Results 1 to 7 of 7
Thread: V8 oil pick up pipe
    Jan 2006
    Cheshire
    143
    V8 oil pick up pipe
    Hi Folks,
    I hope someone here may be able to help point me in the right direction..
    I've got a Ford 351w v8 in a 3dr cosworth.. I've recently got a rear hump sump (Ford SVO) and the pick up pipe to go with it, but I have no idea what distance the pick up needs to be from the floor of the sump, or how I can be sure of actually getting it right.
    I don't think it's safe to assume that it's going to be right straight out of the box, and getting it wrong could be expensive to say the least!
    Any clues anyone?
    Cheers!
    Iain
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Re: V8 oil pick up pipe
    I'm sure he isn't the only one, but Diddy seems to know about these things. PM him if you don't get a reply soon.
    Jan 2006
    Cheshire
    143
    Thanks Dave, I'll sit tight for a bit and see if anyone responds!
    Apr 2006
    essex
    89
    mine is a 302 but uses the same ford SVO sump, pickup should sit about 3/4 -1" off the floor of the sump the pickup should bolt on the pump and off one of the end caps as long as its not been bent should go in correct straight out of the box
    Jan 2006
    Cheshire
    143
    Ah, thanks for that 'Nightmare' ! (Nice car btw.)
    Judging from what you say there, is it true to say it's not that crucial? I kinda had the feeling that every mm might be critical..!
    Talking of the end cap fitting reminded me that I had an additional bolt for that, but it seems like the existing one on the end cap is suitable and all I need is a nut to go over it. Does this sound vaguely possible!?
    Cheers,
    Iain
    Mechanic v8ian's Avatar
    Dec 2004
    FarFar south, any more and my feet are wet, sunny sussex
    755
    I was reccomended to go for around 6mm from the bottom of the sump, and to weld a couple of small tags on the strainer about that size,[6mm] so if you are unfortunate enough to bash your sump, you wont close the gap between the floor of the sump and the strainer and starve the engine of oil.
    Jan 2006
    Cheshire
    143
    Cheers for the reply V8Ian. I've read of someone welding on a nut on the bottom of the strainer for that reason - seems like a good idea especially considering how low things are hanging down there!
    Iain
Similar Threads
  1. Oil Pick up pipe
    By Si3 in forum Wants
    Last Post: 21-05-2007, 16:15
  2. Mk2 RS2000 oil pick-up pipe
    By Ricky in forum Wants
    Last Post: 02-11-2004, 19:33
  3. 2wd Cossie oil pick up pipe wanted
    By RS Yod in forum Wants
    Last Post: 27-08-2004, 00:51
  4. ESCORT 1600 OIL PICK UP PIPE XFLOW
    By The Pigman in forum Wants
    Last Post: 02-04-2004, 21:46
  5. RS2000 oil pick up pipe
    By Pitstop in forum Wants
    Last Post: 07-06-2003, 14:19
