Results 1 to 30 of 30
Thread: Where to buy a pinto turbo manifold????
    Sep 2016
    Dorking
    74
    18
    Does anyone know where to buy a new pinto turbo manifold from in the UK? Cheers
    Mar 2012
    Shropshire
    407
    Re: Where to buy a pinto turbo manifold????
    You can't buy them off the shelf, you have to either make it or get someone to make you one or buy a second hand one.
    Sep 2016
    Dorking
    74
    18
    OK, cheers. What about importing one then? Aren't pinto turbos big in places like Sweden,Hungary, Malta etc????
    Mar 2012
    Shropshire
    407
    They all make them or have them made from what I could find. Shouldn't be too difficult to find someone to make one for you.
    Nov 2004
    Sweden
    1,167
    At least here in Sweden it is all DIY, the volumes are too small to have someone make them and put on the shelf, and everybody has their own ideas on fitment etc.
    Most people seem to know someone with a water or laser cutter that can make the flanges, if not, businesses like KL Racing do them: https://shop.klracing.se/sv/artiklar...into-10mm.html
    They can also sell the bends and the turbo flange.
    Regards
    Gustaf
  6. The Following User Says Thank You to therealpinto For This Useful Post:
  7. #6
    Sep 2016
    Dorking
    74
    18
    Cheers Gustaf ��
  8. #7
    Oct 2013
    Suffolk
    47
    194
    Im going to make mine
    Sx200 stainless manifold (£125 of eBay)
    Remove the flange and tig anew one on ( £50 for the flange )
    Hope this helps
  9. The Following User Says Thank You to Lacey For This Useful Post:
  10. #8
    Sep 2016
    Dorking
    74
    18
    How much would people expect to pay for one to be made by an engineer? For a simple log type manifold it's looking like £100-150 just for bends and flanges.
  11. #9
    Mar 2012
    2,118
    Any easy way of building a turbo manifold starting from a Sierra collector and an old Turbo exhaust scroll. The last one has high nickel and weld very well with nickel rods.
    Turbo very short agains engine, can fit Escort bay.
    Attached Thumbnails Attached Thumbnails P6060111 kopie.JPG‎
    P6060113 kopie.JPG‎
  12. The Following User Says Thank You to Dyno For This Useful Post:
  13. #10
    Mar 2012
    Shropshire
    407
    Mine cost me £175 total. I bought and supplied the flanges and my local shop supplied the bends and made the manifold.
  14. #11
    Mar 2012
    2,118
    An other way of building a turbo manifold
    Attached Thumbnails Attached Thumbnails P5300062 kopie.JPG‎
    P5310074.JPG‎
    P8080204 kopie.JPG‎
  15. The Following User Says Thank You to Dyno For This Useful Post:
  16. #12
    Sep 2016
    Dorking
    74
    18
    Have you got a pic of your manifold and do you know what material they used? Cheers
  17. #13
    Sep 2016
    Dorking
    74
    18
  18. #14
    Mar 2012
    2,118
    Do you mean my exhaust manifold as in the picture? I was using 4 mm mild steel laser cut. Nothing special. The good thing about mild steel is, it does flex a ver little and less cracks in use as with Stainless Steel.
  19. #15
    Mar 2012
    Shropshire
    407
    This is mine. It does the job for what I need.
  20. The Following User Says Thank You to theduck For This Useful Post:
  21. #16
    Sep 2016
    Dorking
    74
    18
    Cheers mate, that's perfect. I did wonder how you got it built so cheap! If it's being wrapped or your on a budget it's fine. Like you say, most use stainless.
  22. #17
    Mar 2012
    2,118
    Don't use SS, it cracks, and always will. Mild steel is what is needed, thick wall is important. The good thing about this manifold is, easy to build and easy to fix into a milling machine to grind it nice flat. Believe me trying to grind flange flat with a tubular manifold, forget it or must have flanges in the same direction.
    I use 15 mm for engine and turbo flange.
  23. #18
    Mar 2012
    2,118
    PS, still got one or 2 sets of these base plates.
  24. #19
    Quote Originally Posted by Dyno View Post
    is that still the case 5 years on?
  25. #20
    Mechanic runoutofrigos's Avatar
    Aug 2006
    North London
    651
    Got something in mind there, Graham?
    Simon
  26. #21
    Mar 2012
    2,118
    I still got the complete manifold but I should also have plates somewhere and if not, I can have the reproduced. There was a small offset in length but easy to correct and about 10-15 pictures, step by step how to build it up
  27. #22
    3,241
    Come on Dyno - show more pictures, step by steps are always interesting
  28. #23
    Quote Originally Posted by runoutofrigos View Post
    Simon
    maybe, problem is 3 project cars and numerous engine/carb projects im already getting to old to think i will ever catch up/finish them
  29. #24
    Aug 2006
    North London
    651
    Hmmm, that sounds familiar.....
    Simon
  30. #25
    Mar 2012
    2,118
    Need to make them all smaller before I can post them here. Need to find an other way, maybe a link to my fb or any other options?
  31. #26
    3,241
    The following are the top five free places to upload your photos.
    Imgur: Easiest way to share images online. ... (heard of this one - seems popular)
    Behance: Share and find inspiration on this photo website. ... (new one to me?)
    ImageShack: A well-designed and free photo sharing site. ... (heard of this one also - maybe not as popular?)
  32. #27
    Mar 2012
    2,118
    Will see what is possible, something for over night, when I stop working
  33. #28
    Mar 2012
    2,118
    Short photo list of how I made it. You can bent the end and bring the turbo flange under and angle if needed. Does make machining more difficult
    Attached Thumbnails Attached Thumbnails P5300064 kopie.JPG‎
    P5300067 kopie.JPG‎
    P5300068 kopie.JPG‎
    P5310071 kopie 2.JPG‎
    P5310075 kopie.JPG‎
    P5310083 kopie.JPG‎
  34. #29
    3,241
    Good series of photos and looks bloody solid! The head flanges make it - water jet cut? Are they individual pattern or 'one size fits all' ? I guess a simplification would be a flat single plate, drilled to suit then ground flat but wouldn't look as good!
  35. #30
    Mar 2012
    2,118
    They both use waterjet (and I think it was done this way) as lazer jet. It is one fit all as you can see the double drilling on the bottom side. N° cylinder has a different setting of bolts.
