Help! ive seen this on ebay! http://cgi.ebay.co.uk/T25-T28-Hybrid...QQcmdZViewItem
Should i use them on my engine or not?
Im stuggling to decide what spec turbos i need, but i was thinking along the lines of a pair of T25s from saabs. I know quite abit about turbos, but nothing about how to decide what spec i need.
The engine im working on is a 2.9 12v in my capri. It will be running standard efi with 7th/8th injectors and 7psi to start off with on a std bottom end, so it will be around 220bhp.
What i want to avoid is choosing a pair of turbos that are too large and dont come on boost early enough, or have bad lag. Can someone with more knowledge give me some advice and tell me if that turbo on ebay will cause any bad effects or is it ideally suited?
Cheers.![]()
