Results 1 to 29 of 29
Thread: Black estate (Abee)
    Tyre Kicker Mk2FChris's Avatar
    May 2016
    South Lincs
    25
    25
    Black estate (Abee)
    Carrying on from the thread put up by flyingbenny http://www.turbosport.co.uk/showthre...t=#post3024490
    After and 8-9 hour round trip I Picked up Abee early 2016 with plans of dailying for a couple years and then a full resto.
    I've always been a big fan of low, clean and simple estates.
    However, the more i poked the more fell off so i eventually decided i'm going to just get on with it now instead, I'm no professional so don't expect top quality work. Just an 18 year old obsessed with cars and taught by myself and my dad!
    So, the day i picked it up.
    And after many piles of rust and filler and all sorts i found the a-post and decided it was time to start the work.
    Before i did anything else i wanted to get that done to put some strength back into it.
    Splash shield on
    Rust converted and hammerite
    Welds were pretty messy as the welder was playing up but they were functional. not that i'm that good anyway
    And that's about where we're at now. i'm in no rush to finish this as i don't quite have the funds at the moment but i'm slowly working on it.
    The longer it takes the more my insurance drops so i aim to have it out summer 2018, whether that happens or not
  2. The Following User Says Thank You to Mk2FChris For This Useful Post:
  3. #2
    May 2009
    Havant
    553
    12
    Re: Black estate (Abee)
    Im not a great welder either but my welds definitely improved as time went on....stick at it and keep the photos coming
    May 2010
    london
    1,139
    good job..as long as the welds strong..no one will ever see them...and by the time you get to the top pannels your be a great welder...
    cheers mark
  5. #4
    May 2016
    South Lincs
    25
    25
    Cheers, planning to get it on a jig once the front end's replaced so it should make it a lot easier. I've learnt plenty of lessons from the fiesta i restored last year (like warping rear arches ) so it should turn out good.
  6. #5
    Spanner Monkey mk1van's Avatar
    Aug 2007
    Wicklow, Ireland
    280
    whats the difference between the posts on a 2 dr and estate?
  7. #6
    May 2016
    South Lincs
    25
    25
    They're mk1 a-posts but the doors on estates are bolt on instead of pins. so instead of the big hole on the corners it's small mulitple holes in the centre
  8. #7
    May 2016
    South Lincs
    25
    25
    Got a little more done, inner wing should be ready to weld on by next weekend.
    Cleaned up, rust converted, zinc primer and hammerite. plenty of protection..
  9. #8
    May 2010
    london
    1,139
    comeing along now...i assume the pics are in the wrong order..and the inner wing is fitted..or was it just tried on for fittment...cheers mark
  10. #9
    Aug 2007
    Wicklow, Ireland
    280
    nice job dude.....keep the pics coming
  11. #10
    Mechanic oxb1l's Avatar
    Sep 2007
    A, A
    550
    Good stuff
    Take your time ,I take lots of measurements and drawings then play with bits of paper for templates
    Bill
  12. #11
    Spanner Monkey mk2mania's Avatar
    Feb 2010
    lancashire
    352
    Can't beat an estate , rebuild is looking sweet
  13. #12
    May 2016
    South Lincs
    25
    25
    Inner wing and strut mount is on and in the right place, so happy with this considering I've never taken this much off a car before
    No idea why they were there but the dents in the inner wing were welded and then a skim of filler (i still need to tidy up)
    As well as making up a new strength bracket for the front bumper mount
    I then found our long lost spot welder which was exciting as it meant i could get a lot of stuff a lot cleaner
    Now to do it all over again on the other side!
  14. #13
    May 2009
    Havant
    553
    12
    Any updates?
  15. #14
    May 2016
    South Lincs
    25
    25
    Other inner wing is off and i've been cleaning it all up every now and then, in the process of searching for a job so it's on pause at the moment.
  16. #15
    May 2016
    South Lincs
    25
    25
    Been trying to get out and do what i can, planning to get it rolling by end of next month?
  17. #16
    May 2016
    South Lincs
    25
    25
    Made some progress, slowly but surely..
    Also, a spot welder is a life saver when it comes to this work!
    I don't have many photos of the specifics as i did this all in a weekend and just got on with it but here's the ones i took.
    Everything rust treated and coated. also repaired a section of the chassis leg.
    End of day 1, inner wing and inner front panel on.
    End of day 2, Splash shield, strut support on, front panel 50 percent on.
    And then the next morning i had it all welded up and on the ground by 9am!
    A hell of a lot better than it was, and flat strut supports.. Lol
    And of course i had to find one of the old rotten wings and put clamp it on just to have a look!
    It still needs a lot of tidying up and finishing off of course but my goal was to get it rolling and i did that, now to eventually work my way backwards.
  18. #17
    May 2010
    london
    1,139
    looking nice ..some real progress made...cheers mark
  19. #18
    May 2016
    South Lincs
    25
    25
    My Dad managed to get his truck rolling so i rolled the escort outside for the first time this year, was good to get it out and have a good look and refresh and figure out what's next.
    what wasn't fun was the seized rear brakes
  20. #19
    May 2016
    South Lincs
    25
    25
    Modified the jig i built for my mk2 fiesta to fit the escort, the underneath especially the chassis rails seem reasonably solid considering how bad other parts were.
    It's a shame the sills are so wonky as the drivers side is pretty solid.
  21. #20
    Spanner Monkey flyingbenny's Avatar
    Jun 2006
    Machynlleth
    434
    Nice one mate, it's good to see ole Blacky getting the love and attention she deserves. You obviously poked a lot harder than I ever did, I didn't have the time money or space to end up with two escorts on jigs😁
    Keep crackin' on, it'll be a very cool car one day. I shall be watching this build for sure.
    Sent from my SM-G920F using Tapatalk
  22. #21
    May 2016
    South Lincs
    25
    25
    Quote Originally Posted by flyingbenny View Post
    Nice one mate, it's good to see ole Blacky getting the love and attention she deserves. You obviously poked a lot harder than I ever did, I didn't have the time money or space to end up with two escorts on jigs
    Glad you're watching mate, I knew it needed it and didn't want to start this soon but couldn't keep the screwdriver away from it!
    So, no progress since my last post unfortunately due to "life" but I started a youtube series a few weeks ago and I aim to hopefully get it back on the road later this year/next year.
    Link below if you want to check it out -
    https://www.youtube.com/watch?v=LIEID6dqANM&t
  23. #22
    May 2016
    South Lincs
    25
    25
  24. #23
    Sep 2006
    cambridge
    1,056
    Nice to see a estate getting some love.
    A mk2 on a y plate is not very common to see..
  25. #24
    Aug 2006
    Christchurch, New Zealand
    463
    You're doing a grand job on that, well done
  26. #25
    May 2016
    South Lincs
    25
    25
    Wow, It's been a while since I've been on here.
    The escort hasn't made as much progress as i wish it had but it's been coming along lately with parts on the way for it.
    It's had a lot of the small patches done, around the windscreen, A-Posts, wing rails, drivers inner and outer sill, passenger inner sill, floors etc.
    I'm currently waiting on some new rear wheel tubs and in the meantime replacing all the rotten steel so they have something to actually attach to.
    once the tubs are done it's arches/rear quarter replacements, small patches on the underneath and then it's done welding wise.
    I aim to get it out on the road for next year, convenient as it's tax exempt then too! Cheers
  27. #26
    May 2016
    South Lincs
    25
    25
    Slowly getting somewhere, weldathon is almost over and plans have been decided for drive train. It won't be the usual that's for sure.
    Excuse the constant mess in my workspace, it does get cleaned up honest...
  28. #27
    Aug 2007
    Wicklow, Ireland
    280
    nice job so far...not many estates about....
  29. #28
    May 2016
    South Lincs
    25
    25
    It's rolling.
  30. #29
    Oct 2019
    Barry South Wales
    30
    Chris,
    A nice M3 engine would go well in there
