Updated list for all my conversion parts:
2 x Engines Both early non coscast-one stripped for rebuild, other i bought last week looks very good.
Gearbox,new 7 degree bellhousing,new clutch fork,new release bearing,new spigot bearing,new quickshift stick.
Manta sump,baffle,3 pickup pipes-enough for 2 manta style ones,new gasket kit.
Twin 45's,new inlet manifold,trumpets,linkage,new twin cable throttle cable kit, K&N filters.
Exhaust manifold, SBD clubman type-good used.
Lowered rack mount world cup x-member-new.
Chassis mount kit-new.
MBE 912 ecu with labelled loom-220 brake map on it apparently,coilpack & leads.
Pair of NEW 286 hydraulic spec camshafts.
Other odds & sods-new water pump,new valve stem seals,nice alloy crank & alternator multi vee pulleys-think i have a clutch cover-will need a pinto plate, also think i have the oil cooler too somewhere.
£2000 ALL IN-no split parts sorry. Can get full pics if needed of everything.
Thanks, John.
