I doing my wiring and need to know what wires are for what on a standard ST170 loom.
coming off the TPS sensor i have:
Yellow/Green Stripe
Brown/Green Stripe
White/Green Stripe
I need to know What is the:
TPS Signal
+5 to TPS
Ground.
Yellow/Green Stripe
Brown/Green Stripe
White/Green Stripe
TPS Signal
+5 to TPS
Ground.
Middle one is TPS Signal, the in the direction of throttle being closed is ground and the one towards the throttle being open is +5v
not my photo but looking at it like this the top would be the +5V???
from my notes I have them as
Yellow = +5v
Brown = Ground
White = Signal
might have to be a bit of try and error then as Brown is in the middle lol
Have you got a multimeter?
Set it to resistance (ohms) and measure between any 2 terminal then move the throttle.
If the reading stays constant then those are the +5V and gnd terminals.
The 3rd unconnected one is the signal.
