Page 3 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 81 to 120 of 388
Thread: Matt's Mk 2 Grp 2 Zakspeed Replica
  1. #81
    Bodger brianrace76's Avatar
    Jul 2010
    ireland
    72
    Quote Originally Posted by Matt75 View Post
    Hi Mate, i dont actually as i had an engineering place design these for me. I could take some measurements though.
    Do please👍
  2. #82
    Mechanic Matt75's Avatar
    Mar 2011
    Melbourne
    797
    Few more pieces arriving.....
  3. #83
    Mar 2011
    Melbourne
    797
    Picked up an alloy dash backing for the Stack Dash. I may paint it though with some crinkly paint as it's a bit shiny...
  4. #84
    May 2010
    london
    1,139
    I really want one of these...but to much for me at the moment...
    coming on strong now...cheers mark
  5. #85
    Mar 2011
    Melbourne
    797
    Quote Originally Posted by madragon199 View Post
    Thanks Mate, Yes it's a nice bit of kit
    You're overdue for an update too!
    Matt
  6. #86
    May 2010
    london
    1,139
    Matt
    Yea...back on it tomorow....
    should have some updates for friday...
  7. #87
    Mar 2011
    Melbourne
    797
    Been a slow month or so but still getting the other things sorted
    Rear hilux axle is now sorted. I had a mate make up some brackets for the Skyline calipers and we used supra rear rotors.
    All sorted and looks great
    Mar 2014
    London
    110
    Coming along nicely .... Wish I had a m8 with a machine shop.. Can help your out of all sorts of problems
  9. The Following User Says Thank You to Peanut1 For This Useful Post:
  10. #89
    May 2010
    london
    1,139
    looking good...still got to tackle my axle....cheers mark
  11. #90
    Mar 2011
    Melbourne
    797
    What are you going to use? Actually, what engine are you running too?
  12. #91
    May 2010
    london
    1,139
    Hi matt the axle of a mits /shogun...needs massive lightning..but perfect width for me come standard limited slip//unbreakable shafts /disk braked...got to convert it to 5 stud but it will fit my wheels..
    Its just a pinto...with a twist...i built the head with down draught ports. 8 injectors....variable velocity stacks...46mm throttle bodies(bike) ..46mm and 37mm valves...
    the bottom end is waiting for pistons to be made...i had the rods made long stroke 5.73" but i also stroked the crank...this means the pistons will be only 21mm above pin (prob only room for 2 rings)...there is a build thread on here if you have a week to spare reading it..ill find the link and post it up...cheers mark
  13. #92
    May 2010
    london
    1,139
    http://www.turbosport.co.uk/showthread.php?t=455891
    i think that will work..if not its called Down draft b.v pinto with variable velocity stacks shed build adventure
    cheers mark
  14. #93
    Mar 2011
    Melbourne
    797
    Hey Man, how could i forget your epic engine build. Apologies. My Pinto is due to be dyno'd in a few weeks now and should see high 180's or hopefully low 190's on 48 DHLA Dellortos.
  15. #94
    May 2010
    london
    1,139
    that will be plenty of power..and hopefully reliable...your running quite a high diff(from memery) so you will have awesome acceleration through the gears...
    what cam did you chose ?
    cheers mark
  16. #95
    Mar 2011
    Melbourne
    797
    Yeah, the guy building oy does race pintos so hes known for reliability.
    The cam is a custom grind but similsr tona Wade 520x .490" valve lift and 311deg inlet and 310 deg exhaust and is around 254@50.
    Yeah, the diff is a 5.3 which is ridiculous dk I'll get it rebuilt to 4.4 or thereabouts
  17. #96
    Feb 2017
    South Shields
    21
    This is awesome and just the sheer speed you've gone through so much work in little time. We'll done mate. Really looking forward to seeing and hearing it go (videos please).
    Sent from my SM-A500FU using Tapatalk
  18. #97
    Mar 2011
    Melbourne
    797
    Carbies all built up
    Click image for larger version Name:	14794124_10155386843654115_708568118_n.jpg Views:	387 Size:	65.1 KB ID:	80592Click image for larger version Name:	14958329_10155419945194115_1037896792_n.jpg Views:	387 Size:	55.8 KB ID:	80593Click image for larger version Name:	17554666_10212679566889875_420190458_n.jpg Views:	385 Size:	28.4 KB ID:	80594Click image for larger version Name:	17580160_10155968845689115_1088185731_n.jpg Views:	386 Size:	112.4 KB ID:	80595Click image for larger version Name:	17580217_10155968845709115_1792747782_n.jpg Views:	389 Size:	71.3 KB ID:	80596Click image for larger version Name:	17619420_10155962722694115_1666651452_n.jpg Views:	385 Size:	83.8 KB ID:	80597Click image for larger version Name:	17670983_10155968845779115_1556133863_n.jpg Views:	383 Size:	57.9 KB ID:	80598
  19. #98
    Mar 2011
    Melbourne
    797
    Pics are all arse about....
  20. #99
    Mar 2011
    Melbourne
    797
  21. #100
    Mar 2011
    Melbourne
    797
    Now painted
  22. #101
    Mar 2011
    Melbourne
    797
  23. #102
    Mar 2011
    Melbourne
    797
    Engine should be dyno'd in a few weeks hopefully...
    Starting back on the car next week. Can't wait
  24. #103
    May 2010
    london
    1,139
    nice work as always...engine has to be green..i couldnt decide on a color for my block..i went through zakspeed green,orange, silver..ended up with deep pearl blue..but still want to look zakspeed ..maybe gold...looking forward to the car updates..cheers mark
  25. #104
    Mar 2011
    Melbourne
    797
    Hmmm, i didn't think about gold.
    Matt
  26. #105
    Mar 2011
    Melbourne
    797
    Sorry for the lack of updates. Progress has been made though
    Engine is finished and will be on an engine dyno next weekend. Hoping to see high 180's and maybe low 190 hp but we'll see. It'll be mated to a W58 Supra gearbox.
    Few pics
  27. #106
    Mar 2011
    Melbourne
    797
    Have started the dry build now. Front and rear suspension is in and finally test fitted the new Braid wheels. They look amazing and I was very relieved they didn't foul anything and the large Brembos with 305mm rotors didn't hit anything too. We ended up throwing some old 225 A050's on and they look great on the 9" fronts. Toyo do a 235 in a 15" so I think I've finally found some RSpec tyres to run that aren't crazy $$.
    Anyway here's the pics
  28. #107
    Mar 2011
    Melbourne
    797
    We obviously haven't done the alignment and the wheel sits far too much forward but thereis plenty of room around it once we trim the front valance
  29. #108
    Mar 2011
    Melbourne
    797
    Onto the rear. I had bought a hilux diff that was in a mk2 escort that had been 6 linked soI weas expecting to have to make the brakets to sit it on the escort leaf springs but had a massive win as we found this had been done already.
    Here it is installed with the new brake brackets and rotors from Supra MA70 that have been machined and redrilled.
  30. #109
    Mar 2011
    Melbourne
    797
    Well that was a pretty good day so hopefully we keep the momentum rolling
    Thanks for looking
    Matt
  31. #110
    Jul 2009
    Auckland, NZ
    17
    Very cool, glad I just stumbled across this. Watching with interest from across the ditch
  32. #111
    Mar 2011
    Melbourne
    797
    Thanks Mate
  33. #112
    Mar 2014
    London
    110
    Starting to come together now ... Keep up the great work matey
  34. #113
    Jul 2009
    Auckland, NZ
    17
    Thanks Mate
    Forgot to ask, where did you get your pedal box? Cheers
  35. #114
    Mar 2011
    Melbourne
    797
    I had a mate make it from a standard one.
    Matt
  36. The Following User Says Thank You to Matt75 For This Useful Post:
  37. #115
    May 2010
    london
    1,139
    Big leap forward...looking like a zakspead now....im trying to find the 235s as well for my fronts....looks a nice tyre...are you using gaz shocks on the rear i cant remember...almost there cheers mark
  38. #116
    Mar 2011
    Melbourne
    797
    Toyo do the R888 and R888r in a 235/50 R15. The tyres in the pic are knackered Yokohama A050's just for setting up
    I've got Bilsteins on the rear and the Gaz Golds upfront
    Once it's dry built we'll pull it apart and ten blast it then the paint can start so still a long way to go
    How's yours coming along Mark?
  39. #117
    May 2010
    london
    1,139
    Slowly ..been grinding down welds ..make it look pretty..(which i hate doing)...my daily driver has been a pain...had to get an obd2 reader to find the fault..but the obd2 driver didnt work, so had to download another...as always seems 1 step forward 2 steps back...
    But ill get there ...nice to see someone else progress..gives us all hope...
    cheers mark
  40. #118
    Mar 2011
    Melbourne
    797
    Nice one, I agree seeing progress on other builds definitely increases motivation
    Get an update on your one going....
  41. #119
    Mar 2011
    Melbourne
    797
    Few pics of the rear brakes.
  42. #120
    Mar 2011
    Melbourne
    797
    small update. Donor engine is into check it fits with x-member.
    W58 Supra G/box mounts will be made next
