Results 1 to 16 of 16
Thread: Turbo V6 Rad keeps boiling
    Pit Crew Decade Plus User rich_mkii_rs2000's Avatar
    Feb 2003
    Haverhill
    1,145
    19
    Right
    My bloody capri keeps boiling the water in the rad. Like tonight after about 10 mins of it ticking over with the bonnet up and the cooling fan switched on i parked it up, turned it off and could hear the water boiling in the rad.
    Its always runs hot and since its engine rebuild i have now changed
    Waterpump
    thermostat (tried several)
    radiator
    electric fan
    The heater runs hot so that is not blocking up.
    Have also tried water wetter, lifted the rear of the bonnet and fitted some aluminium air scops in the front to improve airflow.
    Yet none of this seems to have made a noticable bit of difference.
    (Have fitted an aftermarket electrical water temp gauge which reads at just under 100 when the car has "warmed up" but im suspect about its accuracy)
    What the f*ck is wrong with this car!!!!!!!!!!
    Nov 2004
    Sweden
    1,174
    Re: Turbo V6 Rad keeps boiling
    Is it a 2.8 turbo?
    We had great problems with the twin turbo 2.8 Capri, until we bought a separate thermostat housing and put it on the top hose (just removed the thermostat in the stock location).
    IMO the 2.8 cooling system is flawed to start with, having the thermostat in the "colder" side of the cooling system.
    Gustaf
    Feb 2003
    Haverhill
    1,145
    19
    yes it is a 2.8 turbo, thanks for the responce
    Feb 2003
    Haverhill
    1,145
    19
    just seen this on the rover K series emgine, sounds similar problem
    ROVER K SERIES
    Remote Thermostat Housing
    The K series engines have the thermostat mounted in the flow of the coolant as it enters the engine, as opposed to the more traditional positioning in the flow of coolant leaving the engine.
    With the thermostat positioned on the inlet side of the coolant flow the engine will tend to heat up quickly and maintain a fairly high running temperature.
    This happens because as the thermostat opens low temperature coolant from the radiator runs through the thermostat cooling it, and causing it to close. In this way the thermostat is reacting as much to the temperature of the radiator as it is to the temperature of the engine.
    Although this arrangement has advantages for a standard road car it can cause problems for a more developed motorsport engine, especially if fitted in a rear engine sportscar like the Elise or MGF.
    Removing the original thermostat, and fitting our thermostat housing in the top hose, relocates the thermostat into the flow of high temperature coolant coming from the engine. This means that the thermostat, and thus the flow of coolant, is being controlled in response to engine temperature, as it should be.
    Our thermostat housing is available with a range of pre-fitted thermostats to give opening temperatures more suited for competition
    QED MotorSport Ltd
    Feb 2003
    Haverhill
    1,145
    19
    Mechanic sillymonkey's Avatar
    Sep 2006
    cumbria.
    930
    have you tryed a new rad cap? might help m8.
    25,175
    297
    does it do it only after you have switched off?
    when you switch off initally the water temp will RISE as the coolant is no longer circulating and its not uncommon to get localised boiling, that will happen in the cylinderheads but you will probably hear in in the rad.
    are you using/loosing water?
    i would fit a new high pressure rad cap in the range of 15-18lb and see what happens, i cant remember the exact figure with high pressure cap like that cap the water wont boil until about 120 degrees
    Feb 2003
    Haverhill
    1,145
    19
    am going to order a stant one next week
    it occasionally pushes water out the expansion tank but not a lot. Havent had to top it up really.
    cheers
    richard
    Jul 2004
    Reading
    1,517
    Are you using the standard grill? Can air get to and away from the radiator? Do you have bonnet vents? If not adjust the bonnet slightly so air can escape windshield end.
    Zetec Mk 1 Escort
    Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
    Mk 1 XR4i
    Mk 3a Fiesta Si
    www.zetecescorts.bravehost.com
    Nov 2004
    Sweden
    1,174
    We tried higher pressure rad caps, we had plenty of air but fitting the external thermostat in the top hose solved everything and after that we never had any problems at all. It is an easy fix and I cannot recommend it enough.
    I say do it before you blow headgaskets...
    Gustaf
    Feb 2003
    Haverhill
    1,145
    19
    do you have any pics of your themostat housing.
    what did you use to make it
    thanks
    richard
    Feb 2003
    Haverhill
    1,145
    19
    have seen these housings off a freelander. will find out what diameter they are
    Nov 2004
    Sweden
    1,174
    Ours was just a custom housing, bought locally. No pics, sorry, but the Freelander part looks OK.
    Gustaf
    Feb 2003
    Haverhill
    1,145
    19
    would this be a better option, and where would i feed the bypass to?
    THERMOSTAT BY-PASS 78 deg.
    A great solution for unstable engine temperatures. This stat will allow circulation within the engine until normal temp. is reached. It then opens to feed the radiator. 32mm & 38mm spigots.
    Nov 2004
    Sweden
    1,174
    Yep, that's the one. I'm trying to remember how we really connected it, the bypass should probably go to the lower radiator hose to allow circulation when the water is cold.
    Need too double-think a bit about that though...
    Gustaf
    Feb 2003
    Haverhill
    1,145
    19
    I guess i would put a 'T' piece into the bottom hose and feed the bypass to it.
Similar Threads
  1. Replies: 0
    Last Post: 01-09-2006, 16:57
  2. Replies: 1
    Last Post: 09-07-2006, 22:42
  3. Replies: 1
    Last Post: 29-04-2006, 18:52
  4. zetec turbo pours white smoke, headgasket or turbo ?
    By buncey in forum The Technical Section
    Last Post: 25-03-2006, 19:32
  5. Ford turbo diesel engine, turbo, gear box
    By Lee H in forum Parts For Sale
    Last Post: 18-05-2005, 02:08
