Zetec install
Hi all. This is aimed at all the electrical boffins.
I have a 2003 1.4 zetec fiesta.
What I want to know is.
I want to put 2.0 blacktop zetec engine in. If I connect it up to the original electrical system.
WOULD IT RUN.
Sent from my SM-T560 using Tapatalk
Re: Zetec install
Anyones guess as they are completely different engine designs! One thing for sure is if it did run the fueling and ignition timing would be out of whack - the std ecu's having limited adjustment potential!
Zetec install
If it uses similar sensor inputs and both use 4 injectors then I would GUESS maybe. But shit.
Yea just wondering if it would fire up / run.I know they are different engine designs. Just been wondering. As I'm in process of starting a big build. And looking at options. Thanks for all the input. Maybe someone in the tuning world can throw some light on this question. Cheers mike
Re: Zetec install
i think from memory the loom is same plug so if you have the loom that goes with the engine it plugs in and is a plug and play item also the ecu plug is the same so you could get the 2.0 ecu sent away and DE-IMMOBILISED all would be good
