Results 1 to 3 of 3
Thread: Cologne 2.8 V6 Alu sump starter motor
    Spanner Monkey mihakrapez's Avatar
    Jan 2007
    Ljubljana, Slovenia, Slovenia
    271
    18
    Hello,
    Once again a small issue that could use your help.
    I hava a 2.8 Cologne V6 in my Taunus (mk3 cortina).
    It is fitted with aluminium sump from 2.9 cosworth engine (2wd) and fitted to T5 gearbox.
    Now I am finishing my car and starter motor doesen'fit due to the lump on the sump.
    Click image for larger version Name:	getrempic223.php_Easy-Resize.com.jpg Views:	26 Size:	89.1 KB ID:	80798
    Click image for larger version Name:	getrempic224.php_Easy-Resize.com.jpg Views:	27 Size:	88.4 KB ID:	80799
    This is the starter motor
    Click image for larger version Name:	getrempic222.php_Easy-Resize.com.jpg Views:	27 Size:	92.4 KB ID:	80800
    Does anyone know if a different starter motor exists or should I take off the sump and cut and weld it which I really don't want to do as it is sealed and mounted.
    Obstacles are those frightful things you see when you take your eyes off your goal.
    Nov 2004
    Sweden
    1,167
    Re: Cologne 2.8 V6 Alu sump starter motor
    I can't remember what starter we used on the 24v Capri but it was a standard starter. We had acess to 2.8 XR4x4, Scorpio 12v 2.9 auto and Capri 2.8 4-speed so I assume we used one of them.
    There are aftermarket standard replacement starters with thinner bodies too.
    Gustaf
    Jan 2007
    271
    18
    Thank you very much Will do some digging
