Results 1 to 5 of 5
Thread: 24v cossie starting problems HELP!!
    Jun 2004
    leicester
    14
    got a 24v BOA v6 fitted with emerald ecu
    turns over and over then stops
    or
    turns over and fires one cylinder pos two, but still fails to start.
    with lambda sensor out it flames out of hole but still doesnt start
    want any sugestions simple or complex
    with as much detail as possible and pics or diagrams
    thanks in advance
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: 24v cossie starting problems HELP!!
    Quote Originally Posted by magicrandy View Post
    Simple. Flaming out of there suggests to me it is sparking when the exhaust valve is open. Timing wrong.
    Complex. The above might be due to a wasted spark system.
    (ps. I know feck all about them. )
    Jun 2004
    leicester
    14
    just checked the loom, 1 out of 6 injector plugs were bolloxed.
    fitted some new ones,
    then only 3 of the 6 injectors were squiting fuel.
    so fitted spare set
    5 out of 6 squirting
    took off plug and clipped back on
    all six working, was 11 by this point so didnt try to start as next door like to moan hahaha
    Mechanic Mr_lizard's Avatar
    Jan 2006
    Southend, Essex, Innit
    560
    Mine recently was a non-starter on the Ford ECU and loom. My ECU was full of water and rather green, most of the wiring to the engine was broken, and the timing tensioner blade was in several pieces. Still ran though, just!
    One day people will stop asking 'Is that bit of your car supposed to be hanging off/leaking/on fire like that?'
    Jun 2004
    leicester
    14
    i have fixed the problem now thanks, it was a faulty temp sensor. so it didnt have a reading for cold start procedure
    i have a spare ecu Mr_Lizard if you need one
Similar Threads
  1. Hot starting problems
    By TimGR in forum X-Flow - Pinto - BDA and Twincam
    Last Post: 14-12-2006, 09:10
  2. Starting problems aswell!!!
    By jt1987 in forum RS Turbo's
    Last Post: 20-11-2006, 12:24
  3. Hot starting problems
    By AnthonyS in forum General Car Banter
    Last Post: 01-03-2006, 12:57
  4. Starting problems
    By zeolite in forum RS Turbo's
    Last Post: 16-10-2003, 17:12
  5. Starting problems...!
    By agnelli in forum Cosworth Installations
    Last Post: 15-08-2003, 21:54
