Results 1 to 5 of 5
Thread: Bosch lambda sensor part number
    Jun 2006
    Durham, UK
    1,494
    Anyone have the part number for the lambda sensor as used on the 4x4 L8 ecu models with closed loop fuelling? It's a 3 wire, m18 threaded part. MSD have a compatible Bosch sensor listed on their site, but it's a rather cheeky £62 and I'm fairly sure the generic Bosch part doesn't cost that much, since it's not badged as a Cossie part, as such.
    May 2004
    Norn Iron
    1,142
    Re: Bosch lambda sensor part number
    Any generic wire cheapy should do fine.
    How long the cheap ones last is another matter
    Jun 2006
    Durham, UK
    1,494
    I think I managed to find this out today - it looks like the part MSD sell is a Bosch LS02 unit (there's a much longer part number available if you search for Bosch LS02); it's a standard 3 wire connection with m18 thread.
    I saw threads on Passionford talking about Titanium lambda sensors being recommended as they're faster responding, but they're stupid money compared to the Bosch.
    3,241
    Honestly a 3 wire sensor is purely narrow band and not suited to a performance application that required richer fueling - narrowband are only accurate at or around 14.7:1 AFR! Try here for wide variety of sensors... http://www.lambdasensor.com/main/muniversal.htm. Two same colours are heater + & - the other is the signal. M18 thread is universal.
    Jun 2006
    Durham, UK
    1,494
    It's all the standard L8 ecu is wired up to do, unfortunately. I've only got a relatively basic setup: group A head gasket, dark greens, -31 actuator and a upgraded T3 along with the MSD chip to suit - maybe 330bhp.
    The closed loop setup only works on part throttle; it's disabled on startup, high boost and high rpm, from what I've read; it really just improves economy at part throttle (steady speeds).
