Results 1 to 10 of 10
Thread: V6 engine numbers
    Pit Crew Decade Plus User Allerton Classics's Avatar
    Feb 2007
    Liverpool
    1,662
    17
    V6 engine numbers
    I have a new engine 2.8i v6
    83tm6059
    ba17510d6
    Could some 1 tell me what year the engine is
    Is the 83 the year
    I am planning to put it in a mk1 escort.
    Any help advice also would be great.
    Exhausts, engine mounts etc
    James
    Oct 2007
    middleton
    1,099
    64
    Re: V6 engine numbers
    Quote Originally Posted by bmwjames View Post
    83tm6059
    ba17510d6
    Is the 83 the year
    Not necesarily,that is the part number when it was in production,the 83 does denote the programme year. The engine number is on the N/S of the block towards the front under the cylinderhead
    er...pass,sorry James,I don't have expertise in this area.
    World Champion Decade Plus User popuptoaster's Avatar
    Jan 2003
    Brentwood, Essex
    9,508
    id say use as many capri bits as poss, but its a lot of weight and effort for not much power in an escort.
    Clint's Avatar
    Jul 2001
    897,999
    67
    I agree with popup for the hassle and weight the V6 isnt ideal in an escort, but they do fit see John Betts Restoration to see how to fit one nicely.
    http://www.turbosport.co.uk/showthread.php?t=96591
    Part of the furniture Decade Plus User Tone's Avatar
    Jan 2003
    sarf essex
    11,313
    v6 duratec turbo cheap lighter and good potential imho
    Jul 2007
    Macclesfield
    97
    I've got a V6 in my escort. Easy enough to do. Main points I can think of that gave me traumas were:
    Engine mounts- best to go off the chassis. I tinkered with allsorts just take the plunge and buy a chassis mounting kit.
    Engine positioning- I tried to get mine as far back and down as possible to help the whole weight distribution issue and for pulleys to clear a big electric fan. With the 2.8 having a dizzy you'll have to roll the bulkhead/heater bulge lip. Lowering the motor right down needs a slight inward bulge in the sump. No biggie if your happy welding a little box in.
    Weight- its heavy, no doubt about that! You'll need to seam weld the struts, inner wings etc at the front and use a good straight strut brace or the whole front end pulls apart after a year or so of spirited driving!
    Dont forget hangers for two exhausts.
    Brakes need to be beefed up to stop a heavy motor.
    Any specifics, just ask. This route would allow you the option to later fit a 24v cosworth engine or the 4.0L US V6 as bolt-ins.
    Hope this helps?
    Jul 2007
    Macclesfield
    97
    Forgot to justify....
    the bulge inwards in the sump is to clear the steering knuckle.
    Feb 2007
    Liverpool
    1,662
    17
    Thanks for the info
    Will get the mount kit
    I am in Liverpool,any chance of seeing your v6
    Jul 2007
    Macclesfield
    97
    'fraid its in bits at the engine builders and the shell has gone to the spray shop as a 'fit it in round other jobs'. But if theres anything you need just shout up, I'm happy to help if I can. Just another little thought....with the chassis mount kit I had the engine side plates weren't right for the V6 so I got some new ones cut. Not expensive, just thought I should let you know.
    FLD
    Feb 2007
    Liverpool
    1,662
    17
    I have been pricing parts for the fitting
    £105.00 for the chassis engine mounts, p&p inc
    £70.00 for the remote oil filter, p&p inc
    Exhausts £70.00 x 2
    Then I need a sump and modify it.
    24v engines
    http://www.maddoldbugger.supanet.com/home.html
Similar Threads
  1. Identifying block without engine numbers?
    By Quarterless in forum The Technical Section
    Last Post: 12-03-2007, 00:21
  2. X/Flow engine numbers?
    By Mark2Mark in forum X-Flow - Pinto - BDA and Twincam
    Last Post: 24-10-2006, 06:09
  3. cosworth engine numbers...HELP
    By pugo in forum Cosworth Installations
    Last Post: 22-04-2004, 18:50
  4. cosworth engine numbers...HELP
    By pugo in forum The Technical Section
    Last Post: 11-04-2004, 17:07
  5. help engine numbers
    By Toppy in forum Message Centre
    Last Post: 20-01-2002, 16:18
