right ive just got hold of a t5 borg warner cossie box and wanted to replace some seals and check the internals.
got the gearstick off and all is sweet in that end.
got the bolts out of the gearbox cover and tried to remove it but it appears to have a rod through the cover from the back end of the gearbox?
so i got the bellhousing removed today and then when i got home tried to slide the cover forwards and it gets so far and then stops.
then when i slide it back it only slides back this far..
does it have anything to do with this cap on the end of the cover?
basically how do i get the gearbox cover off please? and wheres the best place to get cossie box gaskets from?
cheers. pauly
