Results 1 to 28 of 28
Thread: Omex, Motec or other?
    I support TS Decade Plus User
    Quarterless's Avatar
    Apr 2004
    Essex
    1,796
    17
    Post Omex, Motec or other?
    Just been informed Omex ecu does the same as Motec one but is cheaper. I want one that is able to run 8 injectors for NA and turbo use with as many useful extras for the best price. Whats best?
    My band: http://www.myspace.com/sanswilfred
    For Sale: http://www.turbosport.co.uk/showthread.php?goto=newpost&t=126514, My items for sale on E-bay,
    Wanted: T5 gearbox, Tremec TKO 600, PACE XE Dry Sump, Tilton floor mount pedal box, Large BMW LSD's 3.5:1 - 5:1, 2.2-2.4ltr petrol Frontera/GM engines.
    Mar 2004
    Barking Essex
    9,873
    249
    Re: Omex, Motec or other?
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
    23,139
    226
    i dont knwo about the never omex units but the older ones had very few features i know the one on my m8's alfa will drive a tacho, or a fuel pump relay but not both!!
    i would go for an emerald myself apart from the usual it will also run 4 or 8 injectors switched in stages or symataniously,
    it can control boost pressure,
    can operate EGT in closed loop
    has the facility to have 3 different maps, which is very handy if you run more than 1 type of fuel or want a wet map, a normal map and a silly high power map
    Spanner Monkey tarmac terriost's Avatar
    Aug 2005
    truro cornwall
    33
    467
    dta are pretty good
    have heared good things about omex and motec ecu's
    thing omex is cheaper one i thought
    mrk 2 mondeo ghia saloon
    17" tsw reflexs bomz kit
    fast road cams/obx pulleys
    drop 30mm eibach springs mongoose catback exhaust
    4.1 ceramic coat exhaust manifold
    custom down pipe/highflow cat
    list to do :-
    st bodykit 300mm disc conversion+rear disc
    underdrive pulley custom management 45mm throttle bodies gasflown big valve head
    comp ratio increased 11:1
    looking for a mint 4x4 rouse motorsport 304r sapphire running std (260bhp) or stage 3 set up
    Jun 2007
    UK
    211
    have you considered Autronic?
    Feb 2007
    cardiff
    432
    I have a omex on my zetec and their support is very good, they supplied me with several maps when setting up
    Mar 2004
    Barking Essex
    9,873
    249
    As said above,I have omex600 which is very good and there very helpful
    Old skool forever
    Aldershot
    36
    6,190
    A second for Emerald here! Best bet is to talk to the people that run your chosen rolling road to see what they recommend. They will have seen every type of ecu so will know what is best for your needs.
    Clint's Avatar
    Jul 2001
    653,801
    67
    Motec are in a different league to all the other mentioned.
    if you can afford it go Motec !
    Nov 2004
    Sunny Essex
    5,101
    100
    True, but if not I'd go for a DTA, mines an S80 pro and has all the features I'll ever need
    Clint's Avatar
    Jul 2001
    653,801
    67
    Its not so much about features, it’s about ease of mapping, ease of changing things and support.
    Lots of cheap ECU’s can’t support all types of injectors, can not support custom sensors, cannot add in load sites in the middle of a map when you need to.
    Omex are not very good in my opinion, they have lots of little things they don’t do that you would think an aftermarket ECU should, they also cannot run sequential injection which is very important for low and mid range efficiency and is a must for tuning turbo cars accurately; Ford knew this when they built the Cosworth even a 25 year old Weber ECU has sequential injection.
    Emerald are quite good ECU's however Neil from NTS has had a complete nightmare with his, at one point if his mobile phone rang the ECU would reboot, cutting the car out in the process. Neil has found support to be rubbish too, he (and I) have phoned them loads of times to find that there’s only one guy that can support them technically and if he is out or busy that’s that for the day, you can email them though and after a few days and a few emails going back and forth you will get a sensible answer.
    The other thing to think about is the mapping, often the money you save buying a cheap ECU will be well lost in the mapping, I have watched Omex and DTA ecus take 2 and3 days to map whereas Motec, Pectel and Autronic often taking less than a Day. Remember Dyno and Rollin Road time is very expensive.
    There is something quite interesting quirk to look out for, cheaper non professional ECU’s seem to have ignition drivers built in and the professional ECU’s do not, (they need to use ignition amplifiers.)
    Nov 2004
    Sunny Essex
    5,101
    100
    Well I just gave my requirements to Steve G and asked him which would be easiest to map as he will be dealing with all of that side of things for me, and he chose DTA, so job jobbed.
    He does mapping day in day out so I have just left it to his discretion really. I have had good experiences with MBE also but must say that I have heard more than a few dodgy things about some of the omex systems, I guess to an extent you get what you pay for and as Clint says if you get a real pain of an ecu to map you will make up the cost of a dearer one in operator charges
    Mechanic lowscorts's Avatar
    Feb 2003
    Bucks
    599
    The lesser systems dont seem to be as stable or consistant, spent today mapping a Jedi with an MBE setup and its difficult to get a consistancy from run to run, the a/f changes making mapping more time consuming.
    Admittedly it was on a ZZR11 carb motor and bike engines built for carbs dont seem to take to FI very well
    Jul 2006
    bristol
    11,509
    902
    What do you poeple think about weber alpha systems???
    Bolt stright on lot of back up easy to get set up.
    Mechanic v8ian's Avatar
    Dec 2004
    FarFar south, any more and my feet are wet, sunny sussex
    733
    I use an Emerald M3dk, Had absolutely no problems with the system, A good thing with Dave Walkers system is the Rolling Road, I think its 250 all in for a set up on his rollers no matter how long it takes, Any E mail questions are normally answered within 24 hours, or over the Phone is not a problem, even Physical upgrades are generally back from Carl within a week.
    Ian
    Jun 2007
    UK
    211
    that sounds liek a very good price.
    23,139
    226
    i've been running emerald ecu's since they first appeared, yes sometimes tech support can be a little iffy due to the small nature of the company but then again your not paying motec money and all the software is free and available, and in my opinion the small nature of the company can work in your favour as your dealling with real people face to face if you want and they can and do go out there way to accomodate one offs, and i do have to say i there would of been many race meetings i would of never made if dave and carl haddnt been prepared to go the extra mile top see my car ready for the track, even working until the early hours if needed.
    my ecu has been upgraded many times and gained a lot of features over the years always FOC , most manufactures would of at least charged for the upgrades, and a lot would of just flogged you a new ecu, and as V8ian said dave does a seroiusly good deal when it comes to time on the rollers
    Apr 2004
    Essex
    1,796
    17
    Are there any existing charts showing what each one can do in comparision?
  19. #19
    Dec 2007
    Dubai
    1,716
    29
    I use the Emerald M3D as well, upgraded to the K3 self-mapping software. While a good dyno operator can never be beaten, my car has done 5000kms self-mapping using a wideband and it works brilliantly
    www.gulfpetrolheads.com
  20. #20
    4,150
    17
    Has anyone used or tested all (or most) of the available systems? Or has a car-mag done a test of these ECU's?
    Personally I have used a couple of the ECU systems and found the Emerald not good at all. But that was some time ago so build quality and userfriendlyness could have improved.
    Recently I used several KMS systems from van Kronenburg, yes a Dutch company: http://kms.vankronenburg.nl/
    Anyone else used these systems?
  21. #21
    Feb 2007
    Norway
    1,093
    65
    I beleive Practical Performance Car Magazine did a comparisson between a few ECUs a year ago or so. I'll see if I can't find the issue in my pile of mags.
    67 TVR VIXEN V8
  22. #22
    Apr 2004
    Essex
    1,796
    17
    Nice one Sonus. Eagerly waiting.
  23. #23
    Feb 2007
    Norway
    1,093
    65
    Found it, Practical Performance Car Magazine Issue 30, October 2006:
    Compares the following ECUs:
    KMS
    DTA E48EXP, S60Pro, P8Pro
    Pectel SQ6
    Emerald K3
    Autronic SM4
    Motec M800
    Omex 600 series
    MBE992E
    Haltech E6X
    Gotech MFi, MFi Pro, Pro X
    Questions answer for each of them was:
    Price of extras
    What trigger patterns will it read
    Can it handle batch and sequential injection
    How many cylinders can it control and in what configuration
    Does i thave self mapping facility using closed loop lambda
    Does it have turbo boost control
    Can it run eight injectors on a four cylinder turbo engine
    Can it handle variable cam timing or duration systems such as honda v-tec or rover VVC
    Does it future knock sensing
    Does it have a can-bus for connection of a digi dash systems
    Can it runmultiple maps? if so how many
    What aftermarket support is there.
    Last edited by Sonus; 25-04-2008 at 18:30. Reason: Added what questions were asked
    67 TVR VIXEN V8
  24. #24
    Apr 2004
    Essex
    1,796
    17
    Being a lazy bum I don't want to go out and buy the mag. Any chance you could scan it in or put the results up?
  25. #25
    alladdin's Avatar
    9,357
    104
    Quote Originally Posted by Quarterless View Post
    your newsagent is having a laugh if hes selling that edition still
  26. #26
    Feb 2007
    Norway
    1,093
    65
    Won't be able to scan it in a few weeks as I'm of on holiday to the UK on Sunday and won't have access to a scanner before that. Sorry.
    67 TVR VIXEN V8
  27. #27
    Oct 2004
    get me on my beeper,beeper
    15,804
    35
    ive just had autronic fitted to my motor.great back up and free remapping as well.and mr sheed is only 5 mins from my house
  28. #28
    Part of the furniture Decade Plus User Tone's Avatar
    Jan 2003
    sarf essex
    11,313
    Quote Originally Posted by trig View Post
    binned mine,no back up and all closed shop mapping can't do anything yourself no software downloads i've gone for an EMERALD myself
Similar Threads
  1. Omex 600 ECU and Omex loom for a zetec or duratec
    By ninja_alex in forum General items for sale
    Last Post: 28-06-2006, 18:54
  2. is motec ecu the way to go???????????????????
    By Tone in forum The Technical Section
    Last Post: 25-03-2003, 12:24
  3. Replies: 0
    Last Post: 24-03-2003, 17:49
  4. Cosworth / MoTeC parts for sale
    By wes in forum Parts For Sale
    Last Post: 26-01-2002, 11:21
