Results 1 to 6 of 6
Thread: Cosworth 24v Questions
    Sep 2003
    Barbados
    36
    1,285
    19
    how many versions of this engine are they?
    What are the standard engine outputs?
    Since the engine was based on the Taunus/Cologne Engine Can a 2300 base model engine(from the cortina etc) be used to make a 2300 24v?
    Have a damaged 2.9 24v n good 2300 engine.
    thanks.
    1973 mk1 escort
    1982 Toyota corolla ke70
    1988 mk4 escort
    25,175
    297
    Re: Cosworth 24v Questions
    the 2.3 engine had a smaller bore than the 2.8/2.9 on which the 24v is based so it may not be possible because the combustion chambers might end up overhanging the bores, and i suspect the loss of 600cc would result in a very low compression
    Bodger ToGGoT's Avatar
    Sep 2005
    Devon
    36
    75
    2 Versions of the 24v. BOA and BOB. BOA in the earlier Granada Cosworths, and BOB in the later Ultima/Scorpio Cosworths - Thicker block, different cams/plenum/ECU.
    BOA approx 195bhp stock. More if you De-cat, and swap for a better ECU it seems. Lots of benefits to fitting BOB cams if you can get them. Easier to fit/setup than BOB engine due to being EECIV.
    BOB approx 205 - 210 stock. Harder to tune, but probably getting more available now. If it were me, i'd get one, bin all the EEC etc, and stick on a mappable ECU and wire it up to that properly.
    ToGGoT
    World Champion Decade Plus User popuptoaster's Avatar
    Jan 2003
    Brentwood, Essex
    9,508
    lots of differences in the block between the old colognes and the 24v so a 2.3 conversion would be difficult, not to say its impossible as a few guys are building 4 litre versions using the american Explorer block (i've seen ohc and ohv versions being used) its not a bolt on job though, plenty of machining needed and things like the dizzy drive goes the wrong way round to work the oil pump etc etc.
    I support TS Decade Plus User
    Scott_B's Avatar
    Sep 2003
    ESSEX
    47
    2,896
    47
    There are loads of differences between the 12v and 24v blocks, there was a previous post covering it here http://www.turbosport.co.uk/showthread.php?t=97643
    The manual pictured is for a BOA engine
    Jun 2007
    chadwell st mary, essex
    9
    hi i have a boa engine for sale if its anygood to you,
Similar Threads
  1. Mk1 Van questions
    By flyingbenny in forum The Technical Section
    Last Post: 25-04-2007, 14:02
  2. 2 questions
    By RETRO_AL in forum RWD Chassis and Suspension
    Last Post: 11-12-2006, 14:48
  3. A few questions..
    By leemarkadams in forum General Car Banter
    Last Post: 29-01-2006, 20:10
  4. COSWORTH QUESTIONS
    By bear in forum Cosworth Installations
    Last Post: 01-01-2004, 18:17
  5. A few questions.....
    By Dan123 in forum The Technical Section
    Last Post: 27-09-2003, 18:21
