Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 40 of 276
Thread: Some pics of todays work
    May 2006
    397
    12
    Beautiful weather over in Belgium, 25 degrees, so decided to give sandblasting a go.
    Not quite convinced bout this blasting, dirty work, lots of cleaning afterwards, and seals dont blast off that easily.
    Gonna finish the rest with the trusty grinder.
    Here are some pics (check out the massive filler job ...)
    Tomorrow i will put some primer on the underside. Still need to figure out the mixture of primer and hardener. No clue so far
    Dec 2003
    London
    12,424
    26
    Re: Some pics of todays work
    That looks a lovely clean shell underneath
    Good luck with the project
    Oct 2005
    birminum
    47
    370
    Most 2k primers mix 4:1 primer to hardener, some mix 5:1 some even 3:1
    It always tells you the mix on the back of the tin unless you are using crap primer then it might not
    Mechanic DanR's Avatar
    Jan 2005
    New York - USA
    719
    looks very tidy underneath! good luck
    May 2006
    397
    12
    put some primer on today. todo is rear arches and front arches with wire brush. then the welding starts
    Nov 2004
    Sunny Essex
    5,101
    100
    Thats a stunning shell you have there
    May 2006
    397
    12
    does anyone know the function of the little plates in the red circles ? I have some rust holes in them, so will need to repair it. Looks like some strengthening for the chassis rail ?
    Nov 2004
    Sunny Essex
    5,101
    100
    Jacking points?
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    31
    18,258
    81
    Nope the jacking points are in the front of the spring hanger you can just see them in the pic with the strengtheners that run out to the outer sill
    It might be for when the cars in the mot/repair garage on a ramp though, dont know if those types of ramp were about when the escorts were born!?! But theres that section at the rear and at the front just where the front rail drops down and meets the centre section its double skinned too, maybe even triple skinned?
    The section hes talking about is the bit that rots on most if not all mk1 & 2s, its the section where the centre rail and the rear rail join and overlap so is double skinned, water gets in between the skins and they rot to fook mine are gone and have been plated badly so im going to be doing them soon but i will probably just let in a single piece of thicker steel, its got to be stronger than whats on it at the moment which is literally a cover to please the mot man!
    To repair yours, which dont look too bad, either weld up the holes or if its worse than it looks, start by chopping off the first outer skin and try to leave the one under in tact so you have something strong to weld to if its rust free, then just knock up a plate to fill the outer skin
    Oct 2004
    get me on my beeper,beeper
    15,804
    35
    looks a nice shell that
    May 2006
    397
    12
    Decided to work on the chassis rail today. Left and right showed rotten pieces, so the grinding starts.
    The inner metal plate was also rusted, so had to replace that too. Both sides. Pretty satisfied with my work today, muuch better the sandblasting horror last weekend
    May 2006
    397
    12
    here you can see the result of both sides done.
    O and i also used some anti-rust paint in between the 2 layers of metal, its not shown in the pics.
    Remember the camper......? Decade Plus User
    mk1matt's Avatar
    essex
    9,423
    70
    Nice work dosn't look like theres much to do on that shell
    west kingsdown kent
    30
    4,250
    now that is a nice shell.looks very solid.nice work on the rails.
    tommy 2000
    May 2006
    397
    12
    Tought i would continue to put some pics here of my restauration. Hope the pics work, its a direct copy of my weblog. Looks good here.
    I first cut out the gearlever hole because i want to re-use that
    Then mark the new tunnel and mark a safety line a bit inwards. There i will cut the first big hole.
    Old versus new
    New tunnel tacked in place
    Pretty good penetration of the weld. I will trim the rest of the chassis plate thats too much under the gearbox tunnel so we have a clean finish. But thats for later, after the welding is done.
    Did some welding on the left and right side. Have to complete the welding in the top area of the tunnel, ooo leave the beast for last …
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Nice work
    May 2006
    397
    12
    finished the welding of the gearbox tunnel.
    Put some seam filler on it
    Cleaned up the underside. Need to finish up the support brace.
    Do i need to cut the red section out so i can fit the sierra gearbox ? I've seen several versions on this.
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Quote Originally Posted by filipvdv View Post
    Mine fitted by cutting using the back of the oval cutout as a line.
    Your red line is a little bit more than necessary going by how mine was.
  19. #19
    May 2006
    397
    12
    Finished cleaning up the support brace following Dave_Robert’s tip. Tried tyding the seam filler but this is quite resistant stuff, so only gave it a little brush with the wire-brush.
    Also applied a coating of primer for protection during the build up.
    After all the work i wanted to clean my paint gun. so put in some paint cleaning stuff and wanted to start spraying the gun clean. Didnt screw on the lid… I took the paint gun of the work bench, but it was stuck. So i pulled harder, and here we go, the paint gun came loose, but the cleaning liquid (thinner) flew out of the paint gun reservoir, straight into my face and into my eye ! You should know, i’m also quite allergic to this stuff. I dropped all i had in my hands, sprinted into the house to find the bathroom. My eye was burning like hell ! Washed my face and eyes with lots and lots of water. Then hit the shower immediately to scrob it all off again. Put on some burning cream, took some eye drops and took a anti-allergy pill. It looks ok now, just a little itchy. Got lucky there i guess. Anyway, here are some pics.
  20. #20
    May 2006
    397
    12
    time for an update
    cleanup the inner left wheel arch today. Imagine a grinder, dril machine, with about 10 sorts of grinding pads, and lots of very hard to reach corners. Took me a whopping 4 hours to get the arch clean
    o yeah, the goal to clean the arches, is to remove the old and cracked sealing. From time to time you couldnt even guess there was rust under there.
    hereís some pics
    You can clearly see the easy parts are done, and some pain in the ass parts to be done
    After I guess 1,5 hours more work on these tiny sports. looks clean dough
    And le piece the resistance, its all worth it when it looks shiny again. sprayed first layer of primer. Still 2 more togo.
  21. #21
    Oct 2004
    15,804
    35
    very nice m8
  22. #22
    May 2006
    397
    12
    cleaned up the right inner arch and sprayed first layer of primer over it.
    Things are starting to look clean again. Finally, cause all this time grinding isnt quite motivating
    Also bought myself a 3M speedglas welding mask. Lots better then my previous ebay one
    Next job, the rear arches. Compared to the fronts, these will be lots easier to clean, lot less hard to reach corners.
  23. #23
    May 2006
    397
    12
    Made the pics work
  24. #24
    west kingsdown kent
    30
    4,250
    much better with the pics that sizeall the work looks very well done so far
    tommy 2000
  25. #25
    May 2006
    397
    12
    brought the rear left arch back to bare metal and covered it with first layer of primer. Decided to give the rest of the car a second layer of primer as well.
  26. #26
    Jul 2005
    telford
    184
    i carnt believe how solid that car is
    nice project mate
  27. #27
    May 2006
    397
    12
    thx, hoping to keep it that way
    A little Q just popped up.
    When spraying a second or third layer of primer. Is it possible to change the colour a bit so you can clearly see you got it all covered ?
    Or am i being a freaking amateur now
    Think 3 layers of primer will do. Then i layer of those bubble paint that prevents water sticking. Then 1 or 2 white layers as a finish for the bottom.
  28. #28
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    13,304
    77
    Looks lovely mate
  29. #29
    Bodger fezzajsy's Avatar
    Aug 2006
    jeRSey
    144
    looking awesome
  30. #30
    May 2006
    397
    12
    finished cleaning up the rear right arch, brought it back to bare metal and that was the last piece of the underside !!
    what a work is has been, but so rewarding when you see a nice and clean underside of the car.
    Sprayed another layer of primer on the car. Decided to add a bit of green colour to the grey primer. This way i could see if i had it all covered.
    Prouved to be very handy.
    Pics are not very good, getting dark, will make some decent ones tomorrow.
    Dont ask me why those holes are drilled. Still thinking bout the best way to fit wider arches.
  31. #31
    Dan's Avatar
    Aug 2006
    north london
    36
    5,765
    i wish the top of my car was that clean, never mind the underside... impressive stuff, keep it up
  32. #32
    mk1matt's Avatar
    essex
    9,423
    70
    Very nice
  33. #33
    May 2007
    Up North
    1,774
    88
    looks clean enough to eat me dinner off .Lots of hard work i see and a lovely bloody garage very nice .
  34. #34
    May 2006
    397
    12
    There were 2 little bad spots that needed repairing. Cut out a little section and replaced with fresh metal.
    Bought myself a stonechip paint gun. The tube you see connected, didnt work at all, so did it all with just the nozzle.
    So off we go with stonechipping. Never did this, but appeared to be pretty straightforward. I used 2 tubes of the ones pictures below. This was just enought. Maybe iíll add some more, donno yet.
    Next up, 2 final coats of white !!
  35. #35
    Pit Crew Decade Plus User TepiTheFinn's Avatar
    Jan 2003
    Finland
    1,318
    i would say that gun is not planned for the stonechip. it's more like for a wax oil...
    my stonechip gun has a different type of nozzle
    Cheers, Tepi
  36. #36
    Feb 2007
    cardiff
    432
    The gun is correct for stonechip but the flexible nozzle is only for applying waxoyl or other cavity wax.
    The correct nozzle is a wide bore tube about 75mm long
  37. #37
    Apr 2003
    Liverpool
    440
    good work getting done there on a very good shell.
  38. #38
    Oct 2002
    London
    31
    18,258
    81
    Looking good
    Just a few questions:
    Is that a thick enough coat (hard to see from the pics), i was thinking of coating it thick like ford did to the sill, wheel tub and chassis rail areas on mine?
    How big is that can is it 1 litre??
    Otherwise keep at it
  39. #39
    May 2006
    397
    12
    the can is 1 litre. I used 2 of them. The shop told me this would easily be enough for the whole car.
    went over to see the car today and decided i'm gonna put some extra stonechip on it. I guess 2-4 cans.
    The current stonechip layer is just too thin. Thx 4 pointing it out. You can still see a shine of the greenish primer through the stonechip.
    I'm guessing i should have a thick layer of stonechip, where all of the primer is sufficiently covered.
    Here's a pic showing it needs some extra coating
  40. #40
    Oct 2002
    London
    31
    18,258
    81
    No worries mate, im just trying to work out how many cans i need to get before i do mine! I see what you mean about the primer showing through. My theory is that the thicker it is the less likely it is to crack over time so shouldnt let in too much moisture although where i have been bare metalling the thin stuff covers well, its the seams that seem to suffer the most!
    So you think about 5litres should do it then?
Similar Threads
  1. A Few pics of Carl's MK1 as work progresses
    By 2quick4u in forum Restorations and Projects
    Last Post: 13-04-2007, 16:54
  2. Its a work of art (sump pics)
    By davejupp in forum General Car Banter
    Last Post: 31-03-2007, 16:19
  3. Any pics from todays meet?
    By DaveWRC in forum Message Centre
    Last Post: 04-04-2006, 15:52
  4. few pics from todays driftin
    By popuptoaster in forum Message Centre
    Last Post: 20-04-2004, 23:33
  5. Todays Bad Joke
    By Threedoorboy in forum Jokes
    Last Post: 08-08-2003, 16:55
