Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 161 to 200 of 246
Thread: 1.6 Zetec SE engine
  1. #161
    Dec 2008
    Finland
    2,106
    62
    Re: 1.6 Zetec SE engine
    Does the Zetec SE engine block have the same bell housing bolt pattern as the Duratec HE?
    As the SE is MZI in Mazdas could I use Mazda MX5 / Miata gearbox with the SE?
  2. #162
    Dec 2008
    Finland
    2,106
    62
    Quote Originally Posted by Roadsport View Post
    To answer my own question. No. I looked at the Ford E- cat spare part software today and no the pattern is not the same. The Zetec SE 1.6 IB5 box will not fit Duratec HE block. The Fiesta ST uses special cast housing in IB5 box to mate with Duratec.
  3. #163
    Jul 2008
    Poland
    9
    I don't want to start new thread so i will ask here.
    Does anyone have information about dimmensions of piston compression height, deck height, conrod lenght for Zetec SE family? (1.25, 1.4, 1.6, 1.7)
  4. #164
    Dec 2008
    Finland
    2,106
    62
    Quote Originally Posted by feluke View Post
    1.6 Zetec SE
    Stroke: 81.4mm
    Bore: 79mm
    Comp. height 25mm
    Rod: 138mm
    Pin diameter 18mm
  5. The Following User Says Thank You to Roadsport For This Useful Post:
  6. #165
    Jul 2008
    Poland
    9
    1.6 Zetec SE
    Stroke: 81.4mm
    Bore: 79mm
    Comp. height 25mm
    Rod: 138mm
    Pin diameter 18mm
    Thx a lot.
    If you find same data for other displacemants, post it. I'll be in debt to you.
  7. #166
    Dec 2008
    Finland
    2,106
    62
    Have not really been interrested in the other Zetec SE's
    But heres something I got.
    1.7
    Bore 80mm
    Stroke 83.5mm
    Compression ratio: 10,3:1
    1.25
    Bore: 71.9mm
    Stroke 76.5mm
    Compression ratio 10:1
    1.4
    Bore 76mm
    stroke 76.5mm
    compression ratio 10,3:1 later focus 1.4 models had 11:1
    To add to the 1.6 Zetec SE I noticed It has the highest compression ratio of the Zetec SE family standing at 11:1 .
  8. #167
    Sep 2009
    Istanbul
    What is the compression ratio you would like to have?
    If you will use stock 100 hp astra rods and pistons your new CR would be 7.8:1
    Good CR for a stage2 turbo application.
    Astra rods big-end radius diameter is more narrow vs SE. So you'll need some machine job for using n SE.
    connecting rod big-end diameters:
    Astra : 46.4mm
    Focus : 46.9mm
    You can find forged rod and piston set for astra. Wiseco end Woessner producing forged internals for astra
  9. #168
    Dec 2008
    Finland
    2,106
    62
    http://www.turbosport.co.uk/showthread.php?t=145051
    Posted some engine build pics in the my competition car section if someone is interreted in Zetec Se builds.
  10. #169
    Dec 2008
    Finland
    2,106
    62
    Quote Originally Posted by topfuel View Post
    just hang fire boys fords are building a turbo 1.6 sigma. should be avilable in about 6mouths or so... i did tell ya tho right
    Your prediction seems to be right. Is this the all new Ecoboost 1.6 engine announced eith the new C-max.
    Can you tell us more?
  11. #170
    Dec 2008
    Finland
    2,106
    62
    Found a picture of it off another forum.
    Click image for larger version Name:	ecoboostengine01.jpg Views:	38 Size:	330.7 KB ID:	37241
  12. #171
    May 2008
    warrington
    58
    243
    If anybody wants to hear what a Shawspeed 1600 zetec SE sounds like from in car....here is footage from our Darrian last week...........you can see the rev counter.
    http://www.youtube.com/watch?v=-e992NPlpEEYouTube- Darrian 1600 - Glyn Stages 09 - Ty Croes.
    Loving this engine!
  13. #172
    Bodger topfuel's Avatar
    Jun 2007
    maesteg
    125
    hey there roadie no prediction.. engine should be in production by june/july 2010. its been put back a few months. only problem i can see is fuel surply as the ecoboost uses fuel at 2500psi.
    cheers terry
  14. #173
    Feb 2009
    Near Milton Keynes
    36
    58
    ^^^ is it GDI then?
  15. #174
    Dec 2008
    Finland
    2,106
    62
    Quote Originally Posted by Moggy View Post
    Loving this engine!
    Sounds very nice!
    The gear ratios seem to suit the engine quite well. Continues nicely after a gear change.
    What was that event? Looked a little bit like a sprint race. But other competitors on a same lap?
  16. #175
    Dec 2008
    Finland
    2,106
    62
    Quote Originally Posted by mikey p View Post
    ^^^ is it GDI then?
    Yes. Thats what the Ford announcement on the new engine stated.
    Hopefully it'll be more reliable than the Duratec SCI
  17. #176
    Dec 2008
    Finland
    2,106
    62
    cheers terry
    "Roadie" .. heh..
    How about the crank and rods? Are they the same as we've seen on a Sigma?
  18. #177
    Jun 2007
    maesteg
    125
    crank and rods should be the same as a sigma as this engine is only a upgrade of the sigma. just a bit stronger. so with luck most of the parts will be interchangeable!!! dut dont take my word for it...
    cheers terry
  19. #178
    Dec 2008
    Finland
    2,106
    62
    Zetec SE in an MK1
    Installed a Zetec SE to my Escort yesterday.
    So now I know it can be done without any dramatic changes to body work. The engine needs to be Dry Sumped tough to clear OE steering rack. And youll need the RWD water outlet to not hit the bulkhead. Still comes very close even with the RWD outlet.
    Some pics in the bottom of the build page:
    http://www.turbosport.co.uk/showthre...=145051&page=4
  20. #179
    Nov 2009
    braintree
    Hi, Im sorry to hijack thios thread a bit but this is a brilliant pic, can anyone tell me which is the tensioner for the auxillary belt please?
  21. #180
    Sep 2007
    wakefield
    28
    Quote Originally Posted by Gtiracer View Post
    far left, rear of the block
  22. #181
    Sep 2007
    wakefield
    28
    Quote Originally Posted by Garry.m View Post
    cheers for that
    its a pitty everythings painted black . I've just spotted that he's moved the pas pump up to where the alternator used to be . Whats the score with 2 and 3 wire alternators ?
    Only a week til Paul at BPJ is back
    thread from the dead, but that was my car, happy to offer any advice if you get stuck
  23. #182
    Apr 2009
    Peterhead
    11
    Quote Originally Posted by wide ka View Post
    i think I'm going to give up on the 1.4 zetec engine conversion ,,engine mounts are begining to be a pain in the a$$ ,,really want to build strong mounts suitable for ralling !
    Thinking of re-fitting the std 1.3 challenge spec engine and selling the car
  24. #183
    Sep 2007
    wakefield
    28
    you only ned to do the one mount, o/s engine mount, and its not hard if you really wanted to you would just plate the area where it mounts to to add strength, far better than old ohv engine, you can see 150bhp on standard internals no probs
  25. #184
    Dec 2009
    Southern Ireland
    632
    35
    So which mounts were on yours mate? Fiesta or Ka? I assume you mean that the only one needing specialist work was the Driver's side one?
    I also plan on installing one of the 1400s into a Rally KA...
  26. #185
    Apr 2009
    Peterhead
    11
    Do you have any better/close up pic's of your mount ?
    Cheers , Garry
  27. #186
    May 2010
    manchester
    Hi ive stripped my 1600se engine down for inspection and from what i can see there is very slight marks on the crank.its very slight pitting mark but ever so slight,its not a deep gouge or anything.would i need to get the crank reground?would i be ok with new shellls
  28. #187
    Nov 2003
    Wirral UK
    6,740
    257
    Can you get pics?
    If the marking is slight then you'll probably get away with a light polish (400 grit emery paper and oil) and new shells, though of course you should always check the bearing clearances with plastigague.
    http://escort.accelerator.org
  29. #188
    May 2010
    manchester
    can the zetec se cranks be reground?i heard it wasnt possible.
  30. #189
    Nov 2003
    Wirral UK
    6,740
    257
    Anything can be reground, it depends on whether you can get undersize shells to suit.
  31. #190
    May 2010
    manchester
    Thanks for the reply.if the scoring was only light would i get away with just fitting new shells?
  32. #191
    Nov 2003
    Wirral UK
    6,740
    257
    You'd have to measure the bearing clearances with Plastigauge and check to see if they're still within tolerance.
  33. #192
    Dec 2008
    Finland
    2,106
    62
    Anyone have any info on the Raceline Sigma-R engines? The web site is not all that informative.
  34. #193
    25,110
    sometimes even engine for which there arnt shell available they can be found by carefull reading through a bearing catalog, and finding an alternative bearing that wil fit the con rod
  35. #194
    Jul 2010
    donegal ireland
    Hi
    just been reading up on fitting a 1400 Zetec se to my MK2 ESCORT RALLY CAR
    Woundering what parts to use
    Bellhousing Inlet Manifold for twin webers rwd Exhaust manifols Water rail etc
    Do you have any parts for sale
    thanks
    I bought a new 1600 zetec se crate motor from ford and I will be fitting it into my mk2 escort rallycar over the summer.
    I will be making up all the conversion parts myself, chassis engine mountings, propper 4 into 2 into 1 tuned length tig welded manifold, water rail, big wing baffled sump, etc.
    I was wondering if many other people on here would be interested in buying the conversion parts from me through ebay, the parts would be high quality and rally tested to ensure easy fitment and relaibility. The price of the parts would be very reasonable aswel.
    It will take some time to develop/test the parts but I should be well on the way by the end of the summer.
    Let me no if you would be interested by posting here,
    I will creat a new post with pics of all the parts when I have them finnished.
    Watch this space
  36. #195
    Jul 2010
    Minneapolis
    33
    Hi GoodFella. Good engine! I think that it is really good to have that Ztec engine. How much did it cost you with that engine?
  37. #196
    Apr 2009
    Peterhead
    11
    ,,,is there not much happening with the zetec se engine just now ? it all seems to have gone quiet . Its been interesting following the builds etc .
    I've got more interested in fitting my 1400 se to my rally Ka again . It seems that Scholar are building some now as well .
    Not much in the way of exhaust manifolds though ,,they all seem to big bore spec to suit a s1600 type engine ,,I really don't want to lose torque .
  38. #197
    Dec 2008
    Finland
    2,106
    62
    This thread has been quite still for a while now. But I believe it's only quiet on the forums and not in the garages. I just got my SE done and had my race debut with it. And I know of a few Zetec SE builds taking place. I have one race left this season and then its on to EVO 2 with the engine.
  39. #198
    Apr 2009
    Peterhead
    11
    EVO2 ? ,,,what plans have in mind now ?
  40. #199
    25,110
    any good race engine always has the new evo in mind, im planning evo3 version of my race engine even though i havnt built evo 2 yet
  41. #200
    Dec 2008
    Finland
    2,106
    62
    Graham is absolutely right. There's always something that can be done to further improve the engine. I too have a evo 3 or 4 in my day dreams. Just don't want to rush and buy all that expensive hipo hardware untill I'm sure I need it.
    I'm not absolutely sure what needs to be done. So I need one more RR session to try a run completely without the air box, one with the retarded inlet timing and one with the longer trumpets. And I will try if a smooth air duct to the air box would be beneficial. With the info gathered from the RR the evo two will propably see some port work, new exhaust manifold. Engien re-positioning alternator re-posioniting ... etc....etc....so many ideas and so little time....the next season is alway too quickly at hand.
    I also would love a lower than 5.13 ratio but it remains to bee seen can I get one. I have two ways of tackling this problem. The other is swappinf to Atlas axle but it costs like H*ll to do a Group 4 conversion to one.
Similar Threads
  1. which zetec engine
    By rcmex in forum Zetec Installations
    Last Post: 04-02-2007, 18:00
  2. zetec engine
    By toe jam in forum Zetec Installations
    Last Post: 09-06-2005, 01:11
  3. zetec engine
    By matt24 in forum Parts For Sale
    Last Post: 12-11-2004, 20:33
  4. zetec engine need help.
    By damon in forum The Technical Section
    Last Post: 22-05-2003, 12:35
