32/36 zetec problems
Hi have a 32/36 running on a zetec engine. It idles and starts easily but will then idle rough. Touch the throttle and it dies. If I can feather the throttle to build up the revs I it will misfire like mad until around 2500rpm but then it will clear and run fine. The carb has done under 500 miles and was previously running on a 2.0 pinto. I've ran one before with the same jets that were used on a pinto as have many others with no issues. Any help would be hugely helpful as I'm near the end of my tether with it now and will end up flogging it and regretting it! Cheers
Sounds like air leak. Check all fittings and gaskets. 😎
