Page 6 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 201 to 240 of 329
Thread: My Escort XE Project!
  1. #201
    May 2016
    Germany
    288
    63
    Re: My Escort XE Project!
    Thanks mate, I found a small company in Germany. They told me that they designed their own Rev counter which they can calibate to whatever you want! V8 engine, V6 Engine, 7000, 12000 UPM, every signal is possible! for just about 250€.
    But due to fckn covid they kicked out the half of their Team. So they can´t fabricate the speedo disk anymore. Thats why I had to do it by myself.
    http://www.wsm.de/
    Never the less you´re right, I should not look at the rev counter! But as you mentioned "attention to detail"
  2. The Following User Says Thank You to skmotorsport For This Useful Post:
  3. #202
    May 2016
    Germany
    288
    63
    Today we start to scan the Cluster bezel with modern 3D technic.
    Now we will start modelling a CAD File out of that scan.
    Stay tuned....
  4. #203
    May 2016
    Germany
    288
    63
    Some more Pictures from the 3D scanning. It took 3 hours.
    And the creating of the CAD model is already finished!
    Have a nice Weekend!
    Stay tuned...Dennis
  5. The Following User Says Thank You to skmotorsport For This Useful Post:
  6. #204
    May 2016
    Germany
    288
    63
    Good morning,
    to protect the finished Car in the garage it was necsesary to search for some heater or dryer. I found a great solution from Trotec, but in the end absolutely over the top an too expensive.
    The best humidity value should be betweet 45% and 55% as shown in the picture below.
    State of the Art is the DH 15 VPR+from Trotec...but very expensive with 2500€
    In the end I found a cheeper solution but never the less with high tech. Klarstein DryFy40. An portable DRyer with WiFy and app for easy access and full controll werever you are.
    At the beginning there was a humidity about 75 -80%. It took just 3 hours to dry it down to 56%
    Now it runs stable with 50% Humidity, which is a quite good number to safe the parts which are stored there before the go back to the car...hopefully soon! The garage have about 27qm.
    65759119_2346392368758485_524757210144702464_n.jpg 65753313_2346392445425144_5362331037730865152_n.jpg
    Stay safe....stay tuned....Dennis
  7. The Following 2 Users Say Thank You to skmotorsport For This Useful Post:
  8. #205
    May 2016
    Germany
    288
    63
    Some Nice weight reducing tips:
    Alternator -1850g :
    Old part 4750g for the Alternator and 500g for the bracket
    New Part 3100g for the alternator (Daihatsu Cuore 60 Amp. Referenznumber OE:2706097202) and 300g for the bracket (Opel 9129426 41519)
    Ignition Coilpack: -600g :
    Old Part 950g/New Part 350g (BOSCHF01R00A025)
    Stay Safte....Stay tuned...
  9. #206
    May 2016
    Germany
    288
    63
    Quote Originally Posted by skmotorsport View Post
    In Saarland , the region were I´m from we have an great Series only for Oldtimer. Saarland Classic Cup. Thats my personal target! First event is on May 13th 2018. Would be great to start there.
    The ECU came from SBD Motorsport. It is an MBE Ecu. the Series is an MBE9A9 with a ready to start engine loom.
    There is also another great event in Belgium this year. For the 50th Birthday of the Escort MK1
    https://www.escort-rally-special.com/english-1/
    Very optimistic at that time!!!four and a half years later and still no visible end...
  10. #207
    Aug 2020
    South East
    235
    326
    Finding the same thing myself.
    Probably about 200 hours into the rebuild now and if you looked in my garage you'd think I've done nothing other than slapped a bit of paint on a few suspension parts!
  11. #208
    May 2016
    Germany
    288
    63
    I filled another checkbox in my to do list:
    The Old Steering boss hub was a bit too big to fit under the Steering column shroud. So I ordered a new Steering boss hub for "Escort MK2"...and what else...Problems!
    The lower end is not long enough to push the turn signal reset ring (dont know the right word) deep enough against the spring. So I decided to create a spacer.
    All good plans start with a drawing...
    followed by a good readable drawing...
    and ended up in a perfect part...
    Now the spacer pushs the reset ring in the right position and the Turn signal can be resetted, and the Column shroud fits like a new one!!
    Stay safe...Stay tuned...Dennis
  12. #209
    May 2016
    Germany
    288
    63
    The rear ashtrays were in a bad condition and he chrom effect is gone. So I decided to Carbonise them...
    Maybe I will, add a chrome edge around the carbon plate with a foil...
  13. #210
    May 2016
    Germany
    288
    63
    Finally my Carbon Plate arrived at saturday. A very thin carbon layer with glue on the rear side. Now it looks really nice!
    Thanks to team-jollify for the great work!
    Stay safe...stay tuned...Dennis
  14. The Following User Says Thank You to skmotorsport For This Useful Post:
  15. #211
    Apr 2013
    S Wales
    233
    433
    If you scan the indicator cancel cam and get it reproduced in aluminium, I think you would sell a lot of them.
  16. The Following User Says Thank You to dt36 For This Useful Post:
  17. #212
    May 2016
    Germany
    288
    63
    I can ask my friend to scan it to create an CAD. I saw some 3D printed parts...but i will do!
    Maybe in aluminium a good business to get some money back which i killed in my Money Pit!
  18. The Following User Says Thank You to skmotorsport For This Useful Post:
  19. #213
    Quote Originally Posted by dt36 View Post
    put me on the list
    More great work here.
  20. The Following User Says Thank You to wildo105e For This Useful Post:
  21. #214
    Apr 2013
    S Wales
    233
    433
    Quote Originally Posted by wildo105e View Post
    put me on the list
    I'll have one too. ��
  22. #215
    Feb 2011
    Caernarfon,North Wales
    180
    29
    put me on the list
    Me too!!
    Great work going on here.....👍👍
    Sent from my Hammer_Energy_18x9 using Tapatalk
  23. #216
    May 2016
    Germany
    288
    63
    Yesterday I blasted my Speedo dials. The new sandblaster Box works perfekt. With very low preasure the didnt bent. I painted them in black, now i have to wait for the stickers from the stickermaker.
    stay safe...stay tuned...Dennis
  24. The Following 2 Users Say Thank You to skmotorsport For This Useful Post:
  25. #217
    May 2016
    Germany
    288
    63
  26. The Following 3 Users Say Thank You to skmotorsport For This Useful Post:
  27. #218
    9,204
    looking good i notice your screwing on the heater bubble rather than welding ? - i was thinking of doing this myself to avoid a possible corrosion trap on the welds.
  28. The Following User Says Thank You to alladdin For This Useful Post:
  29. #219
    May 2016
    Germany
    288
    63
    Thank you alladdin, the only reason for me to doing this, now I can use my carbon bowl and , the best reason, I can paint the whole area an I can dismantle it just for cleaning once a year to check for corrosion...
  30. The Following User Says Thank You to skmotorsport For This Useful Post:
  31. #220
    Spanner Monkey Turbosport Subscriber
    Jan 2012
    Aberdeenshire
    417
    Work of art and will be nice once done
  32. #221
    May 2016
    Germany
    288
    63
    After 5 long Years...painted in Strato silver in a perfect condition!
    First of all....start with a plan!
    After Assembly the brake lines I found some leakages at the firewall at the front brake system. The rear system is ok. So I have to order some parts to fix it!
    With that, I wish you and your families just the best! Stay Safe
    Dennis
  33. #222
    Looking lovely now great to see all the harrd preparation paying off.
  34. The Following User Says Thank You to wildo105e For This Useful Post:
  35. #223
    May 2016
    Germany
    288
    63
    Some more Updates...
    Sound and heat isolation is now in.
    the rear cable loom is finished and I started with my fuse box...
    The washer bottle is back in and electric done
    Time for the marriage
    But in the end I got some bad news with the removable heater bubble/bowl. The bowl is an elementary part of the front structure and it is necsessary to glue it back in (strengten with screws) to make the front stiff again. So hopefully it is not too late and the front is bented like a banana.
  36. #224
    May 2016
    Germany
    288
    63
    and two more pictures ... One with "MY Engine"
    and the fresh rerouted engine loom is now a bit lower, some more space to install a big Airbox!
    Stay safe, stay tuned...Dennis
  37. The Following User Says Thank You to skmotorsport For This Useful Post:
  38. #225
    Oct 2001
    Shropshire
    51
    239
    18
    Looking really good, keep the updates coming it does help me with my project
  39. #226
    May 2016
    Germany
    288
    63
    Fuel Lines and Oil cooling lines finished yesterday..
    Step by step...
    Stay Strong, stay tuned...Dennis
  40. The Following User Says Thank You to skmotorsport For This Useful Post:
  41. #227
    May 2016
    Germany
    288
    63
  42. The Following User Says Thank You to skmotorsport For This Useful Post:
  43. #228
    May 2016
    Germany
    288
    63
    After a good Tip I found out that the brake mastercylinders were sortedin the wrong way. I used the 0.70" for the front and 0.625 for the rear brakes.
    After the change, the rear one is leaky at the piston side for unknown reasons. Now I decidet to change both (front and rear) for new one due to the reason that both are more than 8 Years old.
    I did some more steps with the Instrument panel.
    I decided to use the CUSTOM sticker. This Escort will be an Custom Escort!
  44. #229
    May 2016
    Germany
    288
    63
    New day, new issues.
    Yesterday I assembled te Heater Air duct pipes. At the right side without any Issue.
    But at the left side (my driver side) the Brake Bias Box is right in front of the Air outlet!
    The center console brackets are back in place.
    And I refreshed the chrome at the Valves...
  45. The Following 2 Users Say Thank You to skmotorsport For This Useful Post:
  46. #230
    May 2016
    Germany
    288
    63
    The heater issue is fixed. I used some caravan heater pipes.
    The rear cards came back and they look very nice...
    After protecting the throttle cable i decided to add a bracket to avoid touch condition to the manifold.
    Last job was the assembly of the fuel tank and the fuel sender. The fuel feeding line which goes to the fuel pump needs to be a bit longer
  47. The Following User Says Thank You to skmotorsport For This Useful Post:
  48. #231
    May 2016
    Germany
    288
    63
    Much more steps done...
    Sound and vibration insulation done at the rear side and at the roof.
    For the roof I used the butyl plates.
    For the roof I used the foam with heat isolation
    Also at the underbody along the Exhaust I finished partially the heat isolation
    Next big step was the finishing of the Electric. I had a bloody shortcut at the front lowbeam/parkinglamp just due to fit the bulb cables in the wrong way. I found it after killing roundabout 15 fuses.
    At the Interior I started a first trial to fit the rear side covers..but there is more work to be done. The middle section at the B-Pillar area has a big gap where you can look through.
    Some funny stuff...I bought the headliner three years ago...NOW after hours of trying to fit it alone, my wife asks me to check the shape with an old headliner..
    and...surprise, surprise, I bought a MK1 headliner!
    The right one is now ordered and on its way!
    Last step at saturday...fit and finish for the body panels!
    It took 5 long hours. BUt in the end , I was very happy with the gaps...
    Now I can complete the doors with mechanic, rubbers and so on until the headliner arrives.
    Stay tuned...stay safe...Dennis
  49. #232
    Racer Decade Plus User jimmy2006's Avatar
    Feb 2009
    essex
    1,986
    51
    thats a nice looking car
  50. The Following User Says Thank You to jimmy2006 For This Useful Post:
  51. #233
    Spanner Monkey SimonD's Avatar
    South East Kent
    230
    22
    Coming on leaps and bounds now, the car looks excellent you must be really happy with it
  52. #234
    May 2016
    Germany
    288
    63
    Some updates...
    The left door is well insulated and sounds great when slamed.
    The Zinc plated mechanism is assembled and the new painted door handle is in place.
    The next Picture is the lifehack for all high door handle users! I lost the small fixings were the bajonet fixing from the handle goes through.
    I cut a metalclip and drilled two small 3,5 mm holes to use rivet nuts. Just bend the edges a bit up... and here it is!!
    D31C9908-BCD8-4E49-8652-0BA855C1347A.JPG C5C6AC05-57A6-4E80-81EA-7C78FFCE2191.JPG
    The day ended with assembling of the first windows and the seals. The Brown tinted glass looks awesome with the carbon parts.
    IMG_2581.jpg IMG_2583.jpg+
  53. The Following 3 Users Say Thank You to skmotorsport For This Useful Post:
  54. #235
    Spanner Monkey HOSSMAN's Avatar
    solihull west midlands
    359
    21
    not long till your on the road bet you cant wait
  55. The Following User Says Thank You to HOSSMAN For This Useful Post:
  56. #236
    Pit Crew Decade Plus User onecamohv's Avatar
    Jun 2012
    ireland
    1,158
    looks great Dennis, Keep up the good work and please keep the updates coming!
    wont be long until it is ready for the roads do you need to complete a TUV with this age of car?
  57. #237
    Oct 2001
    Shropshire
    51
    239
    18
    Thanks for the door clip hack
  58. The Following User Says Thank You to prox For This Useful Post:
  59. #238
    May 2016
    Germany
    288
    63
    Thanks Mark, I have two options.
    1st. Drive with a so called Red 07 Number Plate:
    With this plate I´m able to use up to 10 Oldies (Bike and Car) But it is restricted for Events only. Trial and test rides and rides for repair and maintenance.
    2nd. Option is a full blown TÜV certification. If the TÜV register the engine, Exhaust and the brakes, I'll do that. Thats also the reason for me , to work as precise and clean as a can...maybe they can turn a blind eye!
    and a small update from yesterday...the right door is assembled
    There is one BIG Question! The trunk seal is still pushing the lid upwards...in which direction should the small lip at the seal?? Inwards or outwards
  60. #239
    Jun 2012
    ireland
    1,158
    how strict are the police on using the red plate? how can they prove you are not on a test drive? going to work perhaps or..?
  61. #240
    Feb 2009
    essex
    1,986
    51
    Attachment 86503 Attachment 86504
    Attachment 86505
    i would say out
  62. The Following User Says Thank You to jimmy2006 For This Useful Post:
