94 FD3S Mazda RX7.
Engine:
Rebuilt knightsport streetport 13b, ported oil pump gallery
crank thermo pellet delete
Port matched Upper and lower inlet manifolds
Double throttle removed.
Wax pellet removed.
Greddy elbow
Gt35r turbo, HKS tubular manifold, HKS 50mm wastegate with new diaphragm.
3" downpipe, 4" 2 box system, downpipe heat wrapped
550 primary, 1680 secondary, DM fuel rail, fuel lab reg, 044 pump, baffle tank. All new but cleaned 550s.
Paddled and sintered ACT clutch brand new
Sump brace, gearbox and diff braces all new
Solid engine mounts and diff mounts.
OMP blanked, simplified wiring loom, relocated coils.
Custom v mount rad and intercooler 3" boost pipes.
Custom AST and coolant lines
Silicon hoses throughout.
AN6 fuel lines throughout.
Twin oil coolers as factory
New clutch slave and rebuilt master
Apexi power fc ecu including commander mapped recently by Engine Tuner in Plymouth.
Running gear:
Fully poly-bushed front and rear.
Rose joint rear traction arms and toe links
Tein height, preload and damping Coilovers in refurbed condition.
ARC ARB's with upgraded mounting support brace.
Standard good condition 5 speed gearbox
Short shifter with delrin knob
2 way plate diff
Evo6 brembo 4 pot front calipers, scooby widetrack 326mm discs
RZ bigger rear RX7 brakes
Braided brake lines throughout and clutch line.
Hydro handbrake
Wilwood Bias valve
Advan model 6 wheels 17x8 and 17x9 recently painted gloss white with continental and yoky tyres in good cond.
Body;
Custom cages weld in multi point
Painted ford diamond white inside and out.
Lowered drivers floor pan so anyone over 5ft can fit with a helmet with plenty of room. Plenty of adjustment to move the seat forward too.
Seam welded chassis
Stone chipped underneath
Heated front and rear screens
Genuine 99 front end, splitter, lights and crash bar.
Early rear bumper
Fully stripped inside as you'd imagine
No heater matrix or motor
Dash is light skin only
Clocks all work.
Quick release boss
Deep dish wheel
Custom large alloy battery box in boot
Relocated battery with E36 M3 battery cable!
Sparco bucket drivers seat, standard passenger altho i have a matching pair of buckets with FD mounts
Will have harnesses different to photo.
Most parts are brand new, cleaned or refurbished recently. Engine has just had a total overhall using a comprehesive atkins rotary kit, all proper parts cleaner washed and dried and inspected internals. I am currently sorting out a compression test to back up the engine condition.
Makes 476bhp at 1.1 bar. Could make plenty more with extra boost and maybe additionally water meth.
MOT'd and fully road legal.
An excellent base ready for a livery or aero package to suit taste and requirements.
Located in Plymouth, Devon.
£13500 ono.
Please contact me (Danny) on 07793776227 as I'm not on here everyday.
