Ok so ill try and explain, I use a WL7064 currently on my engine and its in a really awkward position under the TBs bolted up to the blanking plate on a Duratec.
I currently use a Man oil filter removal cup with two extensions from underneath with the sump guard off, ive seen this type of oil filter with a 21mm or 19mm male hex the bottom to allow the use of a normal socket.
The filter cant be any deeper than the WL7064.
Anyone know which one I can you please.
