Results 1 to 11 of 11
Thread: Copper Fuel Pipe - what diameter.
    Dec 2005
    Aldridge
    257
    I'm running copper fuel pipe down the inside of the MK2 Escort I'm building (running Zetec on standard injection). I plan to flare either end of the copper pipe and use high pressure rubber pipe for the bendy parts.
    Does anyone know what diameter copper pipe I need for this? The standard internal diameter rubber hose needs to slide over the copper pipe at either end.
    Any help appreciated.
    Thanks.
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Re: Copper Fuel Pipe - what diameter.
    Is there any reason why you can't get a roll of 8mm copper pipe from B&Q and use that?
    Dec 2005
    Aldridge
    257
    No reason as long as the rubber pipe will slide over it.
    Aldershot
    6,190
    Do not attempt this please!!! Use some proper jic connectors on the copper pipe and get the corresponding fittings on the injection hose too. I wouldn't trust a flare and hose clip to take the pressure on fuel injection, maybe for carbs but not injection.
    Try Think Automotive in Isleworth for the bits http://www.thinkauto.com/
    23,915
    236
    i normally agree with richard, but i think hes being a bit over cautious on this one,
    i've run 8mm copper pipe with flare for years on injected motors with never a problem, includin my race cars where incidently once the boost is up and the fuel pressure regulator has done its thing the fuel pressure is in the region of 60psi.
    until very recently vauxhall used push fit rubber hoses and normal hose clips over flared pipes on all there injected cars and many many car manufacturers use push fit hoses and clips on injection fuel filters
    Aldershot
    6,190
    this is true but for the sake of a couple of quid I would use a bulkhead fitting just for neatness.
    Remember the camper......? Decade Plus User
    mk1matt's Avatar
    essex
    9,423
    70
    My manta is just copper flared from new
    Its also what im doing to the escort
    I support TS Decade Plus User
    wildo105e's Avatar
    2,816
    100
    Have a look at this http://www.turbosport.co.uk/showthre...108910&page=20
    I also bought these as i was unsure about flaring the pipe method for a coupla may be well worth peace of mind
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    wildo105e's Avatar
    2,816
    100
    Apologies down the middle of the thread is a piccie of some copper to 8mm rubber pipe adapters. These have multiple ridges on to stop the pipe blowing off.
    Feb 2007
    cardiff
    58
    432
    A copper flare is fine, the pressure in a brake circuit will far exceed that of the fuel delivery pump (60psi)
Similar Threads
  1. fuel pipe question.
    By mark2mex in forum X-Flow - Pinto - BDA and Twincam
    Last Post: 27-02-2006, 18:14
  2. fuel pipe
    By Jon in forum The Technical Section
    Last Post: 04-05-2005, 07:59
  3. Fuel Hose Diameter
    By traven16v in forum The Technical Section
    Last Post: 25-04-2005, 20:18
  4. Fuel Return Pipe and Fuel Pump?
    Last Post: 15-04-2005, 21:15
  5. Fuel return pipe
    By 900ss in forum The Technical Section
    Last Post: 20-04-2003, 00:06
