Results 1 to 5 of 5
Thread: 2.8i running crap
    Mechanic Mr_lizard's Avatar
    Jan 2006
    Southend, Essex, Innit
    673
    2.8i running crap
    I've had an issue with my Capri for a while, when its at idle or light throttle openings upto about 1500 rpm it tends to hunt a little. It's not a misfire, it almost sounds like all 6 cylinders fire, then theres a second pause before they all fire again! I've replaced dizzy cap, rotor arm, plugs, done valve clearances, set timing to 12 degrees btdc and its done nowt. Any ideas?
    One day people will stop asking 'Is that bit of your car supposed to be hanging off/leaking/on fire like that?'
    Spanner Monkey mihakrapez's Avatar
    Jan 2007
    Ljubljana, Slovenia, Slovenia
    281
    18
    Re: 2.8i running crap
    I had the same problem.
    There is a piston in the injection that brakes once in a while.
    It stops to move and engine gets too mutch gas. The injection unit a a bit tricky to take apart.
    Regards,
    Jul 2004
    Reading
    1,517
    Try a new fuel filter and some injector cleaner first.
    Zetec Mk 1 Escort
    Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
    Mk 1 XR4i
    Mk 3a Fiesta Si
    www.zetecescorts.bravehost.com
    Jan 2006
    673
    Cool, thanks fellas. I'm gonna try all of that, i've got a second hand metering head from a turbo technics capri so i'll take the block out and try that.
    Jan 2006
    673
    All sorted now- changed the metering head and it runs sweet as you like. The new one sticks shut slightly- it takes a second or two of turning over before it'll start but runs fine, I'll clean it out when I get a minute. Cheers all!
Similar Threads
  1. Footie is crap
    By Cosnada in forum Message Centre
    Last Post: 13-06-2006, 21:20
  2. Crap video..Crap cars lol
    By cossymax in forum Movies
    Last Post: 29-08-2005, 01:46
  3. More crap from me
    By Esme in forum Jokes
    Last Post: 29-10-2004, 16:46
  4. CRAP
    By ^Mick^ in forum Message Centre
    Last Post: 21-09-2002, 23:15
