Results 1 to 7 of 7
Thread: Mondeo 2.0 195HP N/A
    Jan 2007
    Slovenia
    2.0 Zetec
    catcams
    4-2-1 manifold
    hayabusa bodies
    megasquirt
    Attached Thumbnails Attached Thumbnails 1.JPG‎
    2.0 Zetec/ST170 N/A 270HP
    I support TS Decade Plus User
    alladdin's Avatar
    58
    9,959
    150
    Re: Mondeo 2.0 195HP N/A
    any chance of a copy of your ms map ? and what cams are"catcams." cheers. mike.
    Jan 2007
    Slovenia
    My map won't help you much cause your spec would need to be identical.
    Just stick to AFR 12.7 for max power.
    cams:
    duration [0.1mm+cl] 274 266
    duration [1.0mm+cl] 246 238
    valve lift [cl=0] 10.90mm 10.45mm cam lift
    peak angle 110 110
    timing [1.0mm+cl] 13/53 49/ 9
    lift at TDC [cl=0] 2.50mm 2.05mm
    Jul 2004
    Reading
    1,517
    The calculation of loses does not look right to me. How did they calculate it?
    Zetec Mk 1 Escort
    Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
    Mk 1 XR4i
    Mk 3a Fiesta Si
    www.zetecescorts.bravehost.com
    Jan 2007
    Slovenia
    Quote Originally Posted by Zetec_Escorts View Post
    The same way all dynos do (deceleration). I went to two different dynos and losses were the same.
    I think it has to do with the fourt gear beeing quite long.
    A nother zetec that posted here got similar power on wheels and fly on a mondeo supercharger.
    Dec 2008
    Finland
    33
    374
    What have been done to bottom end? Those camshafts work fine with std pistons etc? Looking info fo 190-200hp 2.0l silvertop setup. You used these cams? http://www.catcams.co.uk/acatalog/info_108.html
    Mar 2007
    Hartwell
    166
    Seems a bit on the high side , what wheel power was it ?
Similar Threads
  1. mondeo
    By RETRO_AL in forum Ebay section
    Last Post: 18-08-2004, 19:09
  2. mondeo T reg
    By lardy in forum Parts For Sale
    Last Post: 01-07-2004, 08:43
  3. 2.0 Mondeo
    By barrym in forum Parts For Sale
    Last Post: 18-06-2004, 14:45
  4. 2.0 Mondeo
    Last Post: 15-06-2004, 17:33
  5. Mondeo 4x4 si
    By babydave in forum General Car Banter
    Last Post: 23-11-2003, 15:21
