Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 81 to 120 of 140
Thread: 2.0 capri turbo
  1. #81
    Re: 2.0 capri turbo
    Well done. Good to see persistance is working.
    When diagnosing MS and installs like this ya have to keep an eye on everything. The fuse has caught me out before
  2. #82
    Mechanic longboy's Avatar
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    no much to show at the minute. Decided to sort the map and code in the ecu out.
    Have updated the code and now remapping from scratch (it's quicker).
  3. #83
    Jan 2008
    BIRMINGHAM
    237
    Re: 2.0 capri turbo
    nice woork a lot of thought and hard work there keep it up
  4. #84
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Cant get the bloody afr stable am getting seriously fed up of have replaced all but 2 hoses in the egine bay guess whats leaking.
  5. #85
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    More leaks
    http://www.turbosport.co.uk/showthre...22#post1476422
    Am tempted to cancel the insurance and store it for a year or till i can bear to get back to fixing one problem to find two more.
  6. #86
    Jul 2003
    England
    766
    19
    Re: 2.0 capri turbo
    I know the feeling.
    Keep at it mate, it will be worth it in the long run.
  7. #87
    Re: 2.0 capri turbo
    best thing to do is to leave it for a week then go back to it. If your heart isn't in it nothing seems to go right.
    Just think you could give up and watch eastenders instead
  8. #88
    May 2006
    isle of wight
    35
    599
    Re: 2.0 capri turbo
    is the alloy rad a honda civic item off of ebay???
    The way to my heart: German and RWD!!
  9. #89
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Quote Originally Posted by kosingcurry View Post
    spot on it's for sale if anyones interested would realy suit anglia or something not turbo'd.
    got up early this morning and covered all the exhaust joints with paste stuff and left it to dry, came back at dinner and put the clamps back on and tightend the manifold back up also tightened the hand brake cable (well spotted me)
    went to start the bugger and drained the battery trying, so had to quickly whip the battery off the probe as i was now late
    The car went for it MOT and blow me the only thing it failed on were the gasses and could have fixed that if the laptop was charged
    At first thought they were taking the pish till i saw the paper work, got some adviseries though brakes and the leaf mounts starting to corrode.
    Am propper chuffed but have to try and get the gasses sorted at home they were 8 and it should be 4
  10. #90
    Spanner Monkey Turbosport Subscriber drev's Avatar
    Sep 2007
    bilsthorpe newark notts
    284
    Re: 2.0 capri turbo
    If thats all it's failed on then you've done well matey. I saw your garage door open last night but didn't have time to pop in and say hello. Where did you go for the mot?
    mk2 capri 3.0s
    focus 1.6 zetec runabout
  11. #91
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    brookside down the road. £63 got to sort the gasses out and take it for a re test next week.
    will be going to thorsby but unfortunatly not in the capri
  12. #92
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    right it's a bit quiet so i'll try and show how i'm setting up the mega squirt.
    Nearly all the inf needed is from http://www.msextra.com/manuals/MS_Ex...x.htm#download but it take some reading
    First thing was to down load the mega tune, manuals and firmware.
    then had to down load the firmware to the ecu and the ini file to megatune. you do this by opening the batch files in the folder where megetune was installed to.
    when downloading firmware follow the instructions and select the right port. with so many usb ports on my laptop i just did trial and error till i found which one worked.
    so you got the firmware in the ecu time to start setting megatune.
    to start with you need to set up megatune using the configurator.
    first thing is to create a new project. Give it a suitable name it helps later
    using the dropdown bar at the top set the project according to your car setup and code you want to use
    then activate the code you want to use (this should have been transfered to megatune using the batch file earlier)
    thats the project configured to your car/ project next is to set the megatune setting........
  13. #93
    Re: 2.0 capri turbo
    Good stuff. Just got back on my escort last night so i was on a refresher course on the MS
    You will soon be whistling and popping down the road
  14. #94
    Sep 2007
    284
    Re: 2.0 capri turbo
    Brookside thats were i took the 3ltr the other week. nigel's pricey but does a proper job. when i went he had a lotus 7 type thing a mach1 mustang and a early 90's corvette in. And his dad's frogeye sprite they've just bought.
    mk2 capri 3.0s
  15. #95
    Oct 2007
    Preston, Lancashire
    Re: 2.0 capri turbo
    Great read mate, Im about to start on exactly the same conversion with my Capri. I have emailed the Extraefi site for a setup & price of what I need, and a mate is about to build me the manifold. Which turbo did you go for mate, was it the cossie garrett T3?
    Nick
    Ford Capri 2.0 Laser
    Ford Capri Cosworth YB (in progress)
  16. #96
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    at the moment i've got a t3/t4 jobby that came with the car (very laggy), will upgrade when ive got a stonger drivetrain.
    A T3 is a good cheap option.
  17. #97
    Tyre Kicker joppa's Avatar
    Feb 2008
    Norway
    Re: 2.0 capri turbo
    nice car and engine you got there
    what injectors are you runnin?
    a good friend of mine has a similar setup, but we have troble with surge at 1.4-5 bar boost.
    i think you will be disappointed if you fit what most people think of as a "T3", cossie 4x4. ebay "turbocharger" kicks ass you know looks like you got the same one as my friend, ar63 exhaust, and quite big compressor and exhaust wheel.
    could you please share your msq with us megasquirt heads?
    -Manta Cosworth
    -Kadett c coupe 16v
  18. #98
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Quote Originally Posted by joppa View Post
    Running cosworth light greens and a only running boost.
    Currently mapping from scratch as udated the code not long ago using an adjusted map wizard thing and a spark map from gustaf (user name therealpinto i think). got to do a proper udate soon.
  19. #99
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Right basicly i followed the help file information to fill in the basic settings for fuel and spark depending on the set up of the car.
    To help with setting up the basic fuel i had to calculate the flow rate of the injector according to the fuel pressure, i found a flow rate at 2.5 bar but am running 3 bar.
    anyway found the formula and knocked up the spread sheet to help later on. Someone might find it usefull
    Attached Files Attached Files
  20. #100
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Done a couple of jobs.
    Finaly fitted the lc1 bit of a pain to fit with some black wires being positive and about four brown wires in the loom from the ecu
    one problem was putting the wires through the buk head so after searching through the garage found a bit of tube that did the job.
    For anyone considering the lc1... it's a cheap wideband controler for a reason, i've found it totaly unstabe have to reset and calibrate it everyday am going to use the defaults so that i dont have to set up the outputs all the time.
    Have only run for a few miles to build a map but has raised a few probs already.
    The turbo oil return pipe hasn't coped witht the heat and became brittle and split (wondered where all the smoke was comming from under the turbo).
    so bought some more hose and used some leftover exhaust wrap then overkilled it with some aluminium tape.
    Also the turbo ex housing was close to the master cylinder so knocked up a heat shield using some steel sheet and some heat barrier matt. (note to self either buy a bench shear or some good tin snips cutting metal using hammer chisel and a brick is not fun!)
  21. #101
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    a quick run through on how i'm geneating my fuel map.
    first to get a table generated.
    to do this i used the table generator wizzard this is in ve table 1.
    input values you expect ( i guessed) you may have to have a few goes at this to get ther torque accepted.
    this should generate a smooth table.
    So you've got a table but this cant be used to drive the car yet.
  22. #102
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    so to get a drivable map.
    First get the car idleing correctly with the correct afr (about 14:1).
    i ended up shifting the entire table so that the correct afr was obtained.
    i then adjusted the no load areas of the map just reving in neutral and adjusting the values.
    so now its time to drive the car to adjust the map. activate the data logger.
    drive the car with very little load for a good 5-10 mins to generate a good datalog.
    using megalog viewer open the data log
    and open the msq for the car, then use the analyse table button. this use the data log to analyse the fuel values in the table with the logged afr readings.
    if happy with the changes accept them and save the msq under a new name so you can go back if not happy.
    drive the car agian checking your afr when happy reapeat higher up the load range a bit at a time.
  23. #103
    Nov 2004
    Sweden
    1,167
    Re: 2.0 capri turbo
    My experience with the LC-1 is that it works very good. I have read about problems now though so it could be a bad batch from Innovate later on. Have you tried upgrading the firmware or checking with the dealer?
    My LC-1 runs (or seems to run) a complete summer and only needs a new free-air calibration when I take the car out of storage.
    You have quite high entries in the VE table, it suggests that either the injectors are on the small side or there is an error in the constants/settings. You can tune "around" it but as 255 is the max VE entry you have little space left, and you may need to work the table more if you swap injectors later on.
    Regards
    Gustaf
  24. #104
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    cheers Gustaf
    Those values are just table i knocked up my table so far looks like this
    the circled area is where i've updated the map.
    As for the lc1, i've updated the firmware but it loses the settings for the outputs so will set them to defaults for the ecu and guage.
    Had to adjust the speed of the sensor reading as it wouldn't give a stable reading.
  25. #105
    Nov 2004
    Sweden
    1,167
    Re: 2.0 capri turbo
    Ah, I see, that looks much better.
    It's really bad if Innovate has lost the dependability on the LC-1, as I said mine has been trouble free.
    Gustaf
  26. #106
    Brum Town
    1,822
    26
    Re: 2.0 capri turbo
    amazing, looks very tuneable, my aftermarket ECU does nothing like that.
  27. #107
    Re: 2.0 capri turbo
    Great update some really useful info
  28. #108
    Re: 2.0 capri turbo
    Just a quicky. Did the table generator get the map reasonable and then you have fine tuned the idle off that. I seem to to be just massively rich at the moment hence starting a map from scratch ?
    Also the flow rate for my injectors is 200cc (standard pinto inj) what required fuel did you use as i assume your higher injector rate will have increased this using the req fuel calculator? Just so i can sanity check my figures
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    well i get the following.
    to be honest i altered the required fuel a bit but thats only to get it to idle.
    I the altered the whole map using the table transform function and used the afr reading to get the fuel right.
    Also read this and this it's what i followed.
  30. #110
    Re: 2.0 capri turbo
    Thats what i got
    thanks
  31. #111
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    bit of an update
    The afr sensor is working ok and seems to have settled down. have fitted a pinto alternator and am now getting 13+ volts at idle compared to the 11.9 volts with the old alternator think this could be the caurse of a few faults.
    One problem of this is that i have to run the alternator upside down to fit under the turbo/ manifold and i is just touching the steering rack a longer belt will solve this soon enough.
    have done a bit of wireing but nothing more than correcting earths and checking which wires go where so no pics.
    continueing to correct the map very slowly as am stuggling to tell if i get amy detonation with the exhaust being so loud and fule pump and tappets doing there best to recreate that loverly desiel tappity sound.
    Also made it to thorsby classic car show at the weekend with the capri club made it there and back but exhaust is blowing again
  32. #112
    Pit Crew Turbosport Subscriber Stu.C's Avatar
    Lancashire
    1,785
    Re: 2.0 capri turbo
    Excellent stuff You're doing a great job there ... and I think I'm even following most of it
  33. #113
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    cheers stu, comments alway apreciated.
    Still mapping but starting to go higher in the rev range. have now calibrated the out put of the lc1 to the guage so i get a close representation of the mega squirt guage, if it's of use to anyone i'll post the setting up.
    went for a nother datalogging drive today slowly going into the +boost area of the map all held together well. Even magaged to get a half decent pic or 2.
    It looks very clean in these shots, trust me it isn't
  34. #114
    Re: 2.0 capri turbo
    Top job. The gauge install would be good as i am looking to fit one at some point.
  35. #115
    Racer 4drmatt's Avatar
    Jun 2007
    Bedford
    2,079
    69
    Re: 2.0 capri turbo
    stunning car
    really like the wheels
  36. #116
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    thanks for all the comments
    if someone want to run a afr guage ( i've got this attached is the instalation instructions i used) that would give a similar indication to the wideband value try programing with the following values:
    1.099v @ 14.08 AFR
    0.103v @ 15.02 AFR
    This gives a very close representation of the AFR reading in Megatune so should show any problems in future.
    i've currently got the other channel on the LC1 as 1-2v = 10-20 AFR
  37. #117
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    well no progress at all now.
    The Lc1 has packed up and am talking to customer services, very quick responce so far.
    was nice to drive it with all the trim in for a bit... oh well off wih the lower dash again, gives me an excuse to look into the tacho again.
  38. The Following User Says Thank You to longboy For This Useful Post:
  39. #118
    Re: 2.0 capri turbo
    No surprise I think mine has packed up but need to really look into it further. If you have a look around the innovate forum they seem to pack in for all number of reasons. The uego ones seem to be rated though
  40. #119
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Well the lc1 has been replaced, took about 3 weeks though. wont get to install it for a while though.
  41. #120
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    well not much of an update on the crappa.
    Due to having probs with my new 'ickle boy and thee mrs going into hospital early have not touched the capri since september.
    was looking for a decent gearbox as i've no confidence in the type 9.
    Then looking the other week looking for a t5 gearbox and ended up getting this...
    it's a left hooker from europe that cant be registered in this country with some slight body work damage and a suspect gasket failure and allegedly had 260bhp which prob means its 200.
    but am happy the whole car was a lot less than this http://cgi.ebay.co.uk/NISSAN-200SX-S13-CA18DET-TURBO-ENGINE-1988-TO-1994-VLM_W0QQitemZ160300355130QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item160300355130&_trksid=p3286.c0.m14&_trkparms=72%3A1299|66%3A2|65%3A12|39%3A1|240%3A1318
    so is this going in the capri? not for a while as i break the nissan and check the engine over, so the capri will be sorted to get running again.
Similar Threads
  1. Replies: 3
    Last Post: 03-10-2003, 23:43
  2. Capri 280 Brooklands Turbo!!
    By Bewy in forum Parts For Sale
    Last Post: 02-10-2003, 20:41
  3. Esc RS Turbo/ 3L Capri drums
    By Mr_Hoarder in forum Parts For Sale
    Last Post: 08-04-2002, 17:40
