Atlas ZF LSD Working Correctly?
I've got a Locost kit car with a 300bhp ca18det engine in. The car has an atlas axle at the back with a 'capri' LSD in (as far as I'm aware entirely standard).
Whilst the car does push on OK, under hard cornering when the car comes on boost you can tell that power isn't going to both wheels (usually it goes to the passenger wheel, i.e. the un-weighted one).
Is there anyway to test if the LSD is working correctly with the axle in the car/wheels off the ground etc?
Re: Atlas ZF LSD Working Correctly?
wheels of the ground, turn the propshaft and tell us how the wheels are turning
Its a old lsd thats lost some of its preload and probably needs a new plate kit
