Results 1 to 6 of 6
Thread: Xflow only starts when you let go of the key
    Oct 2008
    whitley bay
    2,436
    89
    I have read about this happening before But cant find the post now.
    I have just rebuilt my xflow and it turns over lovely and fast and starts quite well but only if you crank it for a while and then let go of the key
    Nothing has changed spec wise so im a bit stumped
    Hexham and District Motorclub
    I support TS Turbosport Subscriber sholdowa's Avatar
    Christchurch, New Zealand
    64
    521
    35
    Re: Xflow only starts when you let go of the key
    had a rs2 that did this in the cold years ago. it was only when I burnt out the starter i found the 12 volt supply to the coil on cranking had fallen off
    Oct 2008
    whitley bay
    2,436
    89
    I only have battery lead and starting lead to the starter
    4,889
    That is probably the cause. (no +12V supply to ignition when starting)
    Oct 2008
    whitley bay
    2,436
    89
    So should i put 12 v to tge coil from the ignition switch?
    Oct 2008
    whitley bay
    2,436
    89
    Just tried it now with the battery fully charged and it started on the key fine
    So only when the battery is slightly down
