looks good tell us more
Yes looks fantastic
Tell us more, and shut gaz up once and for all
How does it do in rallying, positions etc?
The car is Steve Bannisters new one. Steve is one of the fastest Escort drivers and is great fun to watch!
The following info is taken off the Britishrally forum and the spec I believe is as follows:-
2.3 Jondel Duratec 299.99r BHP through a 5speed Tractive sequential to an Atlas axle on Proflex coilovers F&R. Still on 13" wheels but thats up for discussion after yesterday, a very 21st century thing a "Lata Dogger" showed he'd been using 8968rpm at one point.
Must mention Kev Theaker of Ralloy who has had so much input in to getting Edith up and running, it soon focused his concentration when running her around bedding in he found you could spin the wheels in 5th !
She was just a prepared(not painted) shell when Steve sold Elsie 3months ago and I know he's burnt a lot of midnight oil since then. Take a good look around her on the Reivers if you get the chance.
There were only 2 small issues yesterday,once sorted it was tyres and fuel,adjust ride heights/damper settings after she settled in. Not bad straight out of the box and Steves first ever drive, the only time he sat in previously was for the seat fitting.
Steve was concerned because the Tractor has a sequential box where the gear lever is pushed forward to change up so he had to remember he wasn't driving that..!!!!!!!!!
The first Duratec I have seen with a cam belt.
I did here that Mountune were developing a cam belt kit, because the timing chains stretch and the tensioners fail if rev'd over 8000rpm for long periods of time.
Looks like Jondel beat them to it!
ive seen steve in action in this car a few events,he is quick as fook,sure he won the 1st r.a.c. rally a couple of years back in the open class.excellent to watch tho
Looks like Steve & his new car, Lady Edith, were having a good run on the Jim Clark Memorial Rally but seem to have disappeared from the results...................
Wasn't able to get to the JCMR, results show steve retired at SF17 Blackadder 2 "Mechanical"
See below, he did not appear to be trying as hard as he usually does.
What about the noise from Andy Horne's DAM 4100???
http://www.youtube.com/watch?v=cwivtF-cQxE&NR=1
