If the Quaife hubs and the spigot are machined to the same dimensions as the std flange on a std Atlas shaft then you should be okay to fit the drums.The back plate should bolt on as normal. You may even be lucky and manage to leave the caliper brackets on the axle, it all depends on where the brks are fixed.I am sure someone must use that set up for Historic Rally Regs.
If the quaife atlas ones are the same as English one, not meaning literally. There is a difference of app 10mm over std ones so backplate may need packing to bring the shoes back into line.
