Results 1 to 4 of 4
Thread: Duratec blocks
    Spanner Monkey KENNETH's Avatar
    Feb 2007
    CORK, IRELAND
    230
    10
    Duratec blocks
    I'm fitting a Duratec to one of my escorts
    But the 2.0 is hard to find in Ireland so I have a 1.8 block and head as there is plenty of them around
    Can I use a 1.8 as a dummy to fabricate everything while I continue looking for a 2.0
    Basically are the 1.8 & 2.0 externally the same
    I'll eventually probably have buy a ST150 engine in the UK but are these better than a standard 2.0 engine
    May 2014
    North Wales
    85
    Duratec blocks
    I have a duratec block spare. Came out of an st150 that had done 63k miles
    Sent from my iPad using Tapatalk
    Sep 2010
    kent
    227
    Re: Duratec blocks
    The blocks are identical externally.
  4. The Following User Says Thank You to itsawindupuk For This Useful Post:
  5. #4
    Feb 2007
    CORK, IRELAND
    230
    10
    Re: Duratec blocks
    Are the inlet and exhaust ports the same size and position too
