Results 1 to 9 of 9
Thread: Mk1 Wiring Clarification
    Oct 2012
    Telford
    33
    137
    If anyones able to confirm my reading on what the wires do below that would be great.
    Click image for larger version Name:	IMG_2092_edited.jpeg Views:	116 Size:	84.2 KB ID:	80005
    I believe this is just a ground wire, however I'm not sure what the plastic mounting pieces purpose is for though?
    Click image for larger version Name:	IMG_2094_edited.jpg Views:	116 Size:	61.4 KB ID:	80004
    Pretty sure this is the wires used for hooking up a radio (so is just switched ignition).
    Mk1 Escort 1.3 XFlow Turbo - http://bytesandbolts.com/tag/mk1-escort/
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Re: Mk1 Wiring Clarification
    The wire in top pic is as you say a switched accessory/radio wire.
    bottom pic.
    look in the part of the loom where that black wire comes from and see if there's another one which has a male bullet connector on the end.
    on my car these two black wires go to a white wire which is looped around the back of the rev counter.
    pic attached.
    Jul 2011
    herts
    502
    Oops. I got your pics the other way round!
    Jul 2011
    herts
    502
    The brown and white wire is connected the same on mine too. Not a clue what is does though!
    Oct 2012
    Telford
    33
    137
    Yeah I think the brown is just a ground, but don't know why Ford decided to use that plastic riveted thing.
    Spanner Monkey Tony B.'s Avatar
    Mar 2007
    Nr Chichester, West Sussex
    74
    331
    23
    Bytes, in your first pic, I am fairly sure that "plastic bit" should be the resistor for the slow speed of the two speed heater motor. It does go to earth but after passing through the resistor. There should be more to it, on mine there is a wound coil mounted on a metal plate.
    In your second picture, the grey / yellow wires do look like wires that are live when the key is in the "Acc" position, to confirm, is the wire feeding them in the black part of the plug yellow ?.
    Oct 2012
    Telford
    33
    137
    Quote Originally Posted by Tony B. View Post
    Okay that makes more sense as the plastic bit actually has a purpose then. The 2 speed motor works fine and that portion of the wiring harness is still stock AFAIK. It's a late 74' escort so perhaps Ford changed how they do the resistor. Perhaps post a pic for comparison if you can.
    4,889
    Ford uses brown as a ground-wire.
    Brown with a tracer (in this case) white will never be a ground-wire.
    Oct 2012
    Telford
    33
    137
    After some digging I can confirm the brown wire w/ white trace is the low speed return wire for the heater blower, the plastic housing at the ground point is a resistor to reduce motor speed.
    Detailed in the diagram below.
    Click image for larger version Name:	motor_blower.jpg Views:	64 Size:	29.4 KB ID:	81429
    Click image for larger version Name:	Mk1 Escort Wiring Legend - 1973 Onwards; Saloon, Estate, XL, Sport & GT.jpg Views:	66 Size:	142.9 KB ID:	81430
Tags for this Thread
