English axle measurement needed
Hi there,
Ive had the axle on my mk2 shortened to 45.5" long and need to shorten my group 1 shafts to match. Does anyone know the distance between the two shaft ends once installed in the casing without the diff in? I need to take 1.5" of each shaft to match the amount taking of the casing but just wondered if there was a minimum/maximum distance inside the diff itself?
