just found this one a power plot from my old car with a 2.0 8v m10 engine, its not the best it ever produced, that had a few brake more but its still 100bhp per litre.
the engine was a true 2000cc as i had the crank offset ground slightly so it stayed within the capacity limit after a 0.5mm rebore.
although i had machined the hell out of every thing inside the engine the only non origonal bmw parts in it was a 336 degree cam, a set of steel rockers and some pinto valve springs, despite a 11.75 compression ratio even the pistons were std cast ones, all be it with massive valve cutouts machined in them so 200 bhp was pretty good going
