Re: Does this seat position look correct?
Yea it does look too close to the B pillar IMO really. Defo put the rear cage section in to check.
But ideally I'd wait until you've got a bit more in it to go by really, the steering column and wheel
would be good aswell.
the brackets are only tacked in place for the time being,ill bolt a few more bits in and see what the driving position is like
It's difficult to say off the photos but it looks like the seat might need to go towards the transmission tunnel by approx 20mm. You need both seats in really to see how they look. It's a mine field to get the seating position correct.
I positioned mine with the cage, pedalbox and column/ steering wheel fitted.
