mk1 escort cossy powered
evening all
what is considred to be a suitable set up for rear end suspension, 4 link heavy duty??, watts linkage??, ill only be using for road and maybe the odd sprint
cheers
Re: mk1 escort cossy powered
should have added car has rear tubs and turreted and will be fitted with an Atlas axle and coilovers
you've pretty much got 2 choices of 4 link, short and long, personally for that set up id go for a heavy duty wide box long 4 link and a watts
set up.
Hi thanks for the reply, I thought I may need a heavy duty set up is burtons 4 link a good one to buy do you know?
cheers
