Results 1 to 6 of 6
Thread: Cosworth YB idle too high
    Sep 2010
    Ypres Belgium
    78
    Hello,
    Idle is too high of my Escort Cosworth. Sometimes idle goes up and down like "a very modified engine".
    When I shift gear, engine speed keeps "hanging" a little.
    When I shut of the idle actuator everything is normal.
    I have shut off al the vacuumpoints allready...
    Anyone can help?
    Mar 2008
    west bromwich
    1,861
    Re: Cosworth YB idle too high
    Try cleaning the idle speed control vavle , with some carb cleaner
    Sep 2010
    Ypres Belgium
    78
    Thanks for the answer ! Its a brand new one, maybe 500kms....
    Mar 2008
    west bromwich
    1,861
    Un plug it see if it's idles high ? If not it could be the vavle , I know you need to set the base idle with a new iscv , is it a genuine one ?
    Bodger Duffer's Avatar
    Jan 2014
    West Sussex
    198
    27
    If running a P8 (you say Escort cosworth) have you reset the ECU after changing the ISCV? Cant remember exactly but there is a sequence you go through whilst shorting out the diag plug...
    Jun 2012
    Slovakia
    get your engine hot, unplug ISCV...set base idle with screw...connect ISCV...go for a ride 10-20km...get back to garage...
    what is idle? too big? then you have some issue on engine management.
