Results 1 to 2 of 2
Thread: Electronic boost control on MS
    I support TS Decade Plus User
    wildo105e's Avatar
    2,679
    91
    Has anyone tried this. I have it fitted to my MS box but really sure what to use. Would it control an amal valve or what exactly do air injectors do
    Nov 2004
    Sweden
    1,089
    Re: Electronic boost control on MS
    A standard magnetic valve, like the boost control valve off a Cossie or Saab turbo (it's the same) is fine for most applications. But basically any electrically controlled valve can be used, like ones in the charcoal canister purge system on cars with catalytic converters.
    I haven't tried boost control, apparently open loop is reasonably easy but closed loop is pretty hard.
    Regards
    Gustaf
Similar Threads
  1. Boost Control Valve
    By carpmart in forum X-Flow - Pinto - BDA and Twincam
    Last Post: 16-06-2006, 17:53
  2. Boost Control
    By jacko996 in forum Cosworth Installations
    Last Post: 31-05-2006, 09:40
  3. boost control
    By nickmk11 in forum Cosworth Installations
    Last Post: 05-11-2004, 20:36
  4. boost control valve
    By 1000 in forum Parts For Sale
    Last Post: 29-10-2004, 13:44
  5. Adjustable manual boost control... (does it work)?
    By Kennert in forum Cosworth Installations
    Last Post: 11-09-2003, 20:52
