WCXM Engine Mount Height???
Im fitting a Zetec Engine to my Mk1 Cortina using a modified (To fit the Cortinas chassis legs) Escort WCXM.
After having a Zetec Conversion in a Cortina a good few years ago, and seeing others, Im convinced my engine is sitting a bit too high (1 or 2 inches)!
Are there any differences in the height of the actual engine mount towers ie: standard or group 4
Cheers..
Re: WCXM Engine Mount Height???
Wcxm lifts the engine up, about 2" from memory I have mine on a wcxm and it sits higher than it did standard
