Results 1 to 20 of 20
Thread: Chain tensioner mod
    Sep 2015
    Benfleet
    225
    Chain tensioner mod
    Just carrying this out I have it all assembled and fitted as per racelines instructions however they said there should be a 3.5mm gap between the guide and physical stop but I have a lot more maybe 6-7mm it also doesn't look like the photo on this site
    This is mine
    ​obviously I can push the guide back by hand but turning the engine over only moves the guide in and out but about a mm any advice mines a 2.0
    3,241
    Re: Chain tensioner mod
    New chain or old chain? Obviously new will be tighter / less slack / closer to hard stop?
    Is the chain slack - if not the tensioner is doing its job. As I don't know Duratech's - does the tensioner just rely on a spring or does it have a ratchet to take up any resultant slack and stop backing off?
    Sep 2015
    Benfleet
    225
    Hi old chain nice and tight the tensioner has a spring as well as oil pressure maybe a new chain then should be fitted?
    You need to wind out the bolt then lock the k nut to get the correct clearance as per my picture
    Sep 2015
    Benfleet
    225
    I assume yours is a new chain then? I think it's best I get one just to be safe
    Quote Originally Posted by LAWRENCEM View Post
    Nope old chain was re-used just new quides fitted
    Sep 2015
    Benfleet
    225
    Yeah thanks that's where I was looking obviously thier gap is no where near either of ours part of me wants to get a new chain and whack it in but also if it's stretched a bit it prob won't stretch anymore and the new one would anyway so it might be better to set it all up as it is
    If your engine was a high mileage then go for a new chain and quides good piece of mind
    Apr 2012
    glasgow
    500
    17
    For the cost of a new chain and guides I'd get them, it's a little bugbear of mine people spending thousands on an engine and then taking the risk of an old chain/belt breaking.
    I know somewhere you have to draw a line and that I probably change my belts and chains more often than I need to but it's a small price for me to pay for piece of mind
    Keep her lit
    Sep 2015
    Benfleet
    225
    Yeah I'm going to go get some tomorrow it's not worth the risk as you say
    Sep 2015
    Benfleet
    225
    That looks a bit better cheers chaps just have to dial in the cams now which is proving a bit tricky due to needing extensions for the dial gauge I tried the coat hanger mod! But it all was a bit wobbly so it gave random readings will have another. Go this week
    Sep 2015
    Benfleet
    225
    Had another go with the dial gauge I think they are setup correctly but can someone confirm that when all timed up afterwards the timing bar won't fit in on the back of the camshafts anymore it seems to be the inlet can that's slightly further forward now?
    performance cams rarely time up exactly as per std, so i wouldnt expect the bar to fit
    Sep 2015
    Benfleet
    225
    Cheers I did think they might not but just wanted some confirmation from someone who's done it as I found it quite tricky to do getting everything to be repeatable
    Apr 2012
    glasgow
    500
    17
    What cams do you have fitted?
    Keep her lit
    Sep 2015
    Benfleet
    225
    Hi I have the dtec35s from Kent
    Apr 2012
    glasgow
    500
    17
    Nice, I would agree with graham that the bar won't fit. if you've set it up and checked it using a dti you'll be good
    Keep her lit
  19. #19
    Sep 2015
    Benfleet
    225
    Cool cheers
  20. #20
    Sep 2015
    Benfleet
    225
    Rechecked it all again and they do line up still just to clear that up in case someone mucks it up from my post just waiting on a new front crank seal as the one I bought from euros pushed through to the back of the casing when I put true pulley on which was a bit of a pisser as it cost about £20 orders one from burtons and then it's all built up just needs alternator kit exhaust and inlet going to try to use the standard alternator with a different regulator to save a bit of money a few people have done this but no one lists the regulator they used so it's going to be a bit tricky
