Roof vent is on
Not much of an update but next week it'll we'll get back on it as the first track day is booked for 3rd Nov
Roof vent is on
So barring a few stickers the exterior is all finished now and the body kit is now on permanently
The white stripe has been added and is now looking the way I always hoped it would
Now the final assembly can be done
Stay tuned...
Why did you remove the roof vent for the last few shots?
Have you had the stickers recreated?
Awesome....
First of the stickers going on
More updates
Heated Windscreen is in, New tail lights, Grill is on and dash fitted. Switch panel is painted and switches mounted.
I'll keep adding things as it progresses
Few hours spent today
Head lights, door cards, Boot springs, Side Mirrors installed
More Action today
Roof vent has been installed now using MK2 escort vents
Door handle bolted on using nutserts
Zakspeed Sticker stuck on now. Looks soo good
That's looking awesome.
Bet you cant wait to use it in anger.
Shaun
What does the potato button do?
Hexham and District Motorclub
Switch panel mounted
http://imgur.com/gallery/WJxDXgJ
Switch panel now installed
Build continues...
Boot seal in and the fuel filler hose now all sorted so the boot is pretty much done bar the wiring
Installed trumpets on the carbs and fitted filters
Thermo fan is fitted behind the grill. It's only a 10" one due to the oil cooler in the way but this should be more than enough given it won't be a road car. Sorry for the crap pic...I'll get more next time
Looking good and a great read. Keep it up and keep the updates coming
The wiring has begun. Headlights and horn wired in
More pics of the rear firwewall
Pic of the mount for the switch panel
That's all for today. Stay tuned
[/QUOTE]
Hi matt...long time ...looks everything i new it would...stunning car...and congratulations for sticking with it....gives me a kick up the arse...
ive not touched mine since the last update...but fingers crossed will be back on it again....life gets in the way...
cant wait to see it in action...cheers mark
cant wait to see it in action...cheers mark[/QUOTE]
Thanks Mate, hope all is good your end. Your build has inspired me massively so can't wait for the new update
Matt
Wiring has begun in earnest
Engine bay is now all finished with everything wired up including the dash inputs
Boot all finished now too
Now onto the interior
That's all for today. I'll get another update up tomorrow
Thanks for looking
Did you drill and tap the thermostat housing yourself?
Looks good.
Rear windows are in now
Quick vid of the switch panel
https://imgur.com/JSpc4NR
More wiring
First signs of life...
I was trying to help but it wasn't wanted...
Alternator bracket done
Quick shot of the wheel nuts
used a bit of carbon wrap to protect a few areas
Kill switch all wired up and sticker applied
My fabricator is an idiot!
Got some lead separators
Dash all wired up now
Vid of the switches and how they all work
https://i.imgur.com/D64YX37.mp4
This is the remote kill switch
https://i.imgur.com/M3sRXXl.mp4
Everything pretty much done now so hoping to fire it up for the first time tomorrow
What does the 'Panty Dropper' switch do please???
Thanks for the update.
Its Alllllliiive!!
Bretty filling it up for the first time!
Gauge works!
Had a bit of carbon wrap left so I put a bit on the cage to protect it from scrapes
Checking the Stack Dash does everything it should
Here it is after firing it up for the first time. Im soo happy
There are still a few more things to do but it's pretty much finished now once we dyno it
New KAAZ LSD with 4.3 ratio. Little but more suitable than the 5.3 I had
All polycarbonate windows are in now. I've just glued the outside rubbers on with sikaflexand it looks really good and won't be going anywhere. I'll be doing the inner ones tonight
Installed the drivers side foot plate. I've fallen in love with nutserts!! Best thing ever
First time under its own power. I can't believe how happy I am
Few pics too
awesome job, followed this from the start good to see a project followed through to completion. As complete until the next mod. Well done
What, no burnout???
Car looks awesome... it's come a long way.
When is your first event?
Shaun
