Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 40 of 245
Thread: 1.6 Zetec SE engine
    Ireland
    36
    3,588
    174
    1.6 Zetec SE engine
    There doesn't seem to be anything on this site about the Zetec SE engine so I want to start a discussion on this relatively new and undiscovered high reving highly tuneable engine.
    The Zetec SE is known in the US as the Sigma engine,
    and later 1.6 Zetec SE's with variable valve timing are labelled as Duratec Ti-VCT (Twin independant Variable Camshaft Timing) engines.
    The engine comes in 1250cc, 1400cc, 1600cc, and 1700cc.
    They are fitted in ford Fiesta, Focus and Puma.
    The 1700cc engine only comes in the puma and the racing puma delivers 155bhp at 6000rpm.
    The 1.6 litre unit produces 99bhp at 6000rpm and 104ft.lbf at 4000rpm and 115bhp with variable valve timing.
    This engine is very popular in the kit-car market because of its low weight and easy tuneability.
    Yamaha helped to design this all alloy lightwieght powerplant which only weighs 82kg!
    With heavy duty con-rod bolts fitted these engines can rev to 8000rpm.
    Shawspeed say you can get 220bhp out of the 1600cc unit with the standard size valves!
    That is 137.5bhp per litre!
    Shawspeed sell tunning kits from 120bhp right up to 210bhp.
    Here's a link to the Shawspeed website.
    http://www.shawspeed.com/fsigma.htm
    Another Zetec SE tuner is BPJ services.
    If you click on Duratec 1.4/2.5 offer in the website you will see some more information.
    http://www.information.gb.com/bpjservices/frame.html
    Another link below
    http://www.dervman.com/zetecseengine.htm
    In my opinion this engine is as good if not better than the 1.6 BDA engine.
    You can get just as much power from a Zetec SE for a fraction of the cost of an expensive BDA.
    For a mk2 escort competition rallycar 200bhp is easily achievable with,
    A Pair of 300 degree 10mm lift cams + HD springs,
    Vernier pulleys,
    Ported and flowed head,
    Forged pistons and rods,
    45mm throttle bodies + a programable ECU,
    (Or possibly 45mm webbers with a belt driven vauxhall distributor instead of TB's and ECU)
    11 to 11.5 compression ratio,
    Competion bronze bearings.
    This engine would be ideal for rallying or racing in a modified 1600cc class and would also make a very good fast road engine when tuned to about 160bhp.
    If you have any other info please add it to this Thread.
  2. The Following 3 Users Say Thank You to RWD fords rule For This Useful Post:
  3. #2
    Jan 2006
    Norfolk
    994
    Re: 1.6 Zetec SE engine
    Or you could do what I have done and Supercharge it
    I used Paul Jackson at BPJ Services, very helpful guy and easy to deal with, Shawspeed did not even return my calls - make of that what you will
    Bellhousing available for Type 9:
    1.6 is 120hp standard from memory
    It was not done in conjunction with Yamaha, it was a Yamaha design with no Ford involvement
    Figures look good for 200+ on standard internals with the supercharger set up
    More when I think of it
    HTH
    Dom
  4. The Following User Says Thank You to cr500dom For This Useful Post:
  5. #3
    Jul 2006
    bristol
    11,509
    902
    I had a 03 focus with one of these engines in it said on the spec sheet it was 115BHP
  6. #4
    Dan's Avatar
    Aug 2006
    north london
    5,765
    i guess its because it dosnt follow ford bolt patterns like other zetecs do, so im not sure it would be that much cheaper than say a duratec. other than being lighter and in smaller capacities i cant see a benifit... unless of course it is much cheaper to get in and running
  7. #5
    Jan 2006
    Norfolk
    994
    Quote Originally Posted by steely dan View Post
    But if you are running in a Capacity class of up to 1600 then it makes a lot of sense.....
    Imagine Andy Pipes Mk1, as light as it is and with great handling and then add an even lighter engine - with 220hp Normally aspirated
    If you are capacity limited its a great engine and in something like an Anglia would be superb
    HTH
    Dom
  8. #6
    Dan's Avatar
    Aug 2006
    north london
    5,765
    yep, sorry dom thats what i meant with the 'smaller capacities' comment
    i want to get into sprints/hillclimbs and most have a upto 1400 class, it would be mega bucks to get a 1400 xflow to the same power of the sigma unit, and the same goes for the 1600. so it does look like an attractive alternative, although dont the regs limit engine choice to orginal units, and you end up in the sports libre class, excuse the ignorance if im wrong, not read too much into it yet
  9. #7
    May 2007
    cleveland
    my mates got a 1.6 SE in his westfield - runs sprint races and he wins with it!!!!
    getting 130 bhp at the wheels right now - but the big advantage he says is the weight - ally block and ally head is the big advantage - in a lightweight car the handling set spot on and its worth another load of BHP as well as being able to throw it round corners and really incredible speeds.. glued to the road it is..
  10. #8
    Jan 2006
    Norfolk
    994
    For sprints in an escort you will be in sports libre yes so it make sense to go as big as you can then, and a supercharger for good measure
    The Sigma engine and type 9 box even with the supercharger and chargecooler fitted is lighter than the 1200cc Iron Kadett motor and gearbox that came out
  11. #9
    Sep 2007
    wakefield
    28
    i have fitted a se engine in my ka, with loads of bits from shawspeed, they were hard to get hold of, but were great once i did, cr500dom looks like a phase 1 engine you have there, did you look at getting a phase 2 or did it come up at a good price?
  12. #10
    Racer Decade Plus User Si_Steve's Avatar
    Jan 2006
    Aberdeenshire
    33
    3,352
    10
    I agree its a crackin motor, i have the 1250cc engine in my car and for what is essentially a 1.2 engine its quick, ok the torque isnt great in it(i'e uphill with loads in the car)but 3000rpm plus and its off and pulls right up to 5500rpm.........even tested out the limiter 6900rpm, better than the 6400 that wasin my old 1.6 fezzy si
  13. #11
    May 2006
    yorkshire
    482
    sounds like a great little engine,need 200hp,what engine parts do i need ,do partts of a 1700 s fit the 1600s. need advice from someone who ,s been there done that,,,please reply chris,hi wide ladyboy ka.......
  14. #12
    Jun 2007
    Maidenhead
    18
    does the SE have the same inlet and exhaust pattern as the Zetec E?
    have a spare ST170 manifold at home and I'm curious if I could bolt it on a SE?
  15. #13
    Jan 2006
    Norfolk
    994
    Quote Originally Posted by zetecdamien View Post
    Nope totally different...... opposite sides of the engine as well Zetec E is RH Inlet, Zetec SE is LH Inlet
  16. #14
    May 2008
    warrington
    243
    Hi first post on this forum, so go easy!
    I have a zetec se in my Darrian on jenveys and omex ecu...it is dry sumped. Does anybody do a water rail to allow fittment of one to a mk2 escort ? also is a rwd exhaust manifold available ?
  17. #15
    Feb 2005
    Norway
    444
  18. #16
    Ireland
    36
    3,588
    174
    I bought a new 1600 zetec se crate motor from ford and I will be fitting it into my mk2 escort rallycar over the summer.
    I will be making up all the conversion parts myself, chassis engine mountings, propper 4 into 2 into 1 tuned length tig welded manifold, water rail, big wing baffled sump, etc.
    I was wondering if many other people on here would be interested in buying the conversion parts from me through ebay, the parts would be high quality and rally tested to ensure easy fitment and relaibility. The price of the parts would be very reasonable aswel.
    It will take some time to develop/test the parts but I should be well on the way by the end of the summer.
    Let me no if you would be interested by posting here,
    I will creat a new post with pics of all the parts when I have them finnished.
    Watch this space
  19. #17
    May 2008
    warrington
    243
    Hi Fella
    Yes deffinately interested. We have one of these engines in our Darrian, see photo below. It's dry sumped, with head work and cams and is on Jenveys. We are hoping to put one in our MK2 escort we are starting to build into a rally car, so your kit would be ideal. Belhousings are readily available already.
  20. #18
    Ireland
    36
    3,588
    174
    Quote Originally Posted by Moggy View Post
    Hi Fella
    I bought a dummy engine, new bellhousing, clutch, etc for mockup and will be starting to make up the parts soon, I will let you no when I have some of the parts made and send pics.
    Where did you buy the dry sump kit from and does it mount on the exhaust or intake side of the motor?
    Any info on what your engine spec is in your darrian?
    Looks good by the way.
    Thanks for the interest.
    Jason.
  21. #19
    24,348
    255
    yes andy pipes car would handle and go better, but such an engine swap would put him in the same class as a 550bhp 4wd wrc escort and bonkers horse power Skylines, the same being true of hill climbs and sprints, engine swaps put you in the anything goes sports libre class
  22. #20
    Jan 2008
    Sidcup
    112
    i have zetec se engine for sale 295 ono 66k 07786610006 scott
  23. #21
    May 2008
    warrington
    243
    Jason.
    Dry sump kit was from PACE oils systems.....LONG WAIT.....about 6 times as long as quoted, so if you want one of these plan ahead (got many many excuses)...when it arrived was missing a pully (never supplied)....Shawspeed made/modified one to fit in the end..... and one of the fittings was the wrong size (eventually sorted after several more phone calls)...this fitting then leaked due to crappy oil seals (sorted by fitting the ones from the original 'wrong' fitting)....anyway rant over.....pump fits on the inlet side.......if you are going dry sump, suggest you get the kit BEFORE you make engine mounts as we threw away the mount in the kit and used a combined engine/pump mount we made....quite easy and MUCH better for our application. To be fair the pace mount is nicely made and may well suit most other cars.
    They do two types of pump...twin scavenge only (this uses the original engine pump to supply pressure, which is what we have used).........or twin scavenge and pressure in which case you dispense with the engines original pump.
    A tip used on the Darrian, due to the oil tank being a lot higher in the car than the engine....If you go dry sump (I would) then make sure when you wire teh car so you can switch off the ECU allowing you to crank the engine without it firing, this is so that if any oil has migrated back into the engine when standing it is pumped out in a few seconds before you fire her up.
    Due to the shape of the darrian engine bay and mounting we couldn't fit the oil filter so its now on a remote (easy)
    Engine is from Shawspeed, has head work, cams, verniers, jenvey direct to head throttle bodies and is on Omex 600 management. Flywheel/clutch came from Scholar engines (I am sure Shawspeed could have supplied this actually).
    The engine had done 11000 miles in fiesta (crashed), and shawspeed lent us a bare block and head to use whilst we did the install. Exhaust was custom made in stainless to Shawspeed's specified lengths.
    Shawspeed are very good quaility and value I found and clearly know their stuff.
    Let us knwo how you get on....these engines will be superb for a 1600 class escort, small light, decent torque and if you do it with webbers (as we will when we do one for the escort), quite reasonable price....you can get some ideas from www.shawspeed.com
  24. The Following User Says Thank You to Moggy For This Useful Post:
  25. #22
    Ireland
    36
    3,588
    174
    Hello
    Moggy, what size exhaust pipe are you using on your darrian?
    I'm not sure wether to use 1.625" or 1.75" outside diameter.
    Also what shawspeed cam are you using and what BHP does your motor have?
    Regards
    Jason.
  26. #23
    Racer Decade Plus User angliaant's Avatar
    Dec 2006
    Essex
    28
    2,556
    33
    mmm i did look at this a fair while back but was persuaded against the idea but when you start talking about 200 brake it gets me interested, and now im cutting the bulkhead anyway
    any idea what sort of power a 1.4 lump would make, home built etc, not wanting to spend thousands of pounds to get it to fit into the hole?
    im guessing the most expensive bit will be sorting the sump out?
    thanks Guys !
  27. #24
    Dec 2006
    Essex
    28
    2,556
    33
    ohhh reading that maybe the 125 is a better option?
    insurance is the main issue for me, or lack of...
    thanks Guys !
  28. #25
    Dec 2006
    Essex
    28
    2,556
    33
    one me thing... can this lump be set up to run a dizzy, from the canshaft pulley? if so does this do alway with all that posh expensive electrical stuff?
    thanks Guys !
  29. #26
    Jul 2004
    Reading
    1,517
    Quote Originally Posted by angliaant View Post
    I will cost less to fit and ECU than bodging a dizzy. The fuel saved alone will be worth it let alone the improved response etc. It is crazy to fit a modern tuneable engine then de-tune it!!
    Zetec Mk 1 Escort
    Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
    Mk 1 XR4i
    Mk 3a Fiesta Si
    www.zetecescorts.bravehost.com
  30. #27
    Dec 2006
    Essex
    28
    2,556
    33
    mmm i think im genna go for this,use a megajolt and some special carbs
    the big question is 1.2 or 1.6? insurance is main issue
    thanks Guys !
  31. #28
    Dec 2006
    Essex
    28
    2,556
    33
    anyone got the measurements of one of these lumps please?
    thanks Guys !
  32. #29
    Dec 2006
    Essex
    28
    2,556
    33
    got thmeasurements... im going to make a Computer generated model with dimensions on if anyones interested?
    thanks Guys !
  33. #30
    Jan 2006
    Aberdeenshire
    33
    3,352
    10
    after reading this thread again im tempted to chuck a 1.25 into the escort, how hard would it be really, and want to keep it 1.25 for revvyness (and it woulndt be very standard)
  34. #31
    Dec 2006
    Essex
    28
    2,556
    33
    im now on the lookout for a 1.6 se lump
    where does the bellhousing for the type 9 come from please ?
    thanks
    ant
    thanks Guys !
  35. #32
    East Sussex
    5,232
    Just standard sierra/cortina fo a cast one or rs2k for an alloy 1
  36. #33
    Dec 2006
    Essex
    28
    2,556
    33
    Quote Originally Posted by Pushrod King View Post
    really? thats good, will save a few quid there then
    thanks Guys !
  37. #34
    Brum Town
    1,865
    26
    thats not quite right as they are different, so you can't just pilfer one from a car.......try the links above for one mate
  38. #35
    Dec 2006
    Essex
    28
    2,556
    33
    Quote Originally Posted by seventynine View Post
    yep matey i worked that out... burtons do one... thanks bud
    thanks Guys !
  39. #36
    Jan 2007
    UK
    I have a 1.6 Zectec SE with gearbox and a good number of anciliaries (all the inlet, catalyst, clutch, etc).
    It was removed from a brand new undamaged project car about 8 years ago and has been in the garage ever since, bores oiled and occasionally turned over. It has done zero miles !
    I'm in Worcestershire and open to sensible offers if anyone is interested,
    John 01386 442776
  40. #37
    Bodger topfuel's Avatar
    Jun 2007
    maesteg
    126
    if you guys can hang on for 6-8months, i'll be starting to build 1600turbo motors.. well fords will be any way. and as i work there i may just get hold of one....
    cheers terry
  41. #38
    Ireland
    36
    3,588
    174
    I can supply a new Zetec SE alloy bellhousing to suit a type 9 gearbox for 200 + delivery if your interested send me a private message, I can also advise a suitable clutch.
    Jason
  42. #39
    Dec 2006
    Essex
    28
    2,556
    33
    Quote Originally Posted by topfuel View Post
    cheers terry
    Awesome news what sort of power are they expecting?
    Jason
    sorted now thanks fella
    thanks Guys !
  43. #40
    Nov 2008
    Moscow, Russia
    Hello from Russia!
    You have interesting forum
    I own a Ford Focus MK2 with modified 1.6 L I4 Zetec-SE (100hp) now called Duratec.
    From wiki
    The engine line up for the Mk 2 is a mixture of old and new. Revised versions of the 1.4 L and 1.6 L all aluminium Zetec-SE engines from the previous generation Focus were carried over, although the units were now renamed Duratec, with the addition of 1.6 L Duratec Ti-VCT engine with variable valve timing.
    http://en.wikipedia.org/wiki/Ford_Focus_(international)
    gearbox is ford IB5
    I would like to tune it. Can you help me? What mods are possible for my engine?
    Sorry for my english.
    and forgot to add
    He looks so
Similar Threads
  1. which zetec engine
    By rcmex in forum Zetec Installations
    Last Post: 04-02-2007, 18:00
  2. zetec engine
    By oliver in forum Ebay section
    Last Post: 03-08-2006, 22:23
  3. zetec engine
    By toe jam in forum Zetec Installations
    Last Post: 09-06-2005, 01:11
  4. zetec engine
    By matt24 in forum Parts For Sale
    Last Post: 12-11-2004, 20:33
  5. zetec engine need help.
    By damon in forum The Technical Section
    Last Post: 22-05-2003, 12:35
