Results 1 to 2 of 2
Thread: What TPS???
    Spanner Monkey Krusty Crapa's Avatar
    Sep 2006
    Kent
    326
    What TPS???
    I want to change over to Megajolt Lite Jnr on my pinto and keep the 45s, I know weber do a TPS that is a direct fit but is there anything else I could rob one from at the scrappy's. Maybe a bit cheaper that will work with MJLJ.
    Any one done simmilar ??? Pictures???
    Oh and does anyone know the part number for the Ford trigger wheel that seems to get used on these setups??
    Jul 2004
    Reading
    1,517
    Re: What TPS???
    You need a TPS and EDIS 4, best place is an early mk5 Escort. A ZETEC TPS should work to.
    Zetec Mk 1 Escort
    Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
    Mk 1 XR4i
    Mk 3a Fiesta Si
    www.zetecescorts.bravehost.com
Similar Threads
  1. TPS
    By Wolfie in forum The Technical Section
    Last Post: 16-02-2005, 09:24
  2. TPS Codes PF02? Whats it from?
    By Jon_ERST_S2 in forum The Technical Section
    Last Post: 08-08-2004, 19:01
  3. TPS
    By fozzy in forum Cosworth Installations
    Last Post: 18-03-2004, 09:50
  4. escos TPS reading
    By DaveHenshall in forum The Technical Section
    Last Post: 29-09-2003, 13:56
  5. TPS Codes PF02? Whats it from?
    By Jon_ERST_S2 in forum Message Centre
    Last Post: 14-09-2003, 16:44
