Page 1 of 4 1 2 3 4 LastLast
Results 1 to 40 of 140
Thread: 2.0 capri turbo
    Mechanic longboy's Avatar
    Jun 2007
    notts
    438
    12
    2.0 capri turbo
    i admit that this isn't major resto project but there's mod's and fixin' to be had.
    I bought the car for silly money drove it 15miles and it droped to three cylinders
    so after some reading and finding info on the car it was decided to take the head off and found the problem.
    the followers had fallen off the valves, it got worse as it turns out the threads had stripped in the head.
    Pit Crew Turbosport Subscriber Stu.C's Avatar
    Lancashire
    1,785
    Re: 2.0 capri turbo
    Is that picture after it's all been cleaned up, or was there really no oil on the rockers?
    Jun 2007
    UK
    176
    Re: 2.0 capri turbo
    thats abit shit. hope you get her back on the road soon.
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    well the picture of the rockers is after it's been sat a week.
    the saga continued when i tried to find a seperate head.
    At the moment i think every scrappers yard round here knows me know as theres no unleaded pinto injection heads about, but i did find a leaded on for £25 only 10 miles away!
    this left with the problem of a leaded head and wondering what to do, i considered referbing the broken head by drilling and tapping the thread to m16x1 and making a insert on the lathe.
    so after a lot of waiting and trying to make my mind up i sorted the exhaust manifold out as it was warped to hell.
    A plate was knocked out on the cnc miller, though gas axe would have been quicker but i dont have one, and taken to the weldin department to be welded to the manifold.
    original manifold being skimmed, if you can call nearly a mm a skim, level
    Flange being machined
    After welding
    And look how restrictive the original flanges were.
    These were taken back to the plate profle using a 6mm carbide endmill in a air grinder, not exactly safe but very quick!.
    while i was getting this welded up i was talking to our motorsport foundation degree guy, he a top bloke that builds race cars for a living and he suggest just using some addative. so this was the plan the leaded head is going on and i bought a bottle of valve master plus.
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    so the head has been fitted.
    block ready for cleaning
    head bolted on (arp's no less must of been rich that month!)
    priming the oil system, the dissy isn't used for any other than to drive the oil pump anyway, worked a treat for priming the turbo as well.
    rad in.
    when all was bolted on the fule system was primed to pressure only to reveal a leak so new fule hoses were bought, they were expensive and then after paying the bloke said plastic pipes are a third cheeper
    Lancashire
    1,785
    Re: 2.0 capri turbo
    Good to see you're making progress.
    I'm similarly chucking the ValveMaster in until an injection head turns up within my budget - though I didn't realise they were that scarce at the breakers too
    Jan 2006
    southampton
    807
    Re: 2.0 capri turbo
    thats a shame about the head, the cars been around a couple of owners recently but it has good specs and results. good to see you cracking on with it though.
    Aug 2004
    Derby, England
    135
    Re: 2.0 capri turbo
    Sorry about the state of the exhaust manifold.
    I presume you notched out the intake ports on the non-injection head?
    I have to say I'm SERIOUSLY chuffed you're making a proper job of it. You're doing all the things i wish i had given it the time for.
    Keep us all posted.
    John (built the lot up. lol)
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    A lot of respect has to be given to john for providing a good base to work from.
    actualy went to go for a drive but the battery was flat so that will have to wait till later so off to watch transformers it is!
    Aug 2004
    Derby, England
    135
    Re: 2.0 capri turbo
    Thanks dude,
    I know there were a few bits that needed finishing/redoing, but that car will be worth all the work.
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    right then been for my first drive today, only to work about 7 miles.
    The car is running very hot as soon as it is stod to the point that it will overheat at idle.
    Can someone point me to a more suitable rad, think i have seen a ali one somewhere.
    Or dose anyone have any idea think i'll just take out the thermostat for now.
    Oh and i forgot about the old ford fear, whats that rattle, is it miss firing? quick call the AA!
    Nov 2004
    Sweden
    1,167
    Re: 2.0 capri turbo
    It shouldn't overheat with a standard rad as long as the thermostat is OK, the water pump works and the rad is not clogged - and, perhaps most importantly, that timing is not way too late.
    Late timing creates lots of heat so my advise is to double check that first.
    My Pinto turbo has always used a standard 2.0 rad with no problems.
    Gustaf
    Aug 2004
    Derby, England
    135
    Re: 2.0 capri turbo
    Hmmm,, are you sure the electric fan is coming on when you press the switch? Might be worth checking that and maybe even adding the fan switch to the cooling system.
    It never overheated when the fan was on. Cooled it very quickly indeed.
    Another option might be to put the standar fan on, but dont forget the fan shroud.
    Taking themostats out isnt really the best idea...it ruins the flow of the cooling system and can cause hot spots in places. Just change it, though it isnt very old in the first place.
    Apr 2007
    Spain
    Re: 2.0 capri turbo
    What ECU are you running?
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Well the plot thickens.
    Decided to go for a little drive today temp was running fine untill i was just gettin home then it went higher and higher.
    Just as i got onto the drive when coolant started leaking from the botton hose its split in the middle.
    I've a feeling that there was a air lock or the thermosat was sticking, as the fan worked.
    Also the engine wont turn over to start when hot any ideas?
    The car's running megasquirt ecu with the megasuirt-extra code.
    this guy was help full with getting info from the ecu.
    http://www.extraefi.co.uk/
    At the moment is an old code that can't be mapped but have got the new version of the code and a base map to get it running but thats a long way off yet as the money gone till end of august and the probe needs an MOT & service soon.
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Quote Originally Posted by therealpinto View Post
    Gustaf
    Cheers for this i'll look into it and make sure the vr sensor's not moved during tinkering
    Jan 2004
    South Africa
    3,354
    20
    Re: 2.0 capri turbo
    rad fan turning right way around ?
    Hot seizing ?
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Hot seizing? sounds bad!
  19. #19
    Aug 2004
    Derby, England
    135
    Re: 2.0 capri turbo
    Hot seizing??
    Doubt that.
    I would look at the starter motor.
    I dont know what it is but i seem to have a problem with capris and starter motors, perhaps you've adopted the trait through the car.
    Make sure the ECU aint flooding it up, or more likely check the timing isnt too advanced, stopping it dead when its cranking.
    Failing that, check the earth points.
    The engine was checked throroughly when i built it, it wasnt built tight and it wont be tightening up and as long as oil pressure is still there you shouldnt have a problem.
  20. #20
    Mar 2006
    wirral
    36
    65
    Re: 2.0 capri turbo
    wow wot did u dot that?????? it was running mint when my m8 had it
  21. #21
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    just one them things drove it about 15 miles and the head went!!
  22. #22
    west kingsdown kent
    3,590
    Re: 2.0 capri turbo
    i once had trouble starting my old S1 when that was hot.it turned out the battery cable werent man enough because as the heat increases the resistance of the cable increases tooa couple of times i had to get someone to wiggle the cable whilst i tried cranking it until the car actually started turning over.hope this helps.
    tommy 2000
  23. #23
    Pit Crew Decade Plus User bortaf's Avatar
    May 2004
    london
    1,021
    15
    Re: 2.0 capri turbo
    over advanced timing will make it run hot and turn over slow, usually worse when hot
  24. #24
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    had a potter today.
    replaced the bottom rad hose oly to find that the alternator belt was rubbing, the alternator is running upside down to clear the turbo actuator.
    fixed this buy drilling new mounting holes in the rad to raise the rad by 10mm. checked the bonnet closes and tightened every thing up.
    so filled up the rad connected the battery and started her up checked the engine boy to check for leaks...
    tipicly i found on but not from the coolent.
    The fuel return hose from the regulator was pissing petrol.
    Quickly turned the engine off and found some spare hose from when i repaced other fuel lines, the hose was very tight so had to used mr boiling water to help.
    some motivational verbal abuse later the hose was on and tightened up.
    started up the engine again no leaks so warmed it up.
    as mentioned in a earlyer post the temp just rises and dosn't level out.
    got the old stobe out and checked the timing, touble is not sure what idle timing should be on a turbo pinto
    Then as taking the stobe off noticed there was steam comming of the exhaust manifold.
    after i'd stoped shitting myself thinking the head had to come off again looked for the source, now as you cant actual see stean until it cooled a bit this wasn't so easy.
    Anyway there's some droplets of water on the core plug where the alternator should be.
    so now waiting for the engine to cooldown again to retest and see if this happens again.
    Some peole have mentioned the temprimental welders... well the capri will only switch off if the brake pedel is pressed, even if you remove the battery connection it runs for a bit
  25. #25
    Mar 2006
    wirral
    36
    65
    Re: 2.0 capri turbo
    yeh m8 thats coz it has a turbo timer on it lmao
  26. #26
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    ppl keep saying that it's got a turbo timer fitted when i dont agree at the miniute 'cause the turbo timer is still in the box it came in plus the fault is less prominant when the engine is warm.
  27. #27
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    ok a quick update.
    checked the timing and it's between 4 and 8 degrees.
    ran the car on idel for about 40min and made sure the fan cooled it down when switched on.
    Went for a little test drive and seemed ok only a few little niggles.
    1. There's a intermittent misfire that buggin the hell out of me. the ignition leads are getting very hot (to hot to touch) and it needs some suitable plugs
    2. the afr guage will show that the cars fine once then when turned over later shows it to be running lean.
    3. am not used to old school steering being both stiff and wobbly at the same time so i'll have to look into that but it can wait.
  28. #28
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Re: 2.0 capri turbo
    Missfire could be the plugs, graham mentioned that when using wasted spark systems (megasquirt/jolt) that you need to use resisted plugs to take out any possible interference from them as they can cause slight intermittant missfires, i know i had one on mine, hoping they will sort it
    Wobbly loose feeling steering could be play in the rack/bushes etc
  29. #29
    Re: 2.0 capri turbo
    Just to add graham also mentioned about turbo cars needing a good spark check the coil pack and closing the gap down to about 20 thou on the plugs (please check this though i think that it is right though) usually helps this. Like the look of this setup stick with it
  30. #30
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: 2.0 capri turbo
    Front tyre pressure makes an enormous difference on a Capri.
    I would run at no less than 28psi and no more than 30psi. (Well I would run at more than 30 but it wouldn't be responsible of me to suggest it. )
  31. #31
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Thanks for the info guy's.
    have actaly managed to get to work and back twice (7 miles each way) without the fear of it going tits up.
    got a new problem now being about 6'6" my right leg sits between the door handle and steering wheel so turning right is interesting
    so next mod will be to saw 6" off my right leg, i may half to walk like a pirate but i'll be able to drive the capri better.
    funny though never had this problem 10 yr's ago when i was a few stone lighter
  32. #32
    Spanner Monkey carpmart's Avatar
    Jul 2005
    J12 M1 in Beds
    408
    Re: 2.0 capri turbo
    Yep, gapping the plugs to 0.5 mm made a massive difference on my pinto turbo.
  33. #33
    Nov 2004
    Sweden
    1,167
    Re: 2.0 capri turbo
    IMO you shouldn't need to close the plug gaps. I run standard NGK plugs (resistor plugs) on my turbo Pinto with EDIS, standard plug gaps and I have no problems* at 1,4 bar or just over 20 psi.
    Gustaf
    * not with the engine, broke 1 Sierra diff, 1 V6 gearbox and 2 Sierra drive shafts in 2 weeks though
  34. #34
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    Thanks i did gap the plugs but in honesty there were interim standard ngk's.
    Sound like you have a monster there gustaf
    Two day with the joy of driving my toy then it begins again
    http://www.turbosport.co.uk/showthread.php?t=122028
  35. #35
    Aug 2004
    Derby, England
    135
    Re: 2.0 capri turbo
    Quote Originally Posted by longboy View Post
    If you take off the interior trim where the ashtray is, youll see a load of relays and a little clear/pink box. Thats the turbo timer. Its also a remote start thingy, but i never got it hooked up to the alarm.
    Thats what is keeping the engine running when you take the key out.
    I ran 0.6mm gap at 22psi and had no misfire at full boost - If theres no misfire at full boost, the ignition system is man enough for the job. I do think the coilpack is a liability though, considering the heat it gets subjected to.
    As for the steering wobble, i doubt its rack bushes, TCA bushes or ARB bushes - theyre new poly items, and the rack bushes are fecking tight. lol, its also had a new steering rack recently.
    My 2.8i had the same problem on the way to france.....wobbles all over the place. Pulled the wheel off there and noticed a bolt has been snapped off when its had brake disks on it - they just left the snapped bolt in and only used 3!!!!! Amazing. I cant imagine how they thought that would be ok. So my problem is warped disks, and considering how shit capri brakes are i wouldnt be suprised if warped disks are what is causing your wobble. Either that or its an unbalanced wheel.
    In fairness they were a little bit warped when i sold it. (i kill the brakes on EVERY car i drive for some reason )
  36. #36
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    cheers for that i must drive sumpatheticly cause the timers never kicked in when warm, i do drive the last few miles of a journey off boost though to let the turbo slow down.
    Quote Originally Posted by CapriMMIV View Post
    well i tend to change pads when i hear metal on metal
  37. #37
    Aug 2002
    Geordie Land
    2,232
    Re: 2.0 capri turbo
    timing should be set at 10degrees btdc at 900 rpm
    MY MK1 ESCORT (Now turbo'd)
  38. #38
    Nov 2004
    Sweden
    1,167
    Re: 2.0 capri turbo
    With programmable timing you can try different idle timing figures to get the best out of the engine. My turbo Pinto seems to like to idle at about 15 degrees, makes it more responsive off idle also.
    In general I feel that the Pinto with lowered compression often can take a lot more timing than you think, off boost. I run 45 degrees or close to that in some areas...
    Gustaf
  39. #39
    Jun 2007
    notts
    438
    12
    Re: 2.0 capri turbo
    with a couple of threads about motivation being posted recently i thought i get of my arse and tinker.
    I've bought a 2.8 axel, a spare prob & starter motor so o thought id start small and fit the starter. After 40mins the bolts finly came out only to fine the £5 spare starter has different connections went to fit the original starter back on and now the bolts wont tighten so i'll have to run a tap down them.
    Have NO motivation at all now with every "liitle" job being a bitch.. Wanted to cut my losses today and sell up it'll pass.
  40. #40
    Spanner Monkey Turbosport Subscriber drev's Avatar
    Sep 2007
    bilsthorpe newark notts
    284
    Re: 2.0 capri turbo
    How you getting on mate? If you need a hand i'm only up the road.
Similar Threads
  1. Replies: 3
    Last Post: 03-10-2003, 23:43
  2. Capri 280 Brooklands Turbo!!
    By Bewy in forum Parts For Sale
    Last Post: 02-10-2003, 20:41
  3. Esc RS Turbo/ 3L Capri drums
    By Mr_Hoarder in forum Parts For Sale
    Last Post: 08-04-2002, 17:40
