Results 1 to 2 of 2
Thread: Roof swap
    Jun 2009
    greece
    64
    Roof swap
    Hi,does anyone knows if the A pillars of a 4 door escort mk2 are the same as the 2 door? i have a 2 door mk2 with very damage a pillars,roof and gutters, and i have bought a donor roof with the a pillars from a 4 door and the question is can i swap the 4 door roof with the a pillars and the gutters on the 2door? from the 4 door roof i have keptonly the front part of the box frame with the a pillars and the gutters...
    if the a pillars are the same maybe i can fit the 4 door roof on the car after i cut the pillars and cut the inside part of the box frame,just to bent it a little and spot weld the roof from inside?
    Re: Roof swap
    Should be the same - the windscreen is the same and door profile at the front looks the same. 2-door doors are just longer than the front door of a 4-door.
