipe was 5 degrees wrong. My fault.
    To get it to the right angle I screwed both pipes together on a peace of Wood.
    And some new Christmas goodies arived yesterday...
    My Alloy Firewall
    and my Carbon Strut brace
    Nice work !
    Stay tuned...
  21. #100
    May 2016
    Germany
    288
    63
    Just a picture...
    one step forward...3 steps back...
    There is absolutely NO part which I can put at the car from the box! Bloody rework on every single piece!
  22. #101
    Bodger Schobo's Avatar
    Jun 2006
    Germany
    114
    Hi, good work! That will be a nice car when finished. Which gold tone did you use for your bbs centers? Do you have a color code? Looks very close to the original.
    Have a nice Christmas!
    Best Regards
    Lars
  23. #102
    May 2016
    Germany
    288
    63
    Der Lackierer ist im Urlaub. Muss ich anfragen.
  24. #103
    May 2016
    Germany
    288
    63
    Next stop...exhaust. The Tony Law manifold runs straight throug my steering. Time to cut and redesign. 9F11D70C-E31A-47DD-A0CD-624E11709B26.jpeg BF226B65-2048-4CB0-8AE9-AB8D393495E0.jpeg FAA11676-44F4-46FD-AC52-D4DFEE956D24.jpeg 361F3F16-8391-4521-9A92-CC0D83FA89A0.jpeg
    And I spend some Time with the brake Lines...
    6D4B5581-68CF-46FE-B355-0AAE153A1B0C.jpeg A8BC9ABB-E91B-451A-A5E0-3DAF3A1DE2C8.jpeg
    Finaly some easy stuff...
    084BAF17-F289-4EC3-9098-C0609AAF0CCE.jpeg 7AD74E6C-2F18-4EE5-9F38-E196D2D5B60B.jpeg
    On thursday we will weld the new routed pipes together with WIG
  25. #104
    Mechanic flick5848's Avatar
    Jun 2009
    Lancashire
    549
    Shame you have to cup up TLE but I understand you have to. Mine just arrived today to allow me to mock up the engine but mines RHD so can't foresee any issues.
    Keep up the good work. I'm a little behind your progress so I look forward to the updates.
  26. #105
    May 2016
    Germany
    288
    63
    I‘m with you...the First cut in this nice peace of work was the hardest! I called TLE to get some Support for an left hand drive Version it. Nooooooo...
    Before cutting we have done „the paper blow test“ ...tomorrow I will try it again.
    (Put a peace of paper at the to of 3 pipes and blow air in the fourth , If the paper get sucked to the pipes on all four pipes you have a great exhaust...more or less  )
  27. #106
    May 2016
    Germany
    288
    63
    Heater pipes done. A lot of clamps, but with a perfekt routing now, and no touch condition to the coil which is Now located under the throttle bodies.
    BFF43125-7BB0-4ADA-BE9D-EA69E8E3C34E.jpeg. 5AABB14E-4B73-478D-800C-2288698EF8CD.jpeg
    I just need some more space for the small pipe and tube at the rear end.
    Also the Tony Law Exhaust „Dennis Edition“ is finaly welded.
    Next step is the fuel pump, pipes etc.
    Yesterday I ordered a lot of dash06 fittings at Bat Motorsport. The prices are not that bad and they are very good sorted.
    Stay tuned...
  28. #107
    May 2016
    Germany
    288
    63
    Due to some delivery issues for my fuel system parts I started with the electric.
    The new fuse Box will be mounted to the passenger footwell at the A-Pillar. To protect the cables against passenger feets I´d like to use a cable channel out of alloy.
    first mockup done.
    The plastic covers are easy to remove.
    The MBE Box for the Jenvey TB´s is fixed above the fuse box and will be covered from the glovebox.
  29. #108
    May 2016
    Germany
    288
    63
    Some good news for everyone who struggles with too short or damaged clutch or throttle cables.
    My old T9 clutch cable was about 45 cm too short. After some research at google I found a nice page !!!
    The holy grale of cable manufactoring!
    https://www.bowdenzug24.de/en/
    Everything is possible... take a look !
    #bowdencable T9
    #throttlecable
    Cheers Dennis
  30. #109
    May 2016
    Germany
    288
    63
  31. #110
    May 2016
    Germany
    288
    63
    Fusebox cover back from milling
    And I ordered my new gear stick and the handbrake lever handle
    made of carbon.
    22C71D24-D7BC-4355-A266-2CDD64F30922.jpeg 996227AF-09BC-420E-8D07-E066007C2F46.jpeg
    Hopefully my 35mm square cable will be arrive today. So I can start with the electronic distribution!
  32. #111
    Jun 2012
    ireland
    1,158
    great work going on, keep the updates coming!
  33. #112
    May 2016
    Germany
    288
    63
    Thank you! Still pushing hard tio get the engine running! I started with the routing of the cables. Need some new cables, but in total I´m verry happy with it... I closed too much holes in the engine compartment ! Now I need to drill new ones to get the loom to the headlamps again !
    The new position of the fusebox looks good. Just need to coat it satin black.
    The small black box above the battery tray is an additional 100A fuse box. This should protect my interior against the 35mm² cable in case of an accident or whatever
    Also the Carbon handle looks massive...
    On saturday I will finish the engine compartment loom as well and start to wrap it again.
    stay tuned...
  34. #113
    May 2016
    Germany
    288
    63
    ...and the Handbrake...
  35. #114
    May 2016
    Germany
    288
    63
    Yesterday I started crimping the big cables (35mm²) I borrowed a special press plier.
    Together with the black mesh cover and the shrink tube which I ordered from wish, it looks great!
    Each cable will be covered like this. Hopefully this week we can celebrate the first start of my monster!
    Stay tuned...Dennis
  36. #115
    Mar 2011
    Melbourne
    797
    Looking great mate
    Keep up the great work, nearly there
    Matt
  37. #116
    May 2016
    Germany
    288
    63
    Bad news after first run yesterday...
    After few minutes running we found some coolant water dripping out of the Exhaust... After checking the spark plugs we saw that the 3rd. cylinder was showing some water. so we disasembled the exhaust... the tuner who modifiyed the head touched a water chanel at the exhaust side and created a small hole.
  38. #117
    2,660
    268
    Ouch that's going to hurt. Do you think it will take a repair or is the head going to be scrap...?
  39. #118
    May 2016
    Germany
    288
    63
    We still searching the defekt... Looks like a crack. I ordered some special paint to make the crack visible.
  40. #119
    May 2016
    Germany
    288
    63
    Shit Re: My Escort XE Project!
    News... we found the hole in the outlet port of the third cylinder.
    Next step is to contact a specialist who can close this hole again!
  41. #120
    May 2016
    Germany
    288
    63
    Back again. The engine builder told me that the water chanel is rotten from inside due to wrong cooling fluid over the last 10 years.
    Next step...ordering a "new" head
    What should I say...the "low mileage" head came with bent valves...
    Today I will check the head with a leakage test with my old valves...
    Against boring I´ve wraped my exhaust!
